Why don't you just take off the old chain and take it with you to the bike store, since you have to return your new chain anyway and buy a new one. You don't even need to know the size, because they will match the old chain with the new chain. No guesswork required.
cost you more to buy the parts than to get a new saw.and thats not even considering the labor which will be twice the parts cost. wrist pin ,connecting rod,rings ,piston a lot of work with no guarantte that it will run or for how long it will keep running. I just bought a new 2013 saw for $20.00 more that they wanted for a new carb for my old saw and went from a old worn 14 in bar and dull , worn out & streched out chain to a brand new never used bar & chain which goes for38.95 at rome depot so, if i take the price of a new bar & chain off the price of the saw,I got the new power head for only $40.00 I know, thats weird thinking----but not that far out there .
The only reason you should consider fixing your old saw is if its a like 100 cc or something that cost $995.00 only then would it be worth thinking about.
try this saw on for size.cpooutlets.com homelite 38cc,16 inch chain & bar with 3 point anti vibration handle ,8 hour cutting ,imcluding many breaks & no numb hands. reconditioned ,60 day money back warranty $ 79.00 & ship free ship for first time buyers if you sign up for internet fliers only 9.7 lbs not much operator fatigue even at 65 yrs old.
hi, prob good idea with this will be to slacken off the wheel push the wheel forward and fit a chain the correct length for the set up you have, count the links in the chain you have on the bike and get one 2 links shorter, mark a link on the chain with paint or sim turn the wheel and count the link plates, ie 1 plate is 2 links, so start on the 1 next to the marked 1 turning the wheel counting the plates 2 4 6 8 10 etc and end on the marked 1 this will give you the number of links already on the bike
Have you tried using new batteries? How long have you been using the old batteries? As far as i know, the longer you use a rechargeable batteries, the shorter its life(compared to the first time you used it).
Try using new batteries, if the problem is still there, the camera my have the problem. But if the camera works fine, then your old battery is defective.
This is the breakdown of parts for your model,you can see how the brake is, but your problem sounds like the dogs inside the clutch are stuck and causing the chain to constantly engage the chain.
Open the clutch to look at it and see what is causing this.
The idle usually will not cause the clutch to engage, this is usually a higher rev that engages the clutch.
in some cases yes, depends if it will physically mount in the same manner, however putting a longer chain on a saw designed for a shorter chain is tougher on the engine, the cc size of the engine is designed to pull on size chain, it may not pull the longer chain as well
If a new chain ::
make and model is important here, as are guide bar length
a particular chainsaw, may be available with 12,14,16,18,20,22,24,26 inch guide bar,
likewise different saws (even from different makers) use the same size of chain
a chain for this saw may be sold in a variety of lengths or
may be sold in the longest length only and require links removed to suit smaller bars.
back to the store, with the saw, for confirmation
If an old chain::
stretched way beyond safety, replace
