Question about Ingersoll Rand Type 30 Fully Packaged Ir Electric Stationary Air Compressor No. 2475N7.5FP 7.5HP. 80 Gallon Vertical Two Stage
Temperature rising - Ingersoll Rand Type 30 Fully Packaged Ir Electric Stationary Air Compressor No. 2475N7.5FP 7.5HP. 80 Gallon Vertical Two Stage
    President:
  • 1,273 Answers
Make sure that your pully fan is blowing across ehe fins. Check and clean the air intake filter. Check the oil level.
Regards, --W/D--
Posted on Jul 19, 2009
Temperature rises,is the water pump damage?
before to suspect water pump not working. need to check radiator cup, if temperature rise on stop. engine thermostat is the other factor of overheat and notice the temperature begin to rise from start up. leaks from radiator is the other factor,coolant is not enough to support the system.
Aug 21, 2012 | Suzuki Cars & Trucks
My temperature has been rising in my saturn if i sit very long in traffic. What could this be?
As long as the temperature isn't spiking and the fan is turning on. It is normal for the temperature to rise to halfway on the gauge and then for the radiator fan to kick on. Sitting in traffic will normally do this.
May 21, 2010 | 2000 Saturn SL
How do i change my auto tranny oil on 1991 subaru
THere is a dran plug on the left side of the tranmission oil pan. These transmission hold alot of oil and it could be very hot, so be careful. You need to change the filter too and these are quite expensive. When re-filling
I Use care not to exceed the upper limit level.
I ATF level varies with temperature. Remember
that the addition of fluid to the upper limit
mark when the transmission is cold will result
in the overfilling of fluid.
4) Fluid temperature rising speed
I By idling the engine
Time for temperature rise to 60°C (140°F) with
atmospheric temperature of 0°C (32°F): More than
25 minutes
<Reference>
Time for temperature rise to 30°C (86°F) with
atmospheric temperature of 0°C (32°F): Approx. 8
minutes
I By running the vehicle
10 minutes
5) Method for checking fluid level upon delivery or
at periodic inspection
Check fluid level after a warm-up run of approx. 10
minutes. During the warm-up period, the automatic
transmission functions can also be checked.
From my Subaru TSB's
Mar 31, 2010 | 1991 Subaru Loyale
Oven temperature does rise and gas smell
MOST LIKELEY YOUR OVEN IGNITOR IS WEAK.REPLACE IT AND YOU WILL BE COOKING AGAIN.
Mar 05, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Its copier (ir2016j)to desply writh system error. wath is this problem?
Canon iR2016 / iR2016J / iR2016i / iR2020 / iR2020i Код ошибки Субкод Описание E000 0000 Fixing temperature abnormal rise E001 0000 Fixing unit temperature rise detection (by main thermistor) 0001 Fixing unit temperature rise detection (by sub thermistor) E002 0000 Fixing unit temperature insufficient rise E003 0000 Low fixing temperature detection after standby (by main thermistor) 0001 Low fixing temperature detection after standby (by sub thermistor) E007 0000 Fixing film rotation error E010 0000 Main motor rotation err
Dec 17, 2009 | Canon Office Equipment & Supplies
The freezer temperature changes sporadicaly. It
The temperature would charge due to change of cycles in the refrigerator operation. For example, the temperature would slowly rise if the compressor has shut off. Also, the temperature would rise significantly during the defrost process. A heater is activated at the evaporator coil to thaw the ice that forms there. This heat would transfer to the freezer unit and would cause the temperature to go up.
As long as the cycles are constant, and the temperature does not rise significantly and keep rising for a long period, there is no problem.
Oct 19, 2009 | Refrigerators
Treadmill smells HOT HOT HOT
Start by lubing your deck with a silicone oil or slipcoat
Apr 06, 2009 | Exercise & Fitness
Temperature rise of compressor
check oil level may need oil and filter change radiator could also be dirty they clog up after awhile should be washed out with a hose often
Mar 18, 2009 | Ingersoll Rand Type 30 Fully Packaged Ir...
Canon MF 4150 error
Oct 14, 2008 | Office Equipment & Supplies
91 buick runs for awhile, engine light comes on, car shakes then quits. fan wont come on to cool it, how do i repair it?
Perhaps if you could provide a little more information or observations, it might be easier to isolate the problem. For example, it appears you may have a problem with the engine overheating and then your engine dies when the extreme temperature is reached. When you start the engine, watch the temperature gage on the instrument panel. Does the temperature rise slowly (lets say over a period of 10 minutes or more) or does it rise quickly to the point of overheating (less than 5 minutes)? If the temperature rises slowly, it is probably just that the thermostat needs to be replaced. The thermostat is usually located in a housing where the upper radiator hose connects to the engine. If however, the temperature rises rapidly, that indicates a more serious problem. Your engine may have a blown head gasket which is venting hot exhaust gases into the cooling system causing the temperature to rise rapidly. I recently had this exact problem with my Chevrolet Venture which, like your Buick, is a GM product.
As far as the fan motor not coming on, the problem might be the fan motor itself. One way to test it is to connect the fan's electrical leads to a 12 volt power source like your car's battery. If the fan works, then the problem could be with the Engine Coolant Temperature sensor (ECT) which screws into the intake manifold. The ECT senses the engine's temperature and tells the fan when it needs to come on to start cooling. I hope some of this helps.
Jul 21, 2008 | Buick LeSabre Cars & Trucks
Ingersoll Rand  Type 30 Fully Packaged Ir Electric Stationary Air Compressor No. 2475N7.5FP 7.5HP. 80 Gallon Vertical Two Stage  Logo
85 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
