Back to:
Tags:
Printers
Generic problem for all Printers
Epson lq 1150
posted by blpandey on Nov 18, 2007
sir,
i have epson lq 1150 power suplly ok and every power is ok but printer not power on
plz help me
bl pandy
blvhpandey@gmail.com
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Nov 20, 2007
Thanks for Trying (70)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
If you are capable of checking the supply then good enough , but still refer a technician , logic bord inside the printer needs to be checked (if your supply cord or adapter is ok) , power controlling chips mounted on the logic board needs to be checked and you should contact the repair centres
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on epson lq 1150:
I don't want to Accept this solution
Solution #2
posted on Nov 19, 2007
Not Rated (0)
dodgecharger
Rank:Wiz Wiz
Rating: 82%, 264 votes
If the printer is dead - no power- no LED lighting at all, and the power cord is OK, then look at the power supply section for a defect. A fuse could be blown, or some component failure. Note- if a fuse is blown, this is usually due a component failure, and the exact problem must be located.
If you have some technical skills, a VOM or digital voltmeter, you might be able to pinpoint the problem. A circuit diagram would be helpful also.
Thank You!
Solution #3
Not Rated (0)
MUKHTAR
Rank:Wiz Wiz
Rating: 78%, 473 votes
chek the power cord is it working fine otherwise show it service personnel may be the mother board of printer is faulty.
bye
Thank You!
Can you Help with these Printers problems?
Canon PIXMA MP530 All-In-One InkJet...
I have a Canon PIXMA MP530. Sent faxes have a black line...
Brother MFC-420CN All-In-One InkJet Printer
After I changed my black and Cyan ink cartiges...I copied...
Canon PIXMA iP1600 Printer
Tring to print and i keep getting erorr 5100 any ideas
Samsung CLX-3160FN All-In-One Printer
Just bought this machine. Cannot get the scanner unlocked....
Printers
I have a Lexmark X4650 and have it connected wirelessly to...
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
