Question about Samsung Televison & Video
Daytek lcd tv
Good sound but picture showing plade lines
3 Suggested Answers
  • 286 Answers
SOURCE: daytek dt4660 lcd tv sound
You have to check (or have someone else check) the surface-mount fuse on the LCD driver board which is attached to the LCD panel at the top under a metal shield. If it's blown, you will get audio and back lights but no video.
If that doesn't fix it, then replace all the electrolytic capacitors in the output section of the power supply.
Posted on May 20, 2010
  • 78 Answers
SOURCE: Daytek DT3220 power button flashes green 4 (5) times, no picture
does anybody have a drawing of this inverter circut using the 74LS04 to invert the enable circut?
Thanks
Posted on Jul 18, 2010
Daytek 46" LCD TV.. When
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Good luck in solving the problem....
Jun 09, 2011 | Televison & Video
My Daytek LCD TV has audio but no picture,keeps asking for auto tunning but no results after it's done.There is picture when TV doubles for my PC monitor.
Hi, Sounds to me like you are almost assuredly encountering a no signal problem. This would account for the auto tuning not doing anything. I would suggest a newer antenna. Local department stores carry a variety of " DIGITAL T.V. " antennas. And as far as the no audio part I have actually "seen " that problem on my own t.v. ( a portable ). When the tuner does manage to grab a signal if it becomes too weak the picture may freeze or go all diagonal or just disappear altogether leaving just the sound. I hope this helps and thanks for choosing FixYa, Good luck ,Prodzilla
Apr 14, 2011 | Televison & Video
On a Daytek 46 in LCD TV, no AV Digital Cable Signal, but HDMI OK
Had the same problem.
Fixed by unplugging everything from the power source, leaving for 2 minutes then plugging back in.
Works fine now.
Aug 11, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
I have a 42DKF3 Daytek TV
remote control and tv controls stopped working
Mar 24, 2009 | Televison & Video
The power supply voltages might look good on an oscilliscope or using a DC meter, but that doesn't really tell you if the supply is good.
Your TV has an unusual symptom, however 99% of the problems on these TVs are caused by the power supply. I have had 3220s that won't power on, the remote or controls on the TV won't work, or the unit blanks out and all sorts of other odd problems. The power supply can test fine, but if you substitute it the TV will work fine.
Sorry to say you're up a creek. The good news is that just about any 5,12,24V power supply for a 32:" TV will work if you are comfortable rewiring the connectors. I have done this a few times and rescued the TVs from an early grave (I'm actually just about to start on another one now). The pinout is written on the board, and make sure the power supply you want to use also has the pinouts marked on the board.
Nov 22, 2008 | Televison & Video
Daytek dt4660 lcd tv sound no picture
Oct 09, 2008 | Televison & Video
On Daytek LCD DT4040, After some time like 2-3 hour, sometime 10-15 minutes, image from source disapear and red and green line appear... Not actually on DVI input, no trouble since 30 minutes.. on test for...
i have a daytek dt 4040 and when i turn it on,i push the red button ,flash 5 or 6 time and turn green have sound but no image. what the problem
Aug 19, 2008 | Televison & Video
Daytek dt 3220 will not power on
OK, your Daytek 3220 is not a projection TV, but an LCD TV.
Second, I hate to say it, but you bought a piece of junk. They have excellent pictures when they're new, but after a few years capacitors in the power supply go bad. When this happens, either the controls and remote stop working, or the TV starts blanking out, or it will just die and never work again.
The solution is to go buy a new TV. The power supplies are no longer available, and even if you could get one very often the faulty power supply has damaged the main board and/or the LCD panel.
In about 5% of these cases, replacing the capacitors will get the TV to work, in about 25% it will get the TV to work, but because the main board has been damaged the TV will intermittently blank out. In another 25% the LCD panel has been damaged so once repaired you will see dark streaky patches across the display.
In the rest of the units you could have all three problems or any combination of them.
It'ds really too bad because they use a Samsung panel, and have excellent pictures when they're working.
Jul 23, 2008 | Pioneer SD-643HD5 64" Rear Projection...
Fly back lines
Check the connector of the crt maybe got a resistor open or a transistor in short circuit.
Jul 06, 2008 | Televison & Video
Older model jvc tv purchased late 90's
I am not receiving a satellite signal on my old model JVC model AV 32F704
Dec 21, 2007 | Televison & Video
Televison & Video Logo
134 people viewed this question
Henry  Thomas
Henry Thomas
