When i start my pc it shows the motherboard control options like (main,power, exit) i can do whatever change i want and then save changes and exit,after exit everything starts properly and works properly but when i turnoff my pc and restart it again again the same thing appears and i have to do a proper exit or press f 5 so that it goes to the boot mode and then my pc starts another wierd thing i am noticing is that the time in pc when it starts is always 1 oct 2000 12pm (whenever i turn on my pc), no matter how many times i change it once i turn off the computer it starts with the old date and time , although this problem has not effected my work whatever i have saved i have never lost but still it is a problem and i want to solve it. thanks, waiting for your responce
  • 374 Answers
The CMOS Battery has gone Kaput/Weak.Change that and everything will work fine. Let me know if any other problems.
Posted on Jul 16, 2009
    President:
  • 948 Answers
There are two likely reasons for this. One is a dead battery on the motherboard. Remove the battery and check it with a multi-meter or just replace it. If the battery is good, your BIOS is probably corrupt. Go to your manufacturer's website (hp.com in your case) and flash your BIOS to the latest version. If that does not work either post back with your exact computer model number and operating system and let's do some more digging.
  • 1,511 Answers
Please replace your CMOS BIOS battery cell. these symptoms are due to the fact that your battery is dead and it is not letting the bios save any data
it is a silver colloured cell approx 1 inch in diameter and is located on your computers motherboard...
for more assistance in replacing the cell please contact me
Hope this solves your problem/
Enable hyptreading
Hyper-threading is technology available on some Intel processors. If your process and motherboard are hyper-threading, you can enable to option in your Windows operating system. Hyper-threading allows your processor to perform multiple operations at once. Hyper-threading is used on multi-core processors and will share the workload among each core.
Restart your computer and repeatedly press the "Del" key or the F2 Key to enter BIOS this will vary depending on your computer and BIOS Press "Tab" to highlight "Main" then use the down arrow key to select "Hyper-Threading-Technology" then press "Enter". Select "Enabled" then press "F11" to exit and save changes. Your computer will now restart with hyper-threading enabled. Click "Start" then "Control Panel" and double-click "Device Manager". A window will appear showing your computer's hardware devices. Click the "Processors" drop-down menu. Right click one of your processor cores then click "Properties". Confirm hyper-threading is enabled. Hope this helps.
Jan 01, 2013 | Lenovo IdeaCentre B320 7760-2SU All-In-One...
There is a blue lock that appears in the center of the screen
Change the OSD Lock option from ON to OFF by following these steps:
Press the Menu button on the remote or the control panel for 15 seconds to unlock the OSD menu.
When the OSD menu appears, select the Management option at the Main Menu, then select OFF at the OSD Lock option.
Select Exit to save the setting and exit the menu.
hope this helps
Aug 07, 2012 | Dell OptiPlex SX280 PC Desktop
Beeping with f and e showing
BMP accepts the following options: -h, --help Show summary of options. -n, --session Select BMP/XMMS session (Default: 0). -r, --rew Skip backwards in playlist. -p, --play Start playing current playlist. -u, --pause Pause current song. -s, --stop Stop current song. -t, --play-pause Pause if playing, play otherwise. -f, --fwd Skip forward in playlist. -e, --enqueue Don't clear the playlist. -m, --show-main-window Show the main window. -v, --version Print version number and exit.
ford performance chip.
May 25, 2012 | Kitchen Ranges
Hi I'm getting a 8709 error code from my CDJ 800 any idea how to fix this?
According to Pioneer there are 2 possible faults associated with this error.
Option 1 - Error in mechanical operations Unrecoverable: Turn the power off. The error indication will be cleared. If the error still shows then it's Option 2.
Option 2 - Communication error between operating section and main section The error indication is cleared when the communication is finished (if it can finish).
Communication fault between the control interface (the PCB with all the switches on) and the main PCB (the motherboard in the base of the unit). It could be that the main ribbon cable that connects between the two has come loose or damaged. The control interface works on a digital PCM system, and if there is a problem with this, the motherboard throws a fit.
May 11, 2011 | Pioneer CDJ-800MK2 Turntable
Factory reset without using a disk and ALT + F10 doesnt work
his MIGHT work:
1. Click "Start," "Turn Off Computer" and then "Restart", if it is on. If your computer is off, turn it on by pressing the power button above the keyboard.
2. Press the "F2" function key on your computer's keyboard to enter the BIOS utility.
3. Use the laptop's right arrow key to scroll to "Main." Confirm that the "D2D Recovery" is "Enabled." If the D2D option is "Disabled," scroll down to the option using the down arrow key. Press "Enter" to change the option to "Enabled."
4. Use the laptop's right arrow key to scroll to "Exit." The "Exit Saving Changes" option will be highlighted. Press "Enter" to save the settings and exit the BIOS utility. Your Acer Aspire will restart.
Reformatting the Acer Aspire
1. Press the "ALT" and "F10" keys together while your computer is restarting and the Acer logo is showing to enter the Acer Aspire's reformatting utility.
2. Follow the on-screen prompts. Your laptop's hard drive will reformat and the original applications will be reinstalled. Your computer will restart after the reformatting process is complete.
3. Enter your name and other personal information when prompted during the Windows operating system setup process.
Mar 22, 2011 | Acer Aspire One PC Notebook
My PC doesn't load
Restart computer. Watch closely at the bottom of the screen for an F command.
This F command will allow to enter setup.
When computer is loading, start pressing F12 repeatedly until setup is opened.
When setup opens, you'll see a file menu that runs across the top of the screen. It will start from the left and move to the right - press F9. When prompted, select "restore default settings". Move to each file menu and press F9 and set "default settings".
When you come to the Exit menu, do the same thing, then select the Exit Menu, and choose the "Exit Saving Settings" option.
Once it exits, it will automatically restart and begin the loading process into Windows (or your operating system).
If the OS does not load, you will need to re-enter setup: under the file menu, search for an option that will allow you to enable a second F command which should be F5 or F10. Once this is done, go to exit, and select "exit saving settins".
The computer will begin loading, but you will want to restart the computer - watch again at the bottom of the screen for the new F command - remember what it is when you are in setup, and begin pressing it as before with the F12 command - the F5 (F10) will bring you to an option menu for starting the computer - select the "start in safe mode" option.
If the computer does not load in safe mode, you will need to format the hard drive and re-install the Operating System.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jul 23, 2010 | Acer Aspire m5640 PC Desktop
I replaced the battery because the clock stop. When I restarted the PC no recognized the IDE ports, hard disk, floppy disk and CD unit.
Turn on power and starting pressing the "del" key to enter the BIOS. Find the place that says "Load default setting" and select it. Then select the "save and exit" option. System reboots and should work.
Nov 10, 2009 | Soyo SY-P4IS2 Motherboard
Usb ports
This can only mean on thing that the USB port on your computer is not properly working, what you can do here first is to run the setup CD for your motherboard so all the software including the driver for the USB port will be reinstall, if after that still not working the USB port of the computer is already bad...
May 27, 2009 | Computers & Internet
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
