Question about Apple iPod MA446LL/A MP3 Player
I pod the pod comes up with a folder with a warning sign,have press all the buttons ,but nothing seam to work
  • 67 Answers
Have you tried a re-set?
Toggle the hold switch on then off. Then press the center button and the menu button at the same time and hold them down. After a few seconds the screen should flash and the player will re-boot. You may need to try this several times.
If that doesn't work, you may have to do a restore. Connect to your computer and open iTunes and follow the directions for restore. All your music will be erased but you can just re-load it by syncing after the restore is complete.
Posted on Nov 19, 2007
Turn signal relay 2008 jeep location
There is no relay , controlled by integrated power module . Electronics !
Feb 12, 2016 | 2008 Jeep Grand Cherokee Laredo
How to reprogram psp
    • 1 Remove the battery from the left side of the PSP while it is still on. The unit will power down instantly. Wait 10 seconds and then replace the battery.
    • 2 Press both clear shoulder buttons at the top of the PSP and keep them held down while the PSP reboots. This initiates a "Recovery" mode.
    • 3 Press down on the control padicon1.png to locate a "recovery" folder. This will contain all of your PSP content, including games, music, videos and pod casts that are saved on the device. Highlight this folder and press the "X" button to begin reinstalling your content.
Dec 06, 2013 | Sony PlayStation Portable (PSP) Console
My i pod touch is blank, i've followed the relevant stepr to restore it. after which an error code was given on i-tunes, i followed the steps given for the error but my i pod is still doing...
Try this:
Hold down the middle button (home button), the power button, and the volume DOWN button (make SURE that it's not the up one. It won't do anything, but it won't fix your iPod. Only the Down button will.).
Hold all of these down until the Apple sign shows up. Once the Apple sign shows up, it SHOULD work.
I hope this helps!
Jun 15, 2011 | Apple iPod touch
My mac laptop screen has gone a cloudy white and no buttons or typing or mouse scrolling works... after a few minutes a little folder picture comes up with a question mark in the middle of it ontop of the...
The computer can't find the operating system. It could be a sign of your hard drive failing.
I'd suggest booting up the machine while holding the 'option' key and selecting your startup disc, if that doesn't work, insert the OS installation disc and hold either 'option' to select the startup disc or hold 'c' which will boot directly from the DVD.
Running disc utility and repairing the permissions and verifying the disc MIGHT solve the issue. However usually when the machine can't find the OS it is a sign of hard drive failure.
Feb 18, 2011 | Apple Computers & Internet
Create and share toolbar is grayed out
try this
The toolbars can be turned off. They can also be dragged out of the viewable area. If they are turned off, they can be turned on by going to the View menu, to the Toolbars sub-menu and selecting the toolbar that is missing. If it already has a check next to it and it is missing from the program, then it has been dragged out of the viewable area. To correct that:
Warning: Make sure that you are only deleting folder/keys that you are directed to delete in the Registry. Deleting any other folder/keys may cause problems with your system or other programs. Novadevelopment assumes no liability for changes you make in the Registry.
  1. Close the Publisher Pro program.
  2. Go to the Start button and select the Run option.
  3. On the Run window, type “regedit” without the quotes in the Open field.
  4. Click the ON button. This will open your Registry Editor program.
  5. Scroll to the top of the left-hand side of the window to where you can see the My Computer option.
  6. Click the plus sign (+) next to the HKEY_CURRENT_USER folder and this will expand a list below it. If it has a minus sign (-) next to it, skip to the next step.
  7. Click the plus sign (+) next to the Software folder and this will expand a list below it. If it has a minus sign (-) next to it, skip to the next step.
  8. On the list that appears below Software, locate the folder labeled Nova Development. Click the plus sign (+) next to the Nova Development folder. If it has a minus sign (-) next to it, skip to the next step.
  9. On the list that appears below the Nova Development folder, locate the folder labeled Art Explosion Publisher Pro. Click the label for the folder Art Explosion Publisher Pro. It should now be highlighted.
  10. On the Art Explosion Publisher Pro folder name is highlighted, go to the Edit menu and select the Delete option. On the warning box that confirms the delete, select the Yes button.
  11. Close the Registry Editor window.
Jun 06, 2010 | Nova Development Photo Explosion Deluxe...
Becomes frozen on 'Refresh Database' screen- help?
The only solution I found to work with the SAME problem was to 1. turn the player off (if you can't press the power button, then hold the power and menu button at the same time and it will turn off) 2. turn the hold switch to the right. 3. press the on and rec buttons simultaneously 4. connect to the computer 5. when the 16 MB folder comes up, create a folder called 'sansa.fmt' and disconnect the usb cable. *warning! this will erase everything, but it's seriously the only solution i've found that works!
Oct 30, 2009 | SanDisk Sansa e250 MP3 Player
I pod 5th generation
i dont now
i havee
the same problem
Aug 05, 2008 | Apple iPod MA446LL/A MP3 Player
Waste ink absorber full
Hi there try see if this will work
Reset ip2000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jul 25, 2008 | Canon PIXMA iP2000 InkJet Printer
To resolve the problem with "waiting" message when opening images/photos folder is that:
  1. Type: ##1133, then press END (red button);
  2. Select "Photo delete";
  3. Press OK button;
  4. Press END (red button).
WARNING: All your photos and videos will be deleted.
NOTE: On my phone works but now I got a problem with sound folder.
Nov 23, 2007 | O2 Xda II mini
60GB ipod locked up (code forgoten)
i forgot my code, how to poen it? pls reply ..................i pod 60gb
Jun 15, 2007 | Apple iPod MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
20 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
