Question about Victor Welding Tools
Where to find a valve stem or repair parts for my Victor csr 450D oxygen regulator?
    Problem Solver:
  • 5 Answers
Call ESAB they bought Victor 843-664-4405
Posted on Jul 16, 2009
Engines idle goes up and down after warming up and blows blue smoke
If the engine idles for a while then blows blue smoke this is an indication of oil passing the valve stem seals and being burnt in the combustion process. ( When you are at lights and they change and you accelerate away leacing a cloud of blue smoke this is worn valve guides and failed valve stem seals) As for the idle it could be the oxygen sensor is coated with oil and soot and is malfunctioning henace the cpu cannot regulate the fuel setting correctly. Have the valve seals replaced and clean the Oxygen sensor and check for other fault codes
Feb 17, 2013 | Cars & Trucks
I have a victor model 100 torch.The spring appears to be broken in the oxygen handle.What is the screw in valve called and where can i get one
Check this manual. It's not for your exact torch, but the parts are about the same. You should be able to go to any welding supply hose and buy parts or have your torch repaired.
http://www.thermadyne.com/IM_Uploads/DocLib_2340_56-1055%20CA%201260%20-%20CA%201350%20-%20CA%202460%20Series%20Cutting%20Attachmen.pdf
Oct 13, 2010 | Garden
Need parts for victor 272654 oxy reg
I will sell exterior parts only,I do sell internal regulator parts but only to certified technicians that have the test equip and can re-certify the gauges after a re-build
Jul 27, 2010 | Victor Welding Tools
I can't adjust these gauges. How do I do it?
The only part of the gauge that adjust is the tee handle in the middle. the gauge on the left tells you the line pressure to the torch, the gauge on the right tells how much oxygen is in the bottle, usually on a K bottle it is 1800 to 2000 lbs. if you turn the tee handle and the left gauge that tells line pressure does not respond you probably have a bad diaphragm in the gauge. Seek qualified repair man. Thanks
Feb 02, 2010 | Victor CSR350D Oxygen Regulator
My victor oxygen regulator stopped regulating.
send it in for repair at any welding supply, most of them will ck' it out for free before they repair it, probably is grain of dirt / sand will cause that effect.
Jan 09, 2010 | Victor CSR350D Oxygen Regulator
The safetybald is liquing from my oxygen gage what can I do to fix it what part can I buy
replace it the and check your regulator valve your leaking, may be a seal is out in side your gage. i would replace it fri-st, if that doen't work have your regulator check. good luck
Oct 14, 2009 | Victor CSR350D Oxygen Regulator
My oxygen regulator wont hold proper pressure. It just keeps going up.
Diaphragm needs replacing. Take it to the shop...this needs to be done correctly.
Jul 23, 2009 | Victor CSR350D Oxygen Regulator
Can't control pressure on victor oxygen regulator
One gage is fixed for tank volume the other is variable for you to set for process. if the variable gage dose not work you may have a bad diofram. You could purchase replacement repair parts at your welding supply store.
Mar 02, 2009 | Victor CSR350D Oxygen Regulator
Welding Tools Logo
213 people viewed this question
Top Victor Welding Tools Experts
Bill Boyd
Are you a Victor Welding Tool Expert? Answer questions, earn points and help others
