SANYO PLASMA TV DP42746 , HAS SOUND AND GETTING SPECKLES ON THE SCREEN LITTLE PATCHES OF COLOR POPPING UP IN DIFFERENT SPOTS. I HAVE REPLACED THE LOGIC BOARD.
  • Melvin Augustus
    Melvin Augustus Jul 16, 2009
    NEED TO ADJUST VOLTAGES TO SEE IF SOLUTION WILL WORK, OK?
  • Melvin Augustus
    Melvin Augustus Jul 17, 2009
    HAVE NOT FIXED THE TV YET , I'M SURE YOU HAVE LED ME IN THE RIGHT DIRECTION., THANK YOU.
  • 19,396 Answers
To start test the connection cable, and check if switching to a different kind of connection problem persists. For example if you are using HDMI, try RCA or composite cable to test. If the problem happens with the built in tuner, test unplugging all other cables apart power and aerial.
Try also leaving the TV unplugged overnight, and to test place a portable AC in the room where the TV is located, Plasma TV are sensible to climate factors such as temperature and air pressure.
If you replaced already the logic board , you already excluded a problem with the video processing section.
That means that the problem concerns the voltage to the plasma panel, or that you have a faulty plasma panel.
This is fixed by accessing the back panel on the TV and regulating voltages with the aid of a voltmeter, adjusting VE and VS, and VSet values. The right values are usually written on a stickers inside the TV, behind the back panel.
The values are usually adjusting acting on potentiometer while reading the voltage at the same time.
The job is quite delicate and for safety reason must be done by an experienced repairman.
If that is not enough , sometimes a faulty sustain board in rare occasions can cause same problem.
Usually you fix the problem regulating voltages within factory recommended settings for your TV.
Regards.
Posted on Jul 16, 2009
  • Ginko
    Ginko Jul 16, 2009
    Yep, the first thing to do is locating the pots at the back and adjusting voltages. If that does not work, ensure it is not a bad soldering joint to the signal board used, then eventually you can go for a sustain boards kit, even if that will be a bit risky, since sustain boards causing this kind of problems are difficult to spot.
    In that case a service manual to check Sus Boards volts would be helpful. Parts and service manual can be purchased from Partstore or Encompass Parts (Vance Baldwin).
    regards.
I have a sanyo 42inch plasma tv that is giving me the error code D12V what does the code mean? The model number on the tv is dp42746. Thank you for your help.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Error code details to many popular brand TVs are given.
Apr 20, 2015 | Sanyo DP42746 42 in. Plasma Television
Green tint
It sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel... replacing a new colour wheel will solve ur problem
thank u
rate me
May 29, 2009 | Sanyo DP42746 42 in. Plasma Television
Black screen on my sanyo
Call Sanyo. The 800 number is on your remote. Insist on talking to a supervisor and you may get somewhere. I had to do this and Sanyo called today to tell me to take my tv to the shop. They are paying for parts and I have to pay labor to get it fixed. Repair shop said $35.00 to look at the set and if it's just to boards that need to be replaced, it wouldn't be too expensive. We'll see.
Sanyo told me they haven't gotten many complaints on this tv, DP42746, 42" Plasma. You guys have to call them and complain.
Jan 07, 2009 | Sanyo DP42746 42 in. Plasma Television
I get white speckles on black parts of my picture
In years past the problem was created from something that has a bad motor in the area of your house or on the power lines. The 'speckles' sound like ignition noise. I have traced them to strange things as a butter control in a refrigerator. To be sure if that this is causing your problem you can take a radio and tune it around 550 mhz and you will hear a crackle or buzz. Best to use a battery operated radio and wave and walk around until you get the loudest noise and that will be the source of your 'speckles'. Could be as simple as a loose connection in your panel box.
Jan 06, 2009 | Sanyo DP42746 42 in. Plasma Television
No sound and black screen
lets get together, start a list of names and sue companies selling crappy wares at way too high prices! email saryejade@aol.com
Nov 09, 2008 | Sanyo DP42746 42 in. Plasma Television
Screen goes black but still have sound
MINE TOO AND SANYO TOOK THIS TV OFF ITS SUPPORT WE SHOULD ALL SUE THIS COMPANY gcolella@snet.net
Jul 26, 2008 | Sanyo DP42746 42 in. Plasma Television
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
