Question about HP Pavilion dv1000 Notebook
My computer has been very slow and I would like to take it back to factory settings. Do I reformat the hard drive or do I do something else??
  • HP Master
  • 1,606 Answers
You can reinstall windows or use your restore dvd/cd that is something like using a hammer to open eggs. Seeing how this is summer you need to make sure your slow isn't hardware. Put your hand on
the back of the case where the power supply is and feel how warm the air is. It should be warm but not hot. If your computer runs normal then slow after it has run for a bit or has locked up then you may need to have you case and fans cleaned out. That can be done with compressed air but should be done with a vacuum. You need to be careful not to over speed the fans. If you have gas heat, pets, smoke or the computer is in the kitchen then you may need to do this once or twice a year for a desktop and more often for laptops.
Next thing is to make sure you have enough free space on C. Windows gets rather grumpy when it has low disk space on C. It doesn't help that everything installs to C by default. Run the disk cleanup utility under start-all programs-accessories-system tools and see if that helps. Also try deleting downloads or un-installing programs you no longer use.
If you don't think its running hot and you have space then we can try the software stuff.
I would look at what software you have running. The usual slow making suspects are things like monitoring or imaging programs. As an example you have a 3 in 1 printer and when you install it it loads a management suite that now runs all of the time. Or you have a digital camera and you install the drivers and it loads a management suite of software and image programs and they run all of the time. Or you use MSN and ot loads from start and runs all of the time or a p2p sharing program.
On most of these they will have an option for not starting or loading all the time. It is worth the time to try finding the guilty piece of software as you would probably reinstall it again and be right back at the same place.
To see whats running easiest place to look is under start-all programs-startup Anything placed there will start when windows starts. Anything in there can be dragged out (and back in if needed) and dropped in another part of that menu. There are a few things that are quite safe to get rid of. Office toolbar or acrobat speed loader are two prime examples. The less in there, the better. Other programs such as MSN you will have to start and then look under options and see how it connects. Make sure it doesn't start when windows starts. There will be some programs that have no options to disable. On these you may need to un-install and then reinstall and carefully check if you can disable any options. If that won't work consider if you need/use the program at all. When you find the one piece of software that is doing this all of a sudden your pc will be running much faster. It will not be as fast as a fresh install but the fresh install doesn't have any software running either.
If none of this works and you are set on reinstalling windows. You should do a few things. One is to copy off all of your "stuff" ie documents, email and account setting, favorites. That way when you are running again you can just import them and have everything. If you save off your stuff then I would format the drive. This will cleanup any errors and give you a fresh start. Format it in NTFS when given the option.
This is a bit longer answer to your question but you should spend a bit of time checking as you can find yourself right back at slow pretty quick. If you know what to look for after your install then you can keep te slow from reoccurring for a log time.
Posted on Jul 16, 2009
    President:
  • 948 Answers
The best way is use recovery discs if you have them. If you do not have them, but you do have an operating system disc and a drivers disc you can reformat the hard drive (don't forget to back up your data, this process erases everything), reinstall the operating system, then reinstall all your drivers & software.
Keep in mind that any software you have added since the computer was new will have to be reinstalled as well.
  • 1,511 Answers
Yes the best solution is to reformat your hard drive and reinstall your operating system but make sure to backup all your data before formatting.
Hope this helps ...thnx
How do i restore a inspiron b130 to factory settings
You may follow the below steps to perform a full factory restore:
Use an external hard drive to back up any important files on the computer as all of the data on the computer's hard drive will be erased during the restore process. Connect the hard drive to the computer via the USB cable and transfer any valuable photos, music, programs or documents into the hard drive's folder. Once all the files are copied into the folder, right-click on the hard drive's folder icon and choose "Eject."
  • Remove any other unnecessary hardware device cables connected to the computer as they maybe damaged when the computer is restored. Disconnect any scanners, USB drives, MP3 players, smart phones and the external hard drive.
  • Close any programs running on the computer and turn off the computer. Turn the power back on and hold down the "F8" key when the Dell logo appears on the screen to open the "Advanced Boot Options" screen. Make sure to complete this step before Windows loads.
  • Click on the "Dell Factory Image Recovery and DataSafe options" icon. Select the language settings for the computer and click "Next." Check the box for "Yes, reformat hard drive and restore system software to factory condition" and click on the "Next" button to begin the restore process. The computer will then erase the hard drive and restore the computer to the original factory condition. Press "Finish" to restart the computer with the factory settings restored.
  • Hope this helps..
    May 07, 2014 | Dell Inspiron B130 Notebook
    HOw do i reset my computer to where its practiclly new?
    Restoring an HP computer to factory settings requires that you do a system recovery.
    There are two types of recovery for HP computers: destructive and non-destructive.
    Destructive recovery will reformat your hard drive, destroying all data and reinstalling the operating system and additional software according to the factory configuration.
    Non-destructive, or "system," recovery will repair your Windows installation, replacing any damaged or missing system files and restoring the registry to the factory setting.
    Non-destructive recovery is the best option if you are unable to back up your user data before running system recovery.Restoring with CDs
    Back up all crucial user files if you are able to do so.
    If your computer will not burn CDs, use flash drives of 4GB or higher to store your data.
    Alternatively, you can use your network to transfer files.
    You can then back up your data to CDs at your leisure.
    Detach peripheral devices such as removable media drives, USB drives and your printer before recovering.
    Also remove any additional hard drives by disconnecting the cable from the back of the computer.
    Leave your monitor, mouse and keyboard attached to the computer.
    Shut down your computer.
    Place the first recovery CD in the CD drive.
    If your recovery files are written on a partition, you may be able to select system recovery from the splash screen and your computer starts.
    Select the recovery option you would like to use.
    To perform a destructive recovery, click the "Advanced" menu option.
    Select "Destructive Recovery" and click "Next."
    To perform a non-destructive, or system, recovery, click "Next" from the opening screen.
    Watch the computer while it is recovering to the factory settings.
    Watch for any errors, as the computer will wait indefinitely for a response from you, slowing down recovery time.
    Also, you may need to insert additional recovery CDs as the recovery program requests them. Restoring With Recovery Manager
    Click the Windows "Start" menu, type "Recovery" in the Search field and press "Enter."
    Click "Advanced Options," choose "System Recovery" and select "Next."
    If you are prompted to use Microsoft's recovery program, select "No."
    Choose the option to back up your files, if you haven't done it already.
    Once that is complete, choose "Next" to begin reformatting the drive and returning the system to factory settings. http://h30434.www3.hp.com/t5/Notebook-Operating-Systems-and/How-do-I-RESTORE-my-system-to-the-original-factory-settings/td-p/50113
    Dec 08, 2013 | HP Computers & Internet
    Factory reset
  • To 'factory reset' an external hard drive you will need to do something called reformatting. This will wipe all the data and return the drive to a as new state as far as information goes.
  • Begin by plugging the drive into a PC and find the hard drive in the "My Computer" window.
  • Right-click on the hard drive (It normally shows up as a letter like E or F ect.)
    In the right click menu there should be a "Format" option, click it and chose to reformat the drive in NTFS format, this is the format commonly used for most hard drives.
    If you get confused at any point you can do a quick google search for 'reformat a external hard drive'
    Hope that helps!
  • Oct 18, 2012 | LaCie Rugged All-Terrain (301017) Hard...
    How to reformat
    Hi Pamelaventan...
    To set you computer back to factory fresh settings you will need to format the hard drive and reinstall the operatins system and the drivers.
    You will need to have the CD's that either you made when you got your computer or if your lucky you got the CD's that the factory furnished with the computer at the time you bought it.
    1.
    Format the hard drive:
    You do this by double left clicking on "My Computer",then double left click the main drive (normally C drive).
    When the window pops open, you will choose "Format"
    Keep in mind that once you format your hard drive you will loose all your files,programs,pictures,etc that you installed since the computer was new. So make your back up on a portable hard drive,thumb drive,etc.
    2. Once the formatting of the hard drive is complete you will need to reinstall the operating system along with the drivers.
    That will bring your computer back to factory new condition as far as operating is concerned.
    Please take time to rate me
    Sep 01, 2011 | MSI Wind U100-030US Laptop
    Emachine 3653 factory restore
    You can use the Restore CD that came with the computer. The eMachines restore disk sets your PC back to factory settings with the original operating system and programs that were shipped with the computer. Doing so resolves many problems that can arise from long-term computer use, viruses, or the operating system slowing down.
    1. To do a factory restore insert the restore CD then reboot the computer. When prompted, press any key to boot from the CD.
    2. Select the option to "Reformat the drive to factory settings."
    3. Follow the on-screen instructions to reinstall the operating system and original software that came with your computer.
    4. Once the Restore finishes, you can re-install all the programs that you added to the computer as well as restore your files.
    Reminder: Reformatting your computer erases all of your installed programs, personal documents, pictures and music. If you have the ability to, back up all of your personal data using a removable flash drive, external hard drive or DVDs before doing a Factory Restore.
    Apr 06, 2011 | Computers & Internet
    I just want to restore to factory defaults
    The best way to reset your Laptop to Factory Default is to reformat it. Depending on which version of Windows you have this will create a directory in your Hard Drive called Windows.old, or depending on whether or not you deleted the partition, it will erase everything. You'll want to back up your hard drive if you have anything worth saving.
    Beyond that, pop in your recovery disk, or if you don't have it, put in your Windows disk, then restart your computer. When your computer is booting up, head into the BIOS and set your computer to boot from your DVD Drive. If you aren't sure how to do this then reformatting is probably not a good idea. Once you've booted from the disk, just follow the instructions to reformat.
    Dec 27, 2010 | Acer AX1200-U1520A PC Desktop
    Want to bring it back to factory new
    Dec 26, 2010 | Toshiba Satelite 2405-S201 Notebook
    I've got Aspire 6930 and the hdu's partitions have been erased. I got the factory recovery cd's. What do I need to do to restore the factory partitions?
    How was the partitions erased? Did somebody reformat the whole hard drive itself or just a partition. If the hard drive was reformatted then there's no way you can recover the factory partitions. Normally ther will be a hidden partition in the hard drive in case you want to use the recovery cds that came with it. And thru this, it will restore the factory settings on your computer on the state where you first got it. There is another option you can recover deleted partitions in case when the hd was reformatted like the stellar software, etc. but you have to buy it.
    Nov 05, 2010 | Acer Aspire One PC Notebook
    Computer cant find disk to start windows
    This could mean one of 2 things. Your hard drive is damaged or your Windows installation is corrupt. Try reformatting it using the discs that came your computer. Just keep in mind you will lose all of the information on your hard drive. (They reset your computer back to factory settings)
    Sep 11, 2008 | Acer Computers & Internet
    I cant get factory settings on my computer My hard drive wont work properly Ihavent got any memory.Computer very slow Please explain in laymans terms Obliged
    1. Factory settings on computer.
    There really isn't "factory settings" to reset. Well it isn't simple as that. There is the BIOS which can be reset to "default settings" for the BIOS. Also most brand name computers come with a recovery feature, in which you can recovery/restore the computer back to original factory defaults with original software all installed. Therefore the computer's operating system (usually windows) will be running with the programs like it would run if you were to buy the same new laptop.
    2. Hard drive won't work properly.
    You can give the hard drive a test using the hard drive's company's hard drive testing software which can be download from their site. The software would test the hard drive to make sure nothing physical is wrong and the hard drive is functioning like normal.
    3. Haven't got any memory. Computer very slow.
    You can always buy more memory. If windows says it's running out of memory. That means there is too many software running in the background.
    Comment if you want more explained.
    Aug 16, 2008 | Computers & Internet
    HP Pavilion dv1000 Notebook Logo
    121 people viewed this question
    Top HP Computers & Internet Experts
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
