I have a Liquid Video model NO : 1611008 tv/monitor. Basically from what I can tell is there is a black and red cord on the bottom left hand side that has been tampered with (inside the t.v). How can I fix this problem? If i put the red one with the black one I get a little green flashing light. if I put the red with the red and the black with the black I get nothing. both ways the t.v does not turn on.
SOURCE: red light flashing 6 times
I found the above web site pretty helpful, too (AVForums), and have spent a couple of hours reading that thread.
Seems like the capacitators are often why the power won't come on. Also, some people mentioned that holding a blow dryer to your TV will make it come back on. According to the tech-savvy people that could mean that your "solder joins" are cracked. So when they're cold they'll contract and lost the connection,and when you heat them up, they expand and reconnect where they are supposed to. I'm not tech savvy and this doesn't explain much to me, but it's interesting, and I'm sure somebody will go "aaah, I see...."
I'll quote a post from AVForums:
"The main components that wear out are the capacitors which, with aminimum amount of electronics knowledge and a suitable soldering iron(you need one with a tiny point, preferably a butane gas powered one)and a powerful magnifying glass. This must be self supporting or onethat hangs from a neck cord.
The capacitors and any other parts you need can be purchased very, verycheaply from rswww.com and they offer a free delivery service or, foran extra fee, a next day service!
When you remove the back panel from the TV, you will see a few circuitboards and you need to locate the one for the power supply.
On mine it is really obvious as it is situated at the top just left ofmiddle. They all have numbers printed on the circuit board. Mine are2662 (25V 1000 uF) 2663 and 2664 (both 50V 100uF)
The ones originally fitted are '85 deg C' but it is best to replacethem with ones that are '105 deg C' because they will last longer.
These '85 deg C caps' normally have a guaranteed life of of 1000 hours,whereas the '105 deg C' ones have a guaranteed life of 2000 hours!
This being the case, when Philips build the sets they know that theywill probably break down after a minimum of 1000 hours of use. If wesuppose that the caps last for twice their minimum life span (2000hours) and the TV is switched on for an average of 5 hours per day overthe year one, ore more, of them will probably fail in the secondquarter of the second year.
With this knowledge, for high cost items such as this, you would alwaysbe wise to take out an extended warranty and Philips, or any othermanufacturer, should be obliged to include an information card warningconsumers of this fact!
The Aluminium Electrolytic - Radial capacitors in question are,usually, 2 x 100uF. The voltage, I believe, depends on the screen size.My 42" screen requires 50V whereas the 32" version uses 25V caps.
There is also a larger 1000uF capacitor, of a similar type, that willbe sighted close to the other two. This seems to be 25V, whatever thescreen size!
The only thing you must remember when replacing these caps is that thelonger leg on the capacitor is 'Positive' and the shorter one is'Negative' and you must ensure that you do not damage the circuit track!
If you are careful and have a steady hand it is quite an easy job butif you are not too sure, you will probably be able to find a localrepairer that is able do the job.
However, you have to beware of the Companies that offer a service wherethey come and collect the tv for a set fee, usually just under £100!They then work out the cost of the repairs and, if you give them the goahead, they deduct the amount paid from the overall repair cost.
I have looked into many of these and, even if you agree to the repairestimate, usually in the region of £300, they never seem willing toguarantee the repair for longer than three months, six months at thevery most!
When you consider that these components cost a matter of pence you can see the value of trying to repair it yourself."
Posted on Jan 27, 2009
  • 13 Answers
SOURCE: No image on my Westinghouse LCM-22w2 monitor
I fixed it! It's the power supply board.
Your problem isn't precisely the same one I had, but I have the feeling you're not saying that this was a problem that gradually got worse over time and now it won't power up.
The Westinghouse LCM 22w2 has bad capacitors on the yellow power supply board. This is a common problem plaguing motherboards and LCD flatpanels that use capacitors from Taiwan. If you know how to solder, or know somebody that can, it's actually a pretty easy fix. Take out the yellow circuit board on the inside, write down the specifications for each of the capacitors (the cylindrical things) go to the electronics supply store and get the replacement capacitors. You can go over the voltage specification (not under), but keep the capacitance value matching. Replace one at a time. Go to www.badcaps.net for advice, tutorials and training on doing this. *You really should replace all the capacitors*, but the very large one next to the power plug I did leave on the board because I couldn't find a match. To my delight, the white screen of death went away and it was working as new!
I saved a ton of money fixing this, it's definitely worth learning how to solder to do this.
www.ctcco.com for professional hosting solutions
Posted on Apr 09, 2009
SOURCE: bottom left lights. when i turn on tv red light
bottom left lights. when i turn on tv red light flashes what does mean
Posted on Jan 04, 2010
  • 453 Answers
SOURCE: My tv will not come on. It flahses red 7 times.
u have 2 bad capacitor on power supply , they are very small ,
Posted on Apr 15, 2010
toolkits
  • 1099 Answers
SOURCE: LG TV won't turn on. Power light flashes red/green.
Power supply board just die.It can be dead at anytime.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on May 31, 2010
Testimonial: "good advice"
HP5066 flickering
Return it to the dumpster. It is a lost cause.
May 03, 2017 | Televison & Video
Driver download
Most Liquid video tv's and indeed most TV's these days use a RCA power cord. They are available cheaply online and in some dollar stores. You may already have one you can use to test the tv with as desktops use them and some laptops use them as well.
Jul 17, 2013 | Liquid Video L17LCD2 17" Flat Panel LCD...
Hello!! We have a Liquidvideo Model #1611008. Everything was fine....and this morning we turned it on. There is voice available, but the image comes on for 1-2 seconds, and then goes BLACK. This is...
Common failures in the LCD monitors are due to bad DC filter caps in the power supply section, that will be the first place to check.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find
Oct 02, 2010 | Liquid Video Computers & Internet
How do i hook up a nintendo to my tv which cords go where and can someone walk me through it
Round peg into the round hole. Red peg on the red slot. etc. If the wire from the nintendo doesn't fit the slot on the tv then you're in the wrong slot. if the wire from the nintendo fits the slot on the tv (and is the same color if you are using red/white/yellow rca cables) then you're good. here's a hint on connection types (you will not mix): 1. RCA (red/white/yellow round connectors) Red=right audio sound White=left audio sound Yellow=video connect to the slots that look like they want some. 2. Coaxial (stiff cable with a pinner poking out of the end -- same cable that connects you to cable tv) just hook it up by itself; it carries audio and video. 3. Component (red/green/blue)(red/white) two 'bundles' red=red component of video green=green component of video blue=blue component of video red=right audio white=left audio 4. VGA + (red/white) VGA=video (computer monitor cable) red=right audio white=left audio 5. HDMI (flat hdmi cable. you spent $30 on this 3 foot ****) HDMI=audio and video 6. hugs and kisses hugs=video kisses=audio (both sides)
Jul 15, 2009 | Video Game Consoles & Games
1440x900 Monitor seems to think it is a 1680x1050 screen @ >19"?
Try reinstalling the video driver (Control Panel - System - Device Drivers - Video ... ) Good luck
Jun 13, 2009 | ViewSonic VA1930WM LCD Monitor
Red spots
what you can do is take off the back pannel and there is a cord on the top of the board that looks like a computer board, there are many boards in the TV but the one I am talking about is twords the bottom where the video jacks plug in to the TV. Ok once you have located the pannel there is a cord on the top kinda tword the right side, it is many wires inside a black covering. What you need to do is just simply unplug it and plug it back in, do this as many times to try to get it to work. If that doesn;t work you can replace the cord and if that doesn't work then the screen is out and would cost WAY too much to fix, you could buy you a new name brand TV.
Sep 23, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Spilled Liquid
sorry now way to fix it you must change the monitor
Jul 28, 2008 | Acer WXGA AL1916WASD (Silver) LCD Monitor
Accidently locked tv
gonk,
Sorry but you're going to have to be a bit more specific than that.. What kind of Tv is it, what model number, is it the original remote, do you have an otherwise good pic and sound, do functions (vol, ch, power) on the Tv work???
Bill
Dec 11, 2007 | RCA 20F514TD 20" TV
Dvd/vcr combo hookup
your audio video cable is probably plug into the wrong places the way that it goes is this with the dvd player on the right hand side you will see video the yellow cord is supposed to be up at the top where it is color coded at the bottom on the left hand side you will see audio for the left it is white the right hand side it is red for the television it is audio for this you put the red, and white cable at the bottom on the left hand side for the video it is just the yellow cable it is supposed to have three cables in a row at the bottom of the television
Aug 08, 2007 | Symphonic WF803 DVD Player/VCR
Televison & Video Logo
185 people viewed this question
Top Televison & Video Experts
