Question about EliteGroup P4M800-M7 Motherboard
Frontpanel sound Recently got me a frontpanel for headphones, but when i want to connect them i have a problem with the internal jumpers on the motherboard. When i remove the jumpers to connect front panel, i don't have any sound anymore when i connect boxes on the backside.
  • 4 Answers
By default, the pins labeled LINE OUT_R/BLINE_OUT_R and the pins LINE OUT_L/BLINE_OUT_L are shortened with jumper caps. You should remove the caps ONLY when you are connecting the front audio cable. So, if you are going to use the back panel, you should short the pins mentioned earlier. You cannot use the back panel and the front panel at the same time. If you want to use your headphones using the back panel, short the mentioned pins and connect your headphones to the green header of your back panel audio. If you want to use the front panel, take off the jumper caps and connect the front panel cable. Remember, if you connect the front panel audio cable, you won't be able to use the back panel. If you are going to use the back panel, don't forget to return the jumper caps. Usually the 5-6 and 9-10 pins. Hope this helps.
Posted on Nov 18, 2007
I have a franke Saphira it says decalcify needed what buttons do i press and is there a sequence how to press them .
first you need to shut down the machine by pressing the on/off button in the frontpanel. now you can press the decalcify-button on the frontpanel. Follow instructions on display.
Mar 22, 2017 | Franke Coffee Makers & Espresso Machines
Kenwood kdc-u356 say protect
behind the frontpanel is reset button. take t frontpanel off, push the reset button.
Mar 06, 2016 | Kenwood Car Audio & Video
E15 showing on Bosch dishwasher. How to clear?
The overflow switch has been activated.
It means that its a internal leakage.
Unscrew the side panels or frontpanel under the door and dry out the water with a towel and test the machine.
Check for leakage.
Feb 07, 2016 | Bosch Dishwashers
Front audio
Hello try to download the manual here:
By selecting your windows system.
Open the manual folder, and download the manual.
You will need adobe reader, to read the content.
Check also the sound settings in the bios.
The audio cable must be connected to here.
Good luck
Mar 31, 2013 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Dear sir...greetings... i have a ibm fw82801db motherboard which is working fine... the main problem what i am facing is i have a 20 pin front panel jack like FDD jack as unable to connect my front...
Because of the many configuration of motherboard, I can possibly know how to help you with this problem without the keyboard in front of me. The best advice to you is to go back to the manual to find the proper connection of those jumpers.
Feb 26, 2011 | Intel Desktop Board D845HV Motherboard
How to connect front panel plugs
You are working inside the Computer, before you connect the front panel to the motherboard, don't forget to unplug or Power Off.
To see how to connect it, here is some link for information:
Please rate if i am helpful to you.
Thank you.
Sep 01, 2009 | Office Equipment & Supplies
Monitor menu
that's a control issue with the may need to get and reinstall the video drivers for that one...check this link, follow hp icon to model number, for computer, and look for video drivers.
Mar 16, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Dell Dimension 4500
connect this cable to socket, which is in left right corner of motherboard (its on the left side of the bottom pci)
Feb 26, 2008 | Dell Dimension 4500 PC Desktop
Front panel connections
The manual shows the correct pin outs, and can be downloaded here:
Jan 26, 2008 | MSI 915P Neo2 Platinum Motherboard
Open Questions:
See all EliteGroup P4M800-M7 Motherboard Questions
EliteGroup P4M800-M7 Motherboard Logo
800 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
