Question about Brother LS-1217 Mechanical Sewing Machine
Fabric won't feed forward
My machine, a Singer from about 20 years ago, suddenly stopped working while I was basting.  I was basting some interfacing into a bodice just fine. When I began another section, the fabric wouldn't feed forward. I cleaned the lint from inside, underneath, etc. with still no luck.  I even tried a different needle and rewound a new bobbin.   Please help!
    Sniper:
  • 52 Answers
Do the feed dogs move up and down? If they dont the plastic gear underenth has probably broken you can take this to a singer dealer and have them replace the plastic gear with a nylon one which would last longer than that did
Posted on Jul 16, 2009
I have a singer model 513. It suddenly stopped moving the fabric forward while sewing....the little "teeth" are not moving, is this a belt issue or something else?
The feed dogs are not pulling the fabric through the machine properly. There are gears and arms that make that all happen.
These parts can break. Look for a switch or setting that lowers the feed dogs for free motion sewing. Please let a professional trained technician make any repairs or adjustments.
Cheers,
Embroidery Services
San Diego, CA
Sep 14, 2017 | Singer Sewing Machines
Singer 8763 Needle Won't Go Up and Down
read the user manual and if you do not get anything from the trouble shooting section take it back for a warranty check as something may have moved from the material jam
Apr 12, 2017 | Singer 8763 Curvy
Fabric won't feed threw machine
it sounds like the feed dogs are not working, can you see them in the
needle plate area? you should be able to see them and feel them
with your finger. what is the name and model of the sewing machine?
Nov 28, 2012 | Singer Featherweight 132Q Mechanical...
My fabric dosnt move foward or back wards with the petal or manually ..
if the fabric won't move then there is something wrong with the
feed dogs, check in the needle plate to see if you can see the feed
dogs. you should be able to see them & touch them with your finger
since they are not moving the fabric it would be a good idea to
have the machine checked
I'm putting a link for a free manual for the machine, you can check
in the manual to see if it show where the feed dog lever is on the
machine, if it doesn't show a lever, or the lever is not responding to
movement then the machine needs to be checked to see what's
wrong.
http://www.singerco.com/uploads/download/463_2932_esf.pdf
Sep 04, 2012 | Singer 2932 Mechanical Sewing Machine
Fabric will not feed
DO NOT pull your fabric through. Under the face plate you will find the feed dogs. They are two rows of "textured" metal things that grab the fabric from underneath and pull it back. This pulls your fabric through. Look in your manual for info on the feed dogs. They are adjustable. You need to raise the feed dogs to a higher position.
Aug 12, 2012 | Singer Sewing Machines
The machine won't stitch anything...
check the feed dogs in the needle plate area to see if there up,
if you can see them & touch them with your finger, I'm putting in a link
for a free manual, so you can see where the lever is to the feed dogs, just
incase they are not up. if they are up then they may need to be checked
to see why they aren't moving the fabric.
http://www.singerco.com/uploads/download/1199_8770-efs.pdf
Jun 27, 2012 | Singer Curvy 8770 Electronic Sewing...
Won't sew, the fabric stays in one spot
is the problem the fabric is not moving forward but staying in one spot? which would mean the feeddogs need to be checked to see what position there in --up for sewing---down for darning
or the thread is not feeding into the machine?
Feb 10, 2012 | Janome DC3050 Computerized Sewing Machine
How do I set for basting
Some compuerised machines will have a basting stitch programmed in, it may have a symbol like a dot then a long dash then another dot. This will give you a decent spaced basting stitch. On mechanical machines sometimes you can get a basting needle plate - you set up for the longest widest zigzag stitch and the tube on the plate makes one side of the zig not catch so you get a long straight stitch.
But if you are joining silky fine fabrics together, then needle and length of thread doubled is still the best way, takes a little longer but the fabrics won't creep and slip.
Oct 23, 2011 | Brother PS-1250 Pacesetter
Why would my Singer 6235 not feed the fabic:
h! there,
fabric moves forward when machine run due to movement of feed dogs,feed dog has a teeth, when your foot presser goes down attached to fabrics the pressure hold the fabric between pressure foot and feed dogs that why when machine run feed dogs pushed fabric when recieved stitch.try to check adjustment of feed dogs it maybe set at rest or neutral.reset it to upward towards needle.check also bobbins thread if accumulation was build up under feed dogs.regard and have a nice day.
Apr 03, 2009 | Singer 118 Mechanical Sewing Machine
Brother LS-1217 Mechanical Sewing Machine Logo
251 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
