Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
I have the same problem with the green verticle lines.
I have the same proble with the green verticle lines. When I disconnect the power source, wait a few minutes, re-connect the source, the picture clears up. A technician looked at my tv (Samsung-HLR5067W) and stated that I needed a degital board (BP 94-02084A), and that the part is no longer available. I called J& J Parts 1-800--627-4368, and the representative stated that the part is on back order, and was still being made, and would be available for order on the 29th of this month. I don't understand how this company allow mix information going out to the customers - confusing and poor business practice.
  • 691 Answers
Most older projectors are going to be harder to find parts, soon the flat screen price will drop and everyone will be able to afford them and soon projector will be absolete just like the old computers monitor now its all flat screen, we went from 8 tracks to CD and now to memories chips. that person you spoke to may have a bad day who knows. If you need help getting the parts and have dificulty locating one and you already know the problems and have the part number, you can contact your local TV repair shop and they will more access to getting those parts, keep in mind they do those all day long and they charge you a bit more but it sure beat gitting all the head ace locating those parts and getting the run around on the phone..Good luck.
Posted on Jul 16, 2009
No picture on acer 19inch monitor
Disconnect all cables including power.
Wait 5 minutes.
Connect ONLY the power cable.
Does it come on?
If not, take it to a shop.
If it comes on the the source cable or video card is the issue.
Apr 05, 2014 | Acer Computers & Internet
When i turn on my t.v it shuts off....it does turn on and a green program timer light flashes. then it shuts off immediately. cant keep the t.v on to figure this proble out.
have you try to turn off the timer in the tv menu
or you van try to disconnect from power line
then reconnected after a wile that should reset the set.....
hope that help you
Mar 29, 2010 | Philips Magnavox 55P9271 55" Rear...
Replaced power supply but still have no video just green and white lines but i do have audio what do i do
still the power supply voltage out puts be checked. inaddition to that check the line transformer in put voltages.
the problem is that verticle and horizontal speeds are match to the erquirements of the tv.
thanks for asking fixya.
Feb 12, 2010 | Sanyo Televison & Video
Green verticle line on right side of image
Your color convergence is out of adjustment. You can adjust yourself with a service manual telling you how, or take it to service shop and pay about $400.
Jan 17, 2010 | Sanyo PLV 60HT Multimedia Projector
The verticle lines roll ...what causes that to happen
Ground loops. Its a power issue. A very common issue and difficult to troubleshoot. Try disconnecting one source at a time. Usually has something to do with an improperly grounded cable line, cheap lighting dimmer, or bad electrical.
Dec 01, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Verticle black bars
Check the connections on the flat cables to the screen. Be sure first to disconnect the power supply from the x and y sustain boards before you disconnect any of the flat cables.you will burn the cables from the stored energy in the power supply, also check cables on c boards at bottom of screen. If this does not fix probably bad panel.
Apr 24, 2009 | Televison & Video
Verticle black lines on mitsubishi dlp tv screen
Press the Menu Key on your remote. If your menu shows clearly on the screen, then there is a problem with your source.
Mar 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Sylvania 6427FF TV displays wavy verticle lines at top of the screen.
I would suspect defective filter capacitors in the sweep circuits as well as the power supply source voltages.
Aug 07, 2007 | Sylvania 6427FF TV
Similar Problem with Verticle Lines
sounds like a loose cable inside the set, if not it looks like a logic main board
Sep 04, 2006 | Samsung LTN1535 15 in. HD-Ready LCD...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
116 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
