Question about Dell Dimension 4600 PC Desktop
I have a Dell Dimension E310; When I boot up, my
My system, it goes to white on black, and instructs to hit key F1 to continue, and F2 too setup security utility. I can enter home page , but I cannot enter any secure sites. "Puzzled" I need some help.
Gn33d
  • Dick
    Dick May 11, 2010
    We need more information. Is your system a Dimension 4600 (which is where you posted it) or is it an E310? Are you able to boot into Windows and get the message when attempting to run a certain program, or is this happening during or after the POST?
Sounds like your operating system (Microsoft Windows Media Center Edition?) is corrupt or damaged. Did you purchase the restore CD? If not, you can get it from Dell for about $10 - follow the instructions that come with it. If that doesn't work, you may need to replace the hard drive. Depending on how long you have owned it and whether you have the extended warranty, the repair may be covered.
Posted on Jul 16, 2009
Help -- CPU Fan Failure bypass or pinout?
Yep I have a link below you can order the correct fan from.
http://store.cwc-group.com/y4574.html
I had the same issue here, we have 20 offices all running Dells. These fans seem to be used only on dell systems.
Feb 23, 2012 | Dell Dimension E310 PC Desktop
This problem just started yesterday.When booting up,the first screen with the white bar goes across,then it goes to a black screen and beeps once with the message,hit F1 to reboot or F2 to setup menu,but...
restart your computer press F8 then click restore the directory setting this will restore all the directory in the system and the system will reload properly if this doesn't work you will have to re install the OS
Jun 28, 2011 | Dell OptiPlex GX110 PC Desktop
My dell dimensions e310 is having problems.. when i power it on it says Drive 1 not found: Serial ATA, SATA-2 Strike F1 key to continue, F2 to run setup.. When i press F1 it says NTLDR is missing... I...
1 . Insert your Windows installation CD. Reboot the computer. Your computer detects the boot media in your drive and asks you to press any key to boot to the Windows installation disk. Press the space bar on your keyboard. A blue installation window is shown.
2 . Press the "R" key to start the Recovery Console process. Press the "1" key to open the command line console. You are prompted for the administrator password. Enter it into the console and press "Enter."
3 . Type the following text into the command line:
copy e:\i386\ntldr c:
4 . Replace "e" with the drive letter for your CD-ROM drive. This command copies the NTLDR file from your installation CD to your hard drive
5 . Remove the CD from the drive and reboot the computer again. The Windows operating system should successfully boot.
Thanks for using Fixya.
Feb 03, 2011 | Dell Dimension 4600 PC Desktop
My computer starts on black screen... drive 1 not found: serial ATA, SATA-2.. strike the F1 to continue, F2 to run.. if i press F1 it says NTLDR is missing what di i do? I have the operating sys. disk..
  • Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
  • Click to select any options that are required to start the computer from the CD drive if you are prompted.
  • When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  • Press 1 (One) to select windows XP and then hit enter.
  • When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
  • At the command prompt, start typing
COPY D:\i386\ntldr C:\ (Considering that D is your CD Rom Drive)
COPY D:\i386\ntdetect C:\ (a file that may also be missing)
Then rebuild the boot configuration boot.ini file by
Attrib -H -R -S C:\boot.ini (if not found skip the next line)
DEL C:\boot.ini
BootCfg /Rebuild
Feb 03, 2011 | Dell Dimension E310 PC Desktop
My dell d2400 will not boot up, I get the primary drive 1 not found, strike f1 to continue, f2 to run the setup utility
when the operating systems was setup on your hard drive, the incorrect partition was set. this causes that screen to appear. more often people will choose that way so that you may have full advantage od a smaller hard drive. this will not affect the performance of the system in any way. the fact that you have to hit the f1 key on startup is just an inconvenience.
Jan 22, 2011 | Dell Dimension 2400 PC Desktop
Heloo sir i have a problem with my dell 170l when i start it it shows ''strike F1 to continue, F2 to run the setup utility'' when i click f1 it show ''f1 to retry boot,f2 for setup utility'' plz help me...
Hit F2,look in setup to see if the hard drive is recognized and check that the date and time are correct.
Then hit esc key. it will ask if you want to save changes, click yes. It should boot and probably ask you to hit F1 or F2 again., unless there is a problem with the CMOS battery, which may need to be replaced.
If you hit F1 to continue, it will boot, but your time and date will be off.
Dec 17, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 4700 desktop. Turn computer on, go...
try to disconnect, stretch the master cable of Hard drive and then connect it.
May 20, 2010 | Dell Dimension 4700 PC Desktop
Dell Dimension 4600 PC Desktop Logo
151 people viewed this question
Alun Cox
