Question about SimpleTech 160GB USB 2.0 / FireWire External Open Box (STIU2F36160OBB1) Hard Drive
My simpldrive deluxe external harddrive 160gb doen't power on any more...
I used the harddrive with a pc, a view months later I bought a mac. so I wanted to back up my mac on the harddrive, but to do that I had first do format the harddrive for the macsystem, I never got that far, because now the harddrive doesen't power on and doesen't even show any lights. what can I do
  • Zulenzo Apr 02, 2008
    I too have a problem with my simpletech 160 GB external storage. I purchased it a few months ago to transfer data from my old Toshiba laptop to my new Macbook. It worked very well. I left data on the storage device because I did not want to bog down my Macbook. I called Simpletech and they said it was a bad cable so they sent me one. It did not fix the problem, I called them back and they said that I needed to go and buy an adaptor for more power and supplied me with the spec so i would make sure I got the proper adaptor. This too did not work so I called them back and they said it had a 3 year warranty and to return it and they would replace it. However there is data on it I cannot retrieve, is there a way to get this data without going to an expensive recovery place? Is there a trick I can do myself? By the way Simpletech did say that the warranty is still good even if the labels are torn or removed. What I needed to do was put a note in the package and state that the labels were torn for Data recovery
    Problem Solver:
  • 6 Answers
Is it a 3.5" or 2.5" drive?
If its a 3.5" the first thing I'd check is the fuse in the plug for the power supply (if you're in the UK)?
If changing the fuse doesn't work it could be a problem with the power pack within the external HDD. Is it under warranty? You my be able to get it repaired or a new one (Don't forget, if you open up the fasia of the hard drive you will void the warranty). I assume you're not worried about data on the drive as you are happy to format it. If you are worried about data and it isn't under warranty/garantee I can tell you how to get the data off if you need me to?
Hope this helps.
Posted on Nov 19, 2007
IMac won't read Imation 160GB Apollo 2.5
Mac's won't read windows format disc, even if it's capable of reading the files wich I believe Newer Mac Operating Systems CAN DO, it can not read the file SYSTEM used to place them on the disc. You need a third computer. Put the files on a nother computer or two if you need the room or on another media or pocket drive. Use a program that VERIFIES the were moved without errors while copying them, the use the Mac to format the now empty disc drive and download Mac Pooler, or File Stuffer, and copy the files back onto the disc. Now the Mac will be able to read the drive they're on.
Feb 16, 2014 | Imation 160GB Apollo 2.5" Portable USB 2.0...
My WD External Hard Drive for Mac will not power up? Is there anything I can do without paying for Data Recovery? I've only had it about 4 months.
you can purchased an external usb case from I would first take the hard drive out so you can identify whether you need a SATA to usb hard drive or IDE to usb harddrive. Connect the hard drive in and see if it will power up.
Feb 18, 2012 | Computers & Internet
I need to know the power rating for a Maxtor 160GB external Hard Drive for use with a Yamaha PSRs-900 keyboard. Yamaha requires the rating to be not greater than 500-600mA
The Maxtor STM901601EHD301-RK is part of the Maxtor Basics Portable family.
It uses a 2.5 inch Internal harddrive inside. (2 and a half inches across the Width. Same size used for a laptop. Desktop's use 3.5)
It connects with a USB Style A male plug, via the USB cable.
It's has a 160GB storage capacity, has an 8MB Buffer, (Cache), and an External Data Transfer Rate of 60 MegaBytes per Second.
Other than that, I find no more information from Seagate, (Seagate bought out Maxtor, and has the data base for Maxtor products)
What I do know in reference to your question.
I know that the USB 2.0 technology uses 5 Volts DC. The Positive pin on the USB plug will support up to 5 Volts.
[Viewing a USB-A style plug, view it with the white plastic spacer at the bottom. Open part at top. The Positive pin is all the way to the right. The Negative pin all the way to the left. The Data + pin is on the left next to the Negative pin. The Data - pin is on the right, next to the Positive pin]
The Maximum current draw is 500 mA for a USB 2.0 port.
[ Current is rated in Amperes, or Amp's. You are looking at Millionths of an Amp.
Milliamp, or abbreviated as mA]
This would lead me to believe that the Maxtor Basics Portable external harddrives will not use more than 500 Milliamp's.
However I do not feel comfortable, telling you that it is okay to use your Maxtor STM901601EHD301-RK, on your Yamaha PSR2-900 keyboard. Would hate to be mistaken, and have you burn out the finals of your keyboard.
I do feel comfortable with the following suggestion.
What about transferring as much data as you can from the Maxtor Basics Portable, to a USB thumb drive? They have large thumb drives now, and hold a lot of data.
Most programs will fit on a large USB thumb drive.
Or am I missing the point somewhere?
Oct 20, 2009 | Seagate Maxtor OneTouch 4 Mini 120GB...
Maxtor basics 160gb portable hard drive is showing error performi
go to my computer p[roperty then hardware -> device amnager then uninstall usb drivers from it then install aagain.
then connect your harddisk then it found.
Jun 23, 2009 | Fantom Drives Titanium II (TFD160U2) 160...
I m having 250 gb hdd & i wants to make that dos bootable & xp bootable the DM I M having only support 160gb hdd that is not showing above that if u have dm for that can u arrange for me
dude your motherboard does not support harddrives larger than 160GB buy an external one but if you want to use that go ahead and use it but connected in slave if your using another harddrive as master where windows is installed or in master if you want just that hraddrive
Jan 27, 2009 | Computers & Internet
Simple Tech 160 GB external harddrive
Go into your disk utility on the mac, select your external, and erase it.. then it should find it. :) Only thing is now I can't get windows to find it when I take it to school! Oh well :D
Oct 23, 2008 | SimpleTech Signature Mini 160GB External...
Open the drive and see whats burns, if the case circut is burnt put the driv in a new case. the the harddrive is burnt your out of luck.
Sep 05, 2008 | SimpleTech SimpleDrive 160 GB External USB...
Simpletech hard drive
Your desktop usb compatibility is not supported your 160GB. The only way to attach you 160GB is to make it secondary partition to your primary drive by opening the CPU and attach it to your IDE cable.
Don't force yourself if you cannot do it by yourself just leave it to the expert. Probable cause to damage your hard drive if it is not installed properly.
Please rate me solved if you like my solution.
Best regards,
Oct 29, 2007 | SimpleTech 160GB USB 2.0 / FireWire...
Computers & Internet Logo
163 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
