Tablets & eReaders Logo
Sherri Phillips Posted on Mar 31, 2016
How do i access my pictures on my sd card? When i had the sd card on my android phone it was under GALLERY. The tablet doesnt have this.
Smart_Jet
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Mar 31, 2016
Smart_Jet
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
568
Points
6
What tablet you have?
There are various media programs that can help you. Such as as Photo or Viewer.
Testimonial: "I'm sorry I have a next book Aries 8"
  • Sherri Phillips
    Sherri Phillips Mar 31, 2016
    I'm sorry, I have the next book aries 8
2helpful
2answers
How do I print off a Sd card, from my tablet?
Hello, Glenn -
First you need a WiFi printer.
Then, you need to have the printer driver software installed on your tablet.
Then, follow these steps:
-- Open the file you'd like to print
-- Tap the menu button in the top right of your screen
-- Tap Print
-- Tap the drop-down arrow.
-- Tap the printer you'd like to print from
-- Tap the print button
Best wishes.
How to get my pictures and videos off my Android phones SD CARD to my nextbook flexx10 by putting the SD card into the laptop
The Flexx10 has a micro SD slot, the SD card is about the size of your finger nail. If your Android phone also has a micro SD card you just remove it from the phone and plug it into the Flexx10. Then just transfer the pictures from the SD card to the tablets internal hard drive. When complete put the SD card back in the phone. If the SD card in your phone is the standard size it obviously won't fit the Flexx10. You then have the choice of either using Bluetooth to transfer the pictures between devices or buying a USB SD Card converter and plugging that in your FLexx10 with the Android SD card mounted in the converter.
My nexus 7 i cannot retrieve photos from my gallery ?
To fix this problem u can swipe left to go to the next picture or in the gallery. Another thing u could do is go to you setting den go to clear data. But to do that you have to have your pictures saved to your SD card (if u have one)
1helpful
How to delete or remove all photos stored in samsung galaxy tablet 3 gallery?
Although I do not have a Galaxy Tablet 3, I own a Samsung Galaxy S3 phone and I believe both might use the same technique.
There are two ways to erase the photos from the gallery. I generally use the first one, using a computer although you may prefer the second one that works directly in the tablet.
In general, when you connect an Android device that has a camera to a computer, it will display in the Windows Explorer an Icon with the name of the device, if Windows has the right drivers for your device installed. At the same time, an icon of a USB connection will be shown in the device's screen top bar.
If you click on your device's icon at the computer, you may find one or two folders (in general, "Card" and "Phone" in cell phones" and "Card" and "Tablet" for tablets). The "Card" folder appears if you have an SD card inserted in your device. Depending on where you set up your tablet to store the photos, inside those two folder you will find another folder called DCIM (that stands for Digital Camera IMages). Check on both to locate where your photos are. Then, select the ones you want to erase or select them all pressing CTRL + A and then press DELETE on your keyboard.
The other way is acting on your tablet. Touch the GALLERY icon to open the Gallery app. If you have more than one folder in your gallery, touch on the folder you want to erase the photos, to select it. If you have only your Camera folder, touch and keep you finger touching any of the photos for around two seconds. The photo will be selected with a green mark and a rectangle will appear at the top, close to the Gallery icon, indicating "1 selected". Touch this rectangle and the option to either "Select all" or "Unselect all" will appear. Selecting all photos will turn them all marked. Then, touch the "Trash can" (delete) icon and you will be asked if you want to delete all pictures. Touch OK and they are all gone! See images 1 and 2 attached to this note.
Hope you may find this information helpful!
Regards,
Miguel L. Martins
I uploaded a bunch of photos to TIF card on my Zeepad7.0 how do I bring them up so I can view them on Android phone I have gallery but on Zeepad I don't
Download a file manager app from the google play store. Then use it to locate a folder named SD, or 'External' look in there for the pictures.
1helpful
Forgot login for Craig 7" Android tablet
how do i do a hard reset on a craig cmp741d 7-in touchscreen 4.0 android tablet
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
