The turnaround bobbles and shakes in operation. The diameter of the glass turnaround is 9 & 5/8 inches, and might be too large. ? Did they put the wrong size turntable in? Do you know what the specs call for in this Model?
SOURCE: Microwave turntable.
Is that the only thing that doesn't work? If so it could be a coupler or a belt, possibly the motor it self.
SOURCE: i have a Kenmore Microwave Model #363.62709200. I
If you go to www.appliancepartspros.com and do a model search you can find what you are looking for.
SOURCE: F-9 pops up - microwave stops after 5 seconds.
Hello :
The F-9 error code indicates a defective control board, inverter or line voltage too high .
WARNING : A microwave is capable to give you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
good luck .
please don't forget to rate !
SOURCE: I need to buy a new glass turntable for my Kenmore
The correct part # is 3390W1G006.
You can contact Martin Microwave Inc. @ 1-877-894-0035. They carry the tray in stock, but it's not listed on their website (www.microwaveglasstrays.com) .
SOURCE: I have a Kenmore microwave model 721.61820100 and
The part you need is the turntable support. Sears shows the part on their parts site, and here's another source that I use. The support just slides onto the motor shaft through the hole in the bottom of the oven.
Capacity
Oven Capacity (cu. ft.): 1.6
Features
Wattage (IEC-705 Test Procedure): 1000
Cooking System: CircuWaveâ„¢
Plus
Power Levels: 10
Style: Over-The-Range
Clock: Plus AM/PM
pad
Electronic Scrolling Digital Display: Yes
Electronic Touch Controls: Yes
Kitchen Timer/Timer (On/Off): No/Yes
Variable Scroll Speed: 5
speeds (sub-pad w/ AM/PM)
SmartControl System - Concurrent Programming: Yes
SmartControl System - Help Pad: Yes
Beverage (Convenience): Yes
Cook (Convenience): 9
Codes
Popcorn (Convenience): Yes
Reheat (Convenience): 6
codes
Add 30 Seconds: Instant-On
Child Lock: Yes
Cooking Complete Reminder: Yes
Defrost Type: Auto
& Time
Delay Start: Yes
Display On/Off: sub-pad
w/ zero
Express Cook: Instant-on
1-6
Reminder (24 hr): Yes
Time Cook: I
& II
Time Preference: Control
Enhancement (1/9)
Turntable: Glass
Turntable On/Off: Yes
Turntable Size (in.): 13-1/2
Cooktop Lighting: Bright/Night/Off
Night Light: Auto
Rack Type: Wire
Oven Rack
Sound Volume Control: 4
levels
Easy Mount Installation: Yes
Exhaust Fan: 2-Speed
Appearance
Case Color: Black
Color Appearance: Stainless
Steel
Door Color: Black/Stainless
Steel
Handle: Designer-Style
Weight And Dimensions
Approximate Shipping Weight: 63
lb
Overall Depth: 15
5/8"
Overall Height: 16
3/16"
Overall Width: 29
7/8"
Cavity (W x H x D): 20
31/32" x 9 3/8" x 14 3/16"
Power/Ratings
Electrical Input - 120V Amperage: 15
Electrical Input - 120V Watts: 1480
Frequency (MHz): 2450
