If you are talking about an aftermarket alarm system you will most likely need to either get ahold of the place that originally installed it, or another stereo/ vehicle security shop to have your issue looked at. Most dealerships refuse to work on not factory issues, and most mechanic shops are not electronics experts.
SOURCE: key fob will not undo
If you don't have one that works for the vehicle now, you'll have to take it to your local dealer to have it programmed to the vehicle. Some will charge for this, some will do it at no charge.
If you do have a remote that is programmed and working for the vehicle, then the following steps will allow you to program another remote:
1. Enter vehicle and close all doors.
2. Put seatbelt on (or clip it into the buckle) to shut the warning buzzer off.
3. Put key in ignition, turn to run position but don't start it.
4. Press and hold the unlock button on the working key fob and hold for 4 seconds, then also press the panic button.
5. Release both buttons and you should hear a single chime to indicate it is in program mode. You have 30 seconds after the chime to program any additional remotes you want to program.
6. Press and release both the unlock and lock buttons simultaneously on the remote you are programming. You should hear another single chime.
7. Within 4 seconds after hearing the chime, press either lock or unlock button on remote that you are programming.
SOURCE: alarm immobillizer
The alarm systems on land rovers are quite tempramental. They work on radio frequencies. If you park next to a radio antenna like they have at post/ telecommunications offices. Then the radio waves they send out can interfere with your cars system, making it think it has been attempted to be broken into, and so immobilises. You should have a 4 digit code called the EKA code. You must have this to knock off the immobilser to start the car. The car must be locked completely, all windows shut and then enter the EKA code using your key.
Hope this helps
SOURCE: Jag S-Type -intermitent fault where the remote fob does not work
This does not sound like a fob fault - but a locking control module fault , either in the hardware or software of the unit. Get it checked at a Jaguar dealers. When unlocking using the key - as soon as the door is opened you should hear a chime sounding inside the car - this is a timer counting down to sounding the alarm. If you put your key in the ignition as soon as you open the door the alarm should not go off and the chime should stop. If it does not this again points to a fault in the locking controller.
hope this helps - good luck.
SOURCE: kia rio key fob power lock/alarm problem
if the lights flash when you hit the panic button but the horn does not beep, then the alarm horn is bad. Vehicle has a second horn just for the alarm
SOURCE: when we use our key fob to lock the doors, i know
You should be able to just unlock the door with the key, and even if the alarm is still going of try to start it the key should override the alarm.
