Rheem thermostat wiring diagram - Heating & Cooling
  • 614 Answers
The only thing different about a Rheem unit is on the heat pump they use B instead of O. RYGWC all the same.Rus
Posted on Jul 16, 2009
2 Suggested Answers
  • 51 Answers
SOURCE: wiring diagram for Rheem rpka-31 jaz heatpump
TURN THE POWER OFF TO THE UNIT. TAKE THE BACK PANEL OF OF THE HEAT PUMP AND LOOK FOR A SQUARE PLASTIC BAG FASTENED TO THE INSIDE OF THE UNIT, IT MAY BE LOCATED BY THE CONTACTS AND SYSTEM WIRING OR ON THE PANEL ITSELF. REMOVE THE PAPER FROM THE PLASTIC AND THIS SHOULD CONTAIN YOUR WIRING DIAGRAM. ALSO LOOK ON THE BACK OF THE PANEL ITSELF FOR THE DIAGRAM. SOMETIMES THE DIGRAM IS PRINTED THERE.
Posted on Apr 13, 2010
I need to have wireing diagram for thermostat for 30 gal
There is usually one pasted to the back of the access panel cover & some are on the thermostat. Worst case scenario. Go to Lowes or Home Depot, there may be one on the packaging of the replacement thermostats in the plumbing department. Good luck.
Aug 24, 2015 | Rheem Water Heaters
I have a Rheem 82vs50-2. Can this heater's elements be wired continuous for 9.0kw and is there any mfr documention that allows continuous wiring of this heater
You have dual element 240Volt tank-type electric water heater.
You want to change wiring from non-simultaneous to simultaneous.
Copy following link for exact internal wiring diagram, and external wiring change: Remember the wire from breaker box will not support both elements without tripping breaker, so you will need additional 30 amp breaker and 10 gauge wire, or single 50 amp breaker and 6 gauge wire.
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html#simultaneous
http://waterheatertimer.org/Color-codewire2.html
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Sep 23, 2012 | Rheem Water Heaters
Do you have a wiring schematic for a Rheemglas model 81V66DB ser # RH0500408476?
I can't identify that model number, and Rheem does not show that model:
Open following link to help identify water heater:
http://www.rheem.com/Products/tank_water_heaters/gas_water_heaters
Contact Rheem:
http://www.rheem.com/Contact.aspx
Oct 07, 2011 | Water Heaters
Where are the control board fuses for a Rheem RGVH-10EBRJR. Fan will not start at thermosat but will start with thermostat red and green wires jumppered.
Two possible locations, one would be a small glass fuse or automotive type fuse located on the PC board. The second would be in-line of some of the wiring. The wiring diagram will indicate where it is. Make sure you have the proper wires leading up to the thermostat in order to turn the fan on. You will need a minimum of 3 for heating (R, W and G terminals).
Mar 12, 2011 | Heating & Cooling
I have a Rheem Model RHSA-HM3617JA and need a wiring schematic so I can wire in the thermostat
We can get you the wiring diagrams for your Rheem model. Not sure how to attach a PDF to this area, but if you contacted us either by phone or e-mail, we can send it to you via e-mail. You can contact ComfortGurus.com at 866-519-2461 or visit our site and use the "contact us" page to send us an e-mail. We are a full-line Rheem distributor for parts and accessories if you need any parts in the future too. Let us know if we can help.
Oct 18, 2010 | Heating & Cooling
Heating & Cooling Logo
3,418 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
