How to check fuel pressure
With a fuel pressure gauge. If there is a test port called a schraeder valve on the fuel rail on top of the engine, it's easy. If no test port, you have to tee off the fuel line somewhere convenient (like right after the fuel filter) and hook your gauge up there. Hook the gauge up, make sure of no leaking, turn key to on, and read the pressure (it will read the same pressure in the line as at the fuel rail). Check pressure with key on, and then with engine running- if at the specs for your vehicle, it's good. If pressure is below specs, pinch off or pull off the vacuum line to the fuel pressure regulator, and see if pressure raises. If it does, try another pressure regulator. If no change, check the fuel return line for restrictions, check or replace the fuel filter, or suspect a poor performing fuel pump. On MPFI systems the pressure should be about 50 psi, but find the specs for your vehicle.
