Question about Garden
I have an electric hedge trimmer and was using it when all of a sudden it would not cut. All of the parts were working. The motor ran. the blades moved forward and backward, but it would not cut the hedge......?????????? Help!
  • 76 Answers
Hi
sounds like the blades should be sharpen or replaced.
Posted on Jul 16, 2009
I have Bosch hedge trimmer AH15 63-16C which has stopped cutting. It still seems to be working as it should and the cutters moving as normal but suddenly stopped cutting? Just wondering if this is fixable...
This sounds similar to a problem I have with my Bosch AHS 60 24s. The blades are moving but not independantly and therefore not in a cutting action. I took it apart and the bottom blade has slipped off the drive wheel. I put it all back as it should be but as soon as I used it again, the same thing happened. I'm not sure why this is happening, it may be that the motor end of the bottom blade has become slightly bent, so I will be trying to straighten at the weekend. The cost of replacement blades is prohibitive and time for a new hedge trimmer. Has anyone else had this problem and a different solution.
Oct 07, 2013 | Bosch AHS 45-16 Electric Hedge Trimmer
I need a manual for a Ryobi RHT500R Electric Hedge Trimmer 500 Watt - 55cm
I found the manual for the Ryobi hedge trimmer here: fr.ryobitools.eu/local/uploaded/catalog/e_RHT500R-600RL_UM_UK_v1.pdf . The bolts you describe hold the blade to the hedge trimmer's motor. They shouldn't have come loose. However you can check if any of the bolts are loose or have backed out of the motor.
I would suspect either a part of the branch is stuck between the blades. I have one of the small edge trimmer which gets noisy when I get a woody weed stuck in the unit. Unplug the trimmer and look at the blade for some bark stuck between the layers. On each side there are multiple blades that overlap at parts of the cutting cycle.
A parts diagram for the RHT500R is available here: http://www.magic-parts.co.uk/acatalog/Ryobi_RHT500R.php .
II hope this helps.
Aug 23, 2012 | Ryobi Garden
Do I need toil this Remington 22in electric hedge trimmer?
It's always a good idea to oil the blade of a hedge trimmer with WD40 or similar otherwise the sap from branches will eventually build up a coating on the blades and increase friction.
May 11, 2011 | Remington 22-Inch Dual Action Titanium...
My Black and Decker hedge trimmer's blades won't move, but smoke and a burning smell comes from the motor. Can it be fixed? How much would it cost?
Your blades are stuck together.
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
May 30, 2010 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
Do I ever need to sharpen? If I do, how?
Hey i found this for you i might help. Click on the link at the bottom!!
How to Sharpen a Black and Decker Hedge Hog sharpen-black-decker-hedge-hog-800x800.jpg Maintaining the sharpness of electric timmers can made landscape trimming easier with beautiful results. Electric hedge trimmers make trimming hedges and bushes easier and quicker than using manual hand-powered trimmers. Electric trimmers, the most popular type in the U.S., cost less and require less maintenance than gasoline-powered models. Electric trimmers are used most often by homeowners with the Black and Decker Hedge Hog series being very popular. While they are not premium products, electric trimmers like the Black and Decker Hedge Hog trimmer can keep trimming reliably for years with proper maintenance, including sharpening the blade's teeth.
Difficulty: Moderately Easy Instructions Things You'll Need
  • Work table
  • Two medium size clamps
  • Dremel tool or similar hand-held multi-purpose tool
  • Grinding wheel attachment for hand-held tool.
  • Dremel 971 (or similar) aluminum oxide grinding sharpening stone with a tip small enough to cover the flat facet of a Hedge Hog blade tooth
    • 1 Unplug the electric trimmer before trying to sharpen the teeth.
    • 2 Clamp the electric trimmer to the work table using two clamps if necessary so the Hedge Hog is firmly held down with the blade teeth accessible over the edge of the work table.
    • 3 Insert and secure grinding tip in hand-held multi-purpose tool.
    • 4 Maneuver the grinding tip so it is perpendicular to the facet of the Hedge Hog tooth.
    • 5 Sharpen teeth in one direction, being careful to try and maintain the same cutting edge angle on the sharpened tooth of no less than 35 degrees.
    • 6 Make same number of grinding passes/grind the same length of time a few seconds on each tooth.
Tips & Warnings
  • This task should take about 15 minutes.
  • Keep a light touch; too much force can break the grinding surface.
  • For best results, insert the sharpening bit slightly less than all the way into the tool.
Read more: How to Sharpen a Black and Decker Hedge Hog ' eHow.com http://www.ehow.com/how_7163131_sharpen-black-decker-hedge-hog.html#ixzz1XsAosvvl
Oct 17, 2009 | Black & Decker Hedge Hog 24-Inch 3.0-AMP...
My B & D electric hedge trimmer blades are frozen
spray liberally with wd40, let side and hour spray rag with wd40 and clean blades and look for any bent teeth in blade that maybe binding them as u clean use pliers and screwdriver to move if any found, it is likely that wither sap dried or rust formed and is creating too much friction for blades to move wd40 will help free up blades
Jul 09, 2009 | Black & Decker Black Decker 16" Hedge...
Hedge trimmer not cutting
Try getting the blades sharpened. Also have them checked to see if they are tight together, sort of like a pair of scissors. If the screws holding the blades together are sloppy the blades can't cut.
Jun 22, 2009 | Garden
Electric Hedge trimmer will not cut
more than likely it damaged the inner gears or drive pins that make the blades reciprocate and need replaced. if you would like instructions to repair it yourself i will send you them or you can take it to a service center.
Sep 08, 2008 | Electric Hedge Trimmer, 18"
Blade length problem
Hedge trimmers cut using either a single-action, where only the top blade oscillates, cutting against the stationary lower blade, or a double-action where a pair of double-sided toothed blades that slide back and forth at a high speed so you can sweep across hedges in both directions. The latter are more efficient. Blade length Consider the size of the hedge you will be cutting to get the right length blade. The longer the blade length, the more area it can cover and the quicker it will get the job done. However longer blades also require more power and larger heavier motors so weigh up blade size versus ease of use. Blade lengths range from 14 to 30 inches with long blades of 22 to 30 inches providing extended reach for taller or wider hedges. Blade width The blade width indicates the space between teeth and the maximum thickness the trimmer can cut through, eg. 20mm blade width will be able to cut through a maximum 20mm branch.
Aug 27, 2008 | Bond Manufacturing 6-pieceUltimate Pruning...
Garden Logo
859 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
