Question about Garmin Edge 705 Handheld GPS Receiver
I used my 705 on my trainer and it did not record distance or speed like my forerunner does. The 705 works fine on the road
The Garmin Edge series rely on GPS to track your location from point A to point B thereby calculating your speed and distance. Its no different from any other GPS unit which require a clear view of the sky. It does not sense wheel movement, so using any GPS on a trainer will show no movement and using it indoors will give you a bad signal. The sensor on the crank used on the Edge 705 is only for cadence and not speed.
Posted on Sep 03, 2009
When i start my proform 705 trainer the speed goes up and stop , the controller is faulty .What component in the mc-2100lts-30 should i replace to fix it
Dear Sir:
You must adjust , clean, and tigh very well the connector from speed sensor. see the diagram attached.
After that RUN the software calibration.
sincerely. God bless you.
ernesto cuadra
Apr 21, 2012 | Proform Exercise & Fitness
My Kinetic trainer increases resistance when I increase speed. How can I maximize resistance at low cadence of say 60 rpm?
You can't with this type of trainer. You have to have a trainer where you can manually adjust the resistance. The closest you can do is shift your gearing.
Apr 04, 2011 | NRS Kinetic Road Machine Trainer
How to use garmin edge 705 cadence/speed sensor
you must disable the gps speed and enable the sensor
Feb 02, 2010 | Cadence Garmin Edge 705 Bundle W/spd Hrm...
When using my garmin to track exercise while on my stationary trainer, the Garmin does not record any speed or distance. I do have the cadense sensor installed and all of this seems to work fine when using...
The garmin works off of a GPS signal. If you are not moving, the GPS signal doesn't pick up any movement . . . .because you are not really moving. m Therefore, the speed and distance is nil.
Jan 27, 2010 | Garmin EDGE 705
We bought a new garmin 705 and the speed records but not the distance or other features
The Garmin Edge requires that you press the start/stop button to record any data.
1. Before you start riding, press the start/stop button to begin recording.
2. Once you have finished riding, press start/stop button to end recording.
3. Create an account on connect.garmin.com and plug your unit in using the supplied USB cable and download your ride to view details on your cycling session.
Aug 14, 2009 | Garmin Edge 705 Handheld GPS Receiver
Incorrect distance tracked on Garmin Forerunner 405
Could it be that the Unit for distance is set to statute and so displaying miles instead of K?
May 31, 2009 | Garmin Forerunner 405 010-00658-20
Find repair service for schwinn treadmill
short of changing batteries ,if you got them, theres nothing you could do other then replace it, If your speed rpms and distance doesnt read its the speed sensor
Feb 03, 2009 | Schwinn 430 Elliptical Trainer
Is there an idiot's guide to using the Garmin Forerunner 50
This is not exactly a watch- more like fitness device,so, it's not my experize, but I hope this link will help you to understand the basics of use:
http://www8.garmin.com/support/userManual.jsp?market=67&subcategory=68&product=010-00679-05
Do not forget to rate, please.
Jan 25, 2009 | Garmin Forerunner 50
Garmin 305
When the memory in the watch is full detail (ie mapping points) of the earliest runs are deleted but the aggregate data (eg total distance/time etc) is retained. If you want to save the mapping points you need to download it to a PC fairly soon after doing the run (depending of course on how much you use the 305). Although you can use the Training Centre software supplied with the 305 I prefer sporttracks which is a third party donate-ware application which many users find to be much better than TC.
Paul Moore
Mar 11, 2008 | Garmin Forerunner 305 GPS Receiver
Garmin Edge 705 Handheld GPS Receiver Logo
189 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
