Question about Microsoft Xbox 360 Console
No sound, no vision, secure connections,
Xbox 360.[ centre of lights] is on, middle green light on only, buzzes and makes noises, no picture, no sound, all connections secure, worked well for a year, is not overheating, like this from startup, have tried change of discs, help please DB
  • Derek853 Nov 18, 2007
    My 360 was working fine. I rented assassin's creed and it updated my 360. It worked when i played. BUt hte next day i turned it on it wouldnt show a picture or any sound. I tried turning it on with the open close button and that worked. But then I tried turning it on again the next day with the open/close but and it didnt work.
  • Anonymous Nov 21, 2007
    have same porblem.. no sound but everything else works fine
    President:
  • 4,402 Answers
From what I can gather, it sounds like either an overheating issue, but more then likely a cold-joint issue.
I would suggest to try both x-clamp and 12 cent fix. I would try the 12 cent one first just because you dont have to buy anything....unless you need to buy 12 pennies that is, lol. if that doesnt help, then add in the xclamp along with the 12 cent fix to see if it helps.
http://forums.xbox-scene.com/index.php?showtopic=606431&st=0
http://copronymous.com/wp-content/uploads/2007/05/fix-for-the-3rlod.pdf
Posted on Dec 12, 2007
Why wont my xbox 360 stay powered on the indicator light on the power supply brick is green but when i touch the power sensor it lights up green and then goes immedatly back to red
Check your connections. Make sure your A/V connections are secure. The 360 has a feature that if it doesn't detect the connection, it powers down.
Jul 14, 2014 | Microsoft Xbox 360 Console
How can I get the player remotes to connect to the xbox360?
First you hold the big X button in the middle to turn the controller on. Next, after making sure your 360 is turned on, push the connect button on the 360 controller so the lights around the big X are spinning around. Finally, push the connect button on the 360( which is located directly to the right of memory unit B) and the lights around the on/off button of the console should spin. Eventually, your console will find the controller, and you will know its connected because one single light on the controller will remain lit while the others wont.
Sep 10, 2012 | Microsoft Video Game Consoles & Games
My xbox 360 will no longer work i plugged it in yesterday and the green power light in the middle came on but i got none of the flashing green circling lights that appear just before it gets to the...
The flashing lights on the outside of the green power button are the status lights for any connected controllers.
Just turn on one of your wireless controllers and the green status lights should come on.
If you turn on a controller and it doesn't automatically connect, press the connect button the top of the controller and front of the Xbox at the same time. This should connect the controller.
Mar 05, 2011 | Microsoft Xbox 360 Console
Xbox turns on .only centre light comes on,then after 5 seconds or so all 4 lights flash then disappear leaving centre green light on.not playing games at all.we did just update console and thats when games...
There is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide.....you can download it and get help to fix your console.......
Click here to download Microsoft xbox360 repair guide
Jan 05, 2011 | Microsoft Xbox 360 Console
Three red lights flashing on power up. no sound no picture. will open tray. green power light comes on at the power pack.av cables secure. ??? happens all the time can not use console.
his indicates a hardware failure inside the xbox. Your xbox 360 will need to be serviced by Microsoft. There are many internal problems that can cause the three red lights, also known as the "red ring of death" If you would like more information, wikipedia has a good explanation.
You can call 1-800-4MY-XBOX to start the repair process with Microsoft.
Jun 14, 2010 | Microsoft Xbox 360 Console
Xbox 360 not starting up
If you're using HDMI to connect, make sure the TV is on the correct input as the console will 'wait' for a valid signal before powering up fully (on some TV's).
Also check the colour of the Power Adapter when you have powered up the x360.
Here is a link to troubleshoot the power adapter based on the colour of the light on it:
http://support.xbox.com/support/en/us/nxe/hardware/console/setupyourconsole/connecttopowerlist.aspx
Hope this helps.
Jul 13, 2009 | Microsoft Video Game Consoles & Games
Xbox green tint on screen and buzzing noise
i had that problem a while ago. what i did was take out the scart plug, and left my x box off for about 3 hours, then put the scart back in and it worked as new, maybe try taking out the television connecting cable and try get some dust out
Apr 08, 2009 | Microsoft Xbox 360 Console
My xbox 360 turns on with 4 green lights but i can not see any picture or sound
it sounds as if you have a connection unhooked or loose somewhere. Double check all audio and video cables are secure and in the correct position. If that doesn't work try troubleshooting by trying a different tv or removing all connections from tv and xbox and re-hooking everything back up.
Feb 19, 2009 | Microsoft Xbox 360 Console
When i turn my xbox 360 on i get a blank screen with no picture or sound
My solution would be to send it to microsoft if it's still under warranty.
Aug 28, 2008 | Microsoft Xbox 360 Console
Xbox 360 problem
If you can still HEAR sound, but can't see. Check your Audio Video Cable.
It's the colorful one (red, white, yellow) (red, blue green, white, red)
Make sure the connections are secure into the back of the TV as well as the connection to the back of the Xbox 360.
Jul 18, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
