Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
We have a saltwater system and after only 10 days of use we already had to clean the cell because of build-up. Is this normal? Also, I have a test kit that tests for bromine. Is that the same thing as free chlorine?
  • 297 Answers
Lets start with bromine
it can be a substatute but is more expensive. more irritation, and must be kept at a specific reading more so than chlorine or it will be inaffective, or down right irritating to skin clothes and eyes
it works best in Hot tubs
as for the cell build up it sounds like too much salt has been put in
if your followed a table for # of gallons vursus amount of salt to start with then you probably are to high. the tables are just a guide and unfortunatly all salt systems even though produced the same have different results with different amounts of salt
you should get a salt water test kit about 10 dollars for 10 tests a dollar a test sounds exoensive but one you get the pool set you only need to test every 3 weeks or so. salt will not change unless you have a lot of rain or splash out and you are constantly re filling with fresh water
get the salt to 3000ppm no higher or you will get tremendous salt taste and no lower or you will not be able to generate enough chlorine for the pool. The closer you are to 3000ppm then you do not have to worry about the salt content too much for splash out or rain since those instances only change your ppm by about 15-35 so you are a long way from the 2500ppm minumum
check your pool and if you are ( you have got to be ) higher than 3000ppm then drain 20% of the water or so and fill with fresh and so on till you get to that level
clean your cell again and try again
one thing to remeber is that you will need to figure out on your own how long to run it. filtering and chlorine generation are 2 seperat things that pool owners do not understand
I will try to explain as easily as possible
sun,# of bathers and heat will affect the absortion of chlorine there for you will need to run the chlorine generator for different amonts of time. your chlorine should be between 1.0 - 1.5 but anything 3.0 and down to ..0.8 are ok just realize again that thew closer to 0.8 the longer you need to run the generator. Start with 4 hours and see what that does
as for filtering this is what people dont understand you need to turn a pool over AT LEAST 3 times a day even with no swimmers ( Lack of swimmers and filtration is the # 1 cause of cloudy, green, or algea pool )
So lets take generic #'s If you have a 4ooo gal pool and a 2000gph pumpt thats a least 6 hours of straight filtering over and above your chlorine generation
another great hint is to garden hose your cartridge filter every day.
Although it may not look too dirty it has micron particles that block the suction holes and your pump will be running slower than it should
hope this all helps if you have more questions you can e-mail me at shhhucantcme2@yahoo.com
Posted on Jul 17, 2009
  • 4 Answers
DEPENDING ON THE AREA WATER MINERAL CONTENT YOU MAY HAVE TO CLEAN EVERY 10 DAYS, THATS WHAT I HAVE TO DO IN PHOENIX AZ
Posted on Jul 19, 2009
My systems low salt alarm keeps coming on. I have added salt and tested the water all is good. I checked unit for cleaning and it looks very clean. Is it just broke ? Thanks Jim
Jim,
If the salt level is around 3000 ppm and the cells do not have any white calcium build up, you may have a bad electrolytic cell.. Had the same issue with mine.. After I bought a new unit, problems went away and not had an issue.. Found the new model at Wal-Mart for 149.00 with a free 50.00 gift card.. Like paying 99.00, great deal... Good luck Jim!!!
Sep 21, 2011 | Intex Automatic Salt Water System for ...
What is the recommended end-of-season maintenance for the chlorinating pump?
According to the Intex website, the following maintenance is required for this product:
The Intex Saltwater Pool Systems are designed to operate with a minimum amount of maintenance. It is recommended to always turn the pump on prior to turning on the Saltwater Pool System (see Owner's Manual) unless the chlorine generator is part of a combination pool and filter set, to ensure that air pockets are eliminated from the hoses, and that water is flowing through the unit. In addition, the electrolytic cell should be examined and cleaned if necessary. The frequency of cleaning will depend on the local water conditions, pool usage conditions, and length of time the Saltwater Pool System is operated each day. (See Owner's Manual.)
The Intex Saltwater Pool Systems contain several features that minimize maintenance requirements:
1.) An automatic self-cleaning cycle: The Saltwater Pool System automatically undergoes a self-cleaning cycle to maximize the operating length of the electrolytic cell.
2.) Safety diagnostics: the Saltwater Pool System will alert the operator to three conditions that could result in poor operation: Low water flow through the unit, Low Salt level in the pool water, High salt level in the pool water. If any of these conditions exist, the system will sound a buzzer, and flash a digital code on the control panel (Model 8110) or a Red LED will light up. (Model 6110).If the condition is not addressed, the system will automatically shut itself off to prevent damage to the unit.
Sep 11, 2011 | Intex Automatic Salt Water System for ...
I just put up an 18x52 Intex ultra frame pool last week, The saltwater pump and filter pump have both been ran daily for 12 hours.. No codes from the saltwater system, and the water is crystal clear.. ...
I sometimes have the same issue with mine.. One thing missing that helps protect the chlorine from burning off in the heavy sun is (Cyanuric Acid)or (CYA) You should be around 30-50ppm.. To bring this level up to 30-50, they sell a conditioner that raises this level.. Don't add too much if your already close to the 30-50ppm.. Other than that, you can continue to run the system as you already do.. Seems like it's maintaining clean and clear... Hope this helps???
Aug 31, 2011 | Intex Automatic Salt Water System for ...
My water is cloudy and says low salt. I added 120 lbs and it still beeps low salt. I have a CS8111 saltwater system & filter combo. It is on an above ground pool 24' X 52".
Check the electrolytic cell!!! You will get a low salt alarm if cell has calcium or sodium build up.. If it does, soak, flush and clean with vinegar.. Also, make sure you run the pump only, no chlorinator for 24 hrs to properly disolve the salt you just put in....
Aug 05, 2011 | Intex Automatic Salt Water System for ...
My pool water has turned green in 2 days. I have an Intex pool with a saltwater system. How do I get it back to normal? I am new to the pool thing so you may need to put the awnser in laymans terms.
As long as you have the correct amount of salt and the electrolytic cell (The thing that makes the chlorine) , run the pump at 12 hrs with the chlorinatior at 10 to 11 hrs in between those 12 hrs for one full week and you will see results. Also, vacuum and clean your pool now before you start the 12 hrs cycles.
Jul 22, 2011 | Intex Automatic Salt Water System for ...
Low flow came on after pressing the boost button boost button was pressed because test was low what do I do
First, make sure your filter is clean!!! Then check you electrolytic cell for excessive build-up and clean if white stuff is present .Use vinegar to clean the unit as the manual states and also clean your flow switch. Try this and hope this will solve it..
Jul 19, 2011 | Intex Automatic Salt Water System for ...
I have set up the intex saltwater system. We have run the salt generator for several hours, however the chlorine reads 0. I have added conditioner (thinking this was the issue), however, everything else...
The short answer is add some chlorine. Clean your cell and assure it is operating normally per you owner instruction. Normally, the manufacturer recommends physical cleaning followed by acid wash. Of course use the usual safety precautions when using muratic acid.
Conditioner? Is that Cyanuric Acid? or is this a sequestering agent for removing metal?
Thanks for your interest in FixYa.com
Jul 03, 2011 | Intex Automatic Salt Water System for ...
In three days my electode is clogged up my salt build up.so I get a low salt alarm
ok, it is time to stop guessing on how much salt to add or take out.
You need to be as close to 3000ppm as you can
anything under 2700 and you will not generate enough chlorine. any thing above 3500 and you can go cloudy, have build up, or just plain taste terrible.
you need a test kit for salt that reads in #'s not color
the color salt kits have too much varience
If you are over, drain 20% of the pool and ad fresh water keep doing this till you get close to 3000ppm
If you are under then ad the amount of salt stated in the test directions.
Once at 3000 clean your cell again.
you should be good to go
Dont forget that once at 3000 you must keep an eye on the level because of rain and adding water for splash out
Aug 29, 2010 | Intex Automatic Salt Water System for ...
How to clean a salt water system
I think this is metal scale. If you dont have your manual, consider asking your dealer for advice. If there is no dealer in your area, consider a mild acid wash.
Aug 01, 2010 | Intex '10 Saltwater System Pool...
My saltwater pool tastes very salty, but my intex saltwater pump keeps saying low salt. I have to clean the cell everyday or it will not operate properly because the cell gets covered with white buildup...
Your salt is way to high if you can taste it. You will need to dilute with fresh water until you get the salt back down and then clean the cell for continued use.
Jun 25, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
344 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
