Question about Maytag EPIC MFW9700S Front Load Washer
Washer flashing 02 F. Maytag epic washer won't spin -flashing 02 F about 15 minutes into the cycle. We just had new electrical components put into it.
You need to use the HE detergent. I believe that is a drain problem. By using the regular detergent that causes more suds and in turn clogs your drain
Posted on Jul 18, 2009
Maytag epic
Sounds like the control unit needs replacing, it's the brains of the machine. might be time for a new machine.
Jul 22, 2014 | Maytag EPIC MFW9700S Front Load Washer
I push the power button and when I hit start it just shuts off. The only cycle that works is spin on my maytag epic z
Any luck? the certified Maytag repair company looked at mine and quoted $445. for the repair. it is 15 months old so of course the warranty is obsolete. The solution is a new CCU panel and Temperature sensor. Good luck.
Aug 30, 2011 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic Z won't Drain after rinse cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Maytag EPIC MFW9700S Front Load Washer
My Maytag washer has a flashing F 15. What does that mean?
The following list of codes indicates an electronics communication problem with the washer: * EpicĀ® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
* Epic ZTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Hope this helps.
Jun 24, 2011 | Maytag EPIC MFW9700S Front Load Washer
During the wash cycle on a maytag epic mfw9800tq0 my daughter opened the door and after water splashed on the floor she slammed the door shut. It will not drain and spin out now. the tub will agitate...
if she could open the door during wash cycle the door lock is broken and you may need a new one also inspect pumpn and tub to pump hose for foreign objects
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
Final spin /rinse cycle won"t stop
It's usually a control board problem. sorry for the bad news :(
Maytag Epic
the control board has loose solder connections around the relays.
see this
diff model same issue with new boards as they make them all.
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
being it is in warranty its too early for you to fix it yourself.
you will have to wait for them to come out and say the parts are on backorder.
Feb 04, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
378 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
