Question about ViewSonic GA771 Monitor
Screen flicker/jumping i have a packard bell flat screen monitor and the picture /screen continually keeps flickering/jumping up and down can any body suggest a solution thanks regardsphill
  • Anonymous Mar 26, 2014
    This TV/MONITOR Picture Flickers mostly at lower half of screen with large potions lost/blank.can you help please
    Problem Solver:
  • 20 Answers
First check loseconection and tube light and nearaset spk for sparking .and check the earth of monitor main waire
Posted on Nov 18, 2007
I have a 40inch Samsung le40r88bd that keeps flickering and is getting worse is there an easy fix?
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY most common way MODEL ...
Flickering picture
Samsung ElectronicsMar 13, 2013 - A flickering picture on your TV can be caused by the following conditions: Television settings; Incoming signal issues; Electronic interference ...
How to fix Samsung LN46C630 screen flickering issue
Jan 16, 2016 | Samsung Televison & Video
How do I stop screen flickering
If this occurs within a specific application, it probably has to do with the fact that the application wasn't programmed for double buffering. If your screen is constantly flickering no matter what, it could be bad video drivers. Try updating them. If that fails, it's probably either bad hardware. Try a different video card. If it still persists, it's a bad monitor.
Sep 12, 2014 | Microsoft Windows Vista Home Premium with...
My flatscreen Mitsubishi Keeps flickering with tiny stars on the screen
changing the screen migth be expensive you can add money and get a new one
Mar 25, 2014 | HEWLETT-PACKARD Computers & Internet
Laptop monitor bad color and flickers continuely, but when attached to external monitor, works fine
I'm going to take an educated guess here, because it sounds like the monitor's interface controller is bad. I forgot the name of the thing, but it's a small circuit board that's normally located at the bottom of the panel frame, between the flat ribbon cables and the round hinge cables.
"Inverter Board"
Mar 19, 2013 | Dell LATITUDE Computers & Internet
Monitor display flickers a lot and colours change
If the monitor is external, make sure the connecting cable is in properly. If it is a vga cable, ensure it is screwed in tight, not just plugged in. If the display is built it, I suggest you take it to your nearest computer repair shop for them to have a look at it unless you have previous experience in this or a really tech savvy family member/friend.
Oct 19, 2012 | Packard Bell Computers & Internet
Picture flickering and faded on left had side of the screen
if rebooting the monitor would do no good, try to get a spare monitor cable if the same flickering issue took effect. If it is so, then call your pc provider to repair your monitor..
Nov 26, 2011 | Philips 47 in. LCD HDTV
Hello, i have a Packard bell igo , that when i try to boot 3 lights on the bottom of the screen and the cd keeps trying to run and also the screen is flicking , what should be the problem ?
Packard bell igo, is a notebook..what model is it. if the screen starts flickering on the go, then you could be having a flex problem or motherboard problem. but if it loads and later flickers, then you should check the installation. please explain a little bit more if this doesn't help.
Mar 04, 2010 | Computers & Internet
The screen on my packard bell laptop flickers. It is approx 1 year old. This happens if it has been on a while or has just powered up, when plugged in or running on battery regardless of what it is being...
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out for parts, repair service and DIY info.
Mar 13, 2009 | Packard Bell Easy One Silver 2120 Notebook
Dell monitor is flickering
If you have another computer, try hooking to it and see if it flickers on it too.
If you hit Ctl-Alt-Delete and choose Task Manager, does the box flicker there?.
Adjust the monitor ratio in the Display Settings/Display/ Display Adapter Properties, Monitor Tab, see drop down (increase screen refresh ratio to higher number).
Nov 10, 2017 | Dell E207WFP LCD Monitor
Flickering screen
My screen flicker on xp but on win7 please help me?
Regards, Chas
Jan 06, 2009 | Acer X193W LCD Monitor
ViewSonic GA771 Monitor Logo
504 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
