Question about Sub-Zero 690 Side by Side Refrigerator
Vacumm Condenser light flashing
Have a 2000 subzero 650. Two years ago light was flashing and temp rising. Tech replaced sealed system which was leaking. Light started flashing again two years later, but temp remains good. Tech checked sealed system and said there was no leak. Cleaned condensers and reset unit. Two days later light is flashing again.
What else can cause this to happen? What does it actually mean when th light is flashing and the condensers are clean and temp is fine. I'm not sure I understand what triggers that warning message to begin with. Does it mean the compressor is running too long? or????
Thanks in advance.
  • 55 Answers
Hello.
Your unit is sensing that the condenser fan is running at a lower rpm than it should. that is how you get the signal. You will need to replace the condensor motor if your coils are cleaned already. That is the only cure for your problem. I hope this helps you out.
Posted on Jul 16, 2009
My 12 year old subzero fridge (650) is not getting cold. this morning i discovered ice behind the fresh food drawer, removed it, it was running fine, temp 35. now tonight the temp is 51. freezer is fine....
Is it flashing vacuum condenser? Ice behind the crisper drawer shouldn't effect the temp. What is it set at? You can go to www.subzerospecialists.com and click on Tech Help for additional info.
Feb 23, 2011 | Sub-Zero 650 / O Bottom Freezer...
Frost accumulating on back of fridge - service light blinking
YOUR EVAPORATOR IN THE FRESH FOOD SECTION IS LEAKING FREON. THIS IS COMMON WITH EVAPORATORS IN THIS AREA. 12 PART WARRANY OR 6 YEAR FULL ON THIS. SUB ZERO HAS SUPERIOR CUSTOMEER SERVICE AND MAY COVER FULLY IF OUT OF THE 6TH YEAR. 1-800-222-7820 CALL THEM AND ASK.
Apr 23, 2010 | Sub-Zero 650 / O Bottom Freezer...
VACUUM CONDENSER MESSAGE KEEPS COMING ON subzero 650. I vaccumed it several times! The temp gauge is showing 48, yet the tem is set on 38
you need to turn off main power to frig...wait 5 mins..plug back in...if does it again replace sensor by condnser coil you cleaned..please ,on the side you cleaned flash a bright light thur it if you see no light, its plugged...then take compressed air an blow thur it...will be a little dust...vaccum up...hope it will help...michael,doctor airr appl.repair..843-384-8474...call if need more assistance..good luck...
Mar 26, 2010 | Sub-Zero 650 / O Bottom Freezer...
Refergerator side back panel freezing up with ice
2 posibles problems. if the ice is only about 4 an 8 inches you have a seal system problem.(evaporator freon leak) need replace the evaporator asap. if the ice cove a big part of the back wall you have a thermostat problem. for replace the evaporator better call a tech. remember to call a subzero factory authorized company. maybe still under some warrantty> good luck LEAVE YOUR COMMENT IF IT WAS GOOD FOR YOU....... THANKS
Sep 06, 2009 | Sub-Zero 561 / F
Subzero--Vacuum Condenser Signal Won't Turn Off
The vacuum condenser indicator keeps flashing on and off. I did vacuum the unit, the the indicator lights keeps flashing on and off. How can I reset it and keep it off?
Thanks,
Rob
Aug 22, 2009 | Sub-Zero 650 / O Bottom Freezer...
My 650/f sub-zero is not cooling in the refer but the freezer is working fine?
Subzero uses two compressors so the freezer is a separate system. The first thing to do is clean the condenser. You can find instructions on how in the owners manual or at subzero.com. They even have videos. If that doesn't take care of it you could have a bad condenser fan motor a sealed system issue or a temperature sensor issue. Also I have seen if you put something tall enough to push up on the light cover on the top shelf that can stop the evaporator fan at the top of the refrigerator section.
Aug 01, 2009 | Sub-Zero 650 / O Bottom Freezer...
Subzero 650: Ice Service light on
turn the unit off for a few minutes then back on. If you have a real problem that needs to be serviced the service and ice light will star flashing again relativly soon
Jun 30, 2009 | Sub-Zero Bottom Freezer Refrigerator
Subzero 650 fridge temp says 34 but is really about 50
Is your thermometer in a glass of water? That's the way to get an accurate temperature reading. You may want to call an authorized servicer.
Jun 15, 2009 | Sub-Zero 650 / O Bottom Freezer...
My subzero 650 bottom freezer working top part not working (warm)
Make sure the condenser is clean. Instructions are in your manual or subzero.com. If cleaning it doesn't work call for service
Apr 04, 2009 | Sub-Zero 650/SRH Stainless Steel
SubZero 650 - fridge 36 to 50 deg, vac condensor light flashing
Hi!! you have a seal system problem.A leak in the evaporator..
Dec 26, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 690 Side by Side Refrigerator Logo
372 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
