DTC 1784: LOW-REVERSE
PRESSURE SWITCH
1.Remove transaxle relay from connector. Turn ignition on. Install scan
tool and observe low-reverse pressure switch condition. Apply battery
voltage to transaxle relay connector terminal No. 8. If low-reverse
pressure switch stays off, go to next step. If low-reverse pressure
switch turns on, go to step 4 .
2.Raise vehicle enough to allow drive wheels to spin freely. Test
low-reverse clutch hydraulic pressure. See HYDRAULIC PRESSURE TESTS
under TESTING. If low-reverse clutch pressure test is not within
specification, internal transaxle failure exists. If low-reverse clutch
pressure test is within specification, observe scan tool.
3.If low-reverse pressure switch turns on, trouble code is intermittent.
Check wire harnesses and connectors for damage or poor connection. If
low-reverse pressure switch does not turn on, replace solenoid and
pressure switch assembly. Recheck trouble codes. If trouble code resets,
replace TCM.
4.Check and repair wiring harness between transaxle relay connector and
solenoid and pressure switch assembly connector. If wiring harness is
okay, check wire between TCM connector terminal No. 10 and solenoid and
5.If wire between TCM connector terminal No. 10 and solenoid and
pressure switch assembly is okay, check TCM and solenoid and pressure
switch assembly connectors. Repair connectors as necessary. If
connectors are okay, recheck
trouble codes.
If trouble code resets, replace solenoid and pressure switch assembly.
Recheck trouble codes. If trouble code resets, replace TCM.
P0700-The Transmission Control Module (TCM) monitors the malfunction of
sensors and actuators relating to transmission control. When the TCM
detects a malfunction with the control, a signal is send to the Engine
Control Module (
ECM) to trigger the Engine Light or Service Engine Soon light. The
ECM stores the P0700 code and it means the TCM detected a malfunction with the transmission controls.
I would try disconnecting he battery and letting it sit for 5 minutes, then hook it back up to see if they return-the 700 code is probably related to the 1784 code, that seems to be your main issue.
