Question about Western Digital MY BOOK HOME 1TB EXT HD-USB2/FW/E-SATA 3.5IN 1YR FireWire 400 Hard Drive
How to unlock the case on WD Home Edition
I believe my disk drive is ok...I would like to open the case and place the
disk drive itself in another USB dock. What can I use to open the case ?
  • 696 Answers
I have opened a few of these and they are tricky but it can be done. You will need 2-4 flat screwdrivers or if you have them paint can openers work even better.
THESE INSTRUCTIONS WILL VOID ALL WARRANTY ON YOUR DRIVE. PROCEED AT YOUR OWN RISK.
Wedge 1 of the drivers into the seam near the top of the back of the drive and pry inward until the upper latch releases, then pry up about 3mm to release the clip, repeat at the bottom of the same edge leaving that driver in it's place.
Now, either leave them in or slide that side back about 2mm to prevent the latches from relocking. Then repeat on the other side.
Once all four latches have released wrestle the pages from the binding(think book) as if tearing the pages out of a binder. It's a tough seal but will pull apart slowly.
Once you've removed the shell, you will see the drive mounted on a cage, with 2 circuit boards attached, remove the screws and boards first, then remove the 4 screws from the HDD and it will pull free.
Once it's out, it's just an ordinary internal 3.5" SATA drive and should fit and connect into any standard(current) desktop.
Hope this helps FixYa,
Chris
Posted on Jul 18, 2009
My hard drive stop data transfer for a few seconds and then strats it again - drives me crazy when listening to music from the drive
Copy one of the "music" files from the W.D. to your 'C:' drive.
Then, "play" that copy of it. If it stop/starts/stutters, it's your computer, not your W.D. device, that is the problem.
Otherwise, you have a problem with your W.D. device.
See: http://support.wdc.com/product/downloaddetail.asp?swid=119&wdc_lang=en
and "Download the Data Lifeguard Tools software (Acronis True Image WD Edition and user manual and the WD diagnostic tool)".
Run that WD Diagnostic Tool, to "test" your W.D. drive.
If it "fails" the test, then exercise the warranty to get W.D. to replace the drive.
If the warranty has expired, W.D. has a "Customer Loyalty" program;
buy a new W.D. drive through the W.D. web-site, at a discount.
Or, open the case, remove the disk-drive, and buy a replacement, compatible, disk-drive, and "transplant" it into your case, to revive your external storage device.
Dec 04, 2010 | Western Digital My Book Essential 1TB...
My hard drive starts but the file won't open. I reprogrammed it but the outcome is the same. If you open the file it freezes the screen till I can close the file. Is there a way to fix it? Please and Thank...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
Nov 07, 2010 | Western Digital My Book Home Edition 500...
My WD 250 GB hard drive no longer reads on my laptop....what has happened to it?
There are 4 major components:
* the USB cable -- try a different one
* the power-supply -- try to find a different one, or use a multi-meter to check the output (voltage and amperage) levels, to confirm that the actual values match the specifications
Try connecting it to a different computer, to see if it works at all.
Disassemble the enclosure, remove the disk-drive, and attach it as a "slave" disk-drive in a desktop computer, to see if the drive itself is OK or not OK.
If it is OK, then buy a new "empty" external storage enclosure, and "transplant" your disk-drive into the new enclosure.
Is the warranty still valid? If so, exercise the warranty.
If not, then W.D. has a "Customer Loyalty" program, allowing you to buy a new W.D. device from the W.D. web-site, at a significant discount.
Nov 02, 2010 | Western Digital My Book Essential Edition...
When i plug in my western digital my book home edition to my pc it shows no folders in it like there is nothing there can you please help
Try connecting it to a different USB port on your computer.
Try connecting it to a different computer.
If it still is under warranty, W.D. will repair/replace it (but won't try to "rescue" your data).
If the warranty has expired, W.D. has a 'Customer Loyalty' program; buy a new W.D. disk-drive from their web-site, and enter the serial-number of your current disk-drive, to get a discount on your purchase.
Or, disassemble the enclosure.
Separate the disk-drive from the USB-to-disk-drive adapter.
Connect the disk-drive as a 'slave' in a desktop computer, to see if the files can be accessed _not_ through that adapter.
Note that you could put a different, compatible, disk-drive into the enclosure, to build your own external storage device.
Oct 26, 2010 | Western Digital My Book Home Edition 500...
My WD 500g external storage unit started to fail me. The USB connection broke off into the actaul WD outer case. I opened the case and took everything apart except the actual drive. I am wondering what...
Buy a new "empty" external disk-drive case for $30.
Pick one that has "data" and "power" connectors that are compatible with your current disk-drive.
Put the disk-drive into the new case. Done.
Apr 18, 2010 | Western Digital My Book Essential Edition...
I have XP and my WD hard drive will not recognize?
Try a different "data" cable between the computer and the WD unit.
Try connecting the unit to a different computer.
If it still does not work, then either:
* the USB-to-disk-drive adapter, inside the casing, has failed,
* the disk-drive, inside the casing, has failed.
Disassemble the unit, and remove the disk-drive.
Connect the disk-drive as a "slave" disk-drive to a computer, to see if the disk-drive is OK, i.e., the USB-interface is the problem.
Copy the serial-number of the disk-drive, and use it to "check warranty status" on WD's web-site. If the drive is still under warranty, WD will replace it.
If not under warranty, WD has a "Customer Loyalty Program", i.e., buy another MyBook through their web-site, and get about a 20% discount, as a current WD customer.
Apr 08, 2010 | Western Digital My Book Essential Edition...
When I plug it into the PC it does not show as connected
Try it in another computer (Mac, desktop, notebook).
It could either be the USB-to-disk-drive interface that has failed,
or the USB cable that has failed,
or the disk-drive inside the casing that has failed.
Open the casing, and remove the disk-drive, and temporarily connect it as a "slave" disk-drive in a computer, to see if it can be detected.
Jan 13, 2010 | Western Digital Elements powered by WD 320...
WD My Book Studio Ed. (Mac) - 2TB - stopped working for no reason
plug your drive in to your computer, right click
on my computer and bring up disk manager,
open disk manager and see if your wd drive
shows up. then reinitialize the drive and this
will hopefully solve your problem.
Aug 21, 2009 | Western Digital My Book Home Edition 500...
WD5000MT not recognized
Try a replacement USB cable first, and test the MyBook on a different computer, to ensure the fault is on the external storage unit.
There are two possibilities:
The Mybook USB/ATA controller board is faulty.
In this case you can simply take apart the enclosure and mount the disk into a new enclosure. WD Mybooks are SATA, but double check the hard disk connector to ensure.
The hard disk inside is faulty.
In this case repair may be expensive. You need to locate a data recovery facility with a 'clean room' , the cost is usually more than $800.
If this happened after a power surge, then the problem is most likely a faulty controller board.
If instead you have dropped the hard disk it is possible an hard drive failure, in that case repair will be expensive.
A replacement enclosure will stfrom art about $20 on Ebay or Amazon, and must not necessarily be WD .
Check if your disk is Sata or PATA (IDE) before buying the enclosure.
May 21, 2009 | Western Digital My Book Home Edition 500...
Western Digital MY BOOK HOME 1TB EXT HD-USB2/FW/E-SATA 3.5IN 1YR FireWire 400 Hard Drive Logo
937 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
