Question about Philips Audio Players & Recorders
No sound coming from one of the jacks
I have a set of philips speakers,38watts,on the back of the sub woofer is the white and red jacks,one side is not working.
  • 1,511 Answers
Please check if your sound balance is in the middle
also try to insert the jacks properly
hope this solves your problem
Posted on Jul 16, 2009
Instruction manual for a RCA Home Theater System RTD 3136
The speaker jacks are labeled on the surround system.
front left front right
sub woofer
(can be located either side)
center
left rear right rear
tv= audio out ( red/white ) to surround=audio input ( red/white)
yellow is video, not needed for sound
Feb 18, 2014 | RCA Rtd3136 5.1 Channel Home Theater...
How do i connect my dell 540 to a receiver?
The audio output jacks on the back of your computer are for 5.1 speaker setup. Meaning that you have a speaker array of 2 front side speakers, 1 center speaker, 2 rear left and right speakers and a sub-woofer speaker. Here is a link to the set-up giude of your computer:
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_studio_desktop/studio-desktop_Setup%20Guide_en-us.pdf
Feb 16, 2013 | Dell Studio 540 MT Pentium DualCore E5300...
Where should I plug in my sub woffer
There should be two jacks on the back that say SUBWOOFER in the "preout" section of the back panel that is directly above the speaker jacks. Either of these jacks should work for your sub hook-up. Also make sure that you set your front speakers to small in the speaker setup menu, otherwise there will be output to the subwoofer jacks.
Dec 27, 2012 | Pioneer Elite VSX-52
There is not a subwoofer input jack on the back of this subwoofer. There are a set of input (negative and positive) terminals and a set of output (negative positive) terminals like would hook speaker wires...
On the back of the sub woofer you have two sets of binding post / some have spring clip terminals ( red & black ) labeled Speaker In ( sometimes High Level In ) and Speaker out.
Take 2 pairs of speaker cables and connect one end to the speaker out socket of your amplifier ( left & right ) . The other end of the cable should be connected to the sub woofer's Speaker In socket , Red to red and black to black. Now on the Speaker Out socket of the sub woofer connect your existing pair of speakers using another pair of speaker cables. If your sub woofer has a Hi Pass filter built in , you may not hear bass coming from your existing speakers with this kind of connection. Good if you have small satellite speakers.
Mar 12, 2011 | Audio Players & Recorders
How do I wire up my Logitech X540 Speaker system to my Lg tv?
Most TV's nowadays, have audio out RCA jacks that will allow you to send audio from the TV, to an alternate source. These speakers do come with an adapter that allows you to hook up RCA red and white audio cable, and plug them into the adapter, which goes from the RCA jack to a 1/8 in female headphone style jack. You would then need to get a 1/8 in audio cable that has two male ends, and plug that into the back of your sub woofer in the front speakers port. But this really isn't going to give you very good sound quality being it's not giving you true 5.1 surround sound, even with the matrix feature enabled!
Dec 27, 2010 | Logitech X-540 Computer Speakers
I have connected all speakers but not getting anything coming through the subwoofer? I have connected all of my existing Sony suround system speakers 4 corner and one middle and the sub woofer to the...
You need to use an amplified sub. The Yamaha receiver is only sending "Pre-Amp Signal" not amplified audio like the rest of your speakers. If your sub has a crossover built in, connect it's speaker level (wires) to the "B" side of the receiver which will send audio to your sub and it will cross it over internally. Not the best sounding, but it works. Amplified subs range in price from 200 and up. Hope this helps
Jun 14, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
My tv has one sub output socket,but my active sub woofer has a red and white input sockets.what lead do i need to connect it up with?
Sounds like the output on the TV is a phono socket or a jack and the inputs on the sub woofer take banana plugs. You need (or should make up) a lead with a phono or jack plug one and and two banana plugs the other end. (phono plug/socket has two connections and banana plugs just one)
If you can provide the model numbers of the two bits of equipment I can check this for you.
Mar 08, 2010 | Audio Players & Recorders
I Do Not Know How To Connect Boston Micromedia To My Computer
The Boston Micromedia speaker set comes with two speakers (right and left),a subwoofer, and a complete set of cables to connect everything up.
1.) Position the speakers. The two small speakers typically are spaced equal distance apart on a desk/table top to the benefit of the listener. The sub-woofer typically rests under the surface, on the floor for example.
.) Connect the cable sets to the back of the two small speakers along with the speaker feet.
Note: the small speaker with the volume control knob will have three cables coming from it. This will be the "right" speaker. The other speaker will have a single cable and will be the "left" speaker.
2.) The cable ends will be color coded to match the jackson the sub-woofer. Match up the color coded cables to the respective colors on the subwoofer as follows:
(a) White cable end (left speaker) to white jack on sub-woofer.
(b) Red cable end (right speaker) to red jack
(c) Purple cable end (input) to the purple jack
(d) Green cable end (computer out) to the computer's microphone output jack.
Note: if any of the cables are too short to reach their jacks for whatever reason, an extender cable with a female and male end can be purchased relatively inexpensively to make up the difference in distance.
3.) Power up the system (plug in power cables to the sub-woofer and wall), play some music, and adjust the sub-woofer sound (control knob) to suit listening pleasure.
A nice little set of speakers, I had mine for some years now and continue to enjoy them. Good luck!
May 17, 2009 | Boston Acoustics MicroMedia Computer...
Connection of a subwoofer to Yamaha ZX-V490
Get a powered sub-woofer that has speaker level inputs, then run your front speaker wires into the sub-woofers speaker level input and then run a set of speaker wires from the sub-woofers speaker wire output to your front speakers. This is a common way to use a sub-woofer with a receiver that doesn't have a sub-woofer output.
Most powered sub-woofers have these connections, just check it out first before you buy one. They look like speaker jacks on the back of the receiver.
Let me know if you have any other questions.
Jan 02, 2009 | Audio Players & Recorders
118 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
