Question about Hotpoint FFA70 Bottom Freezer Refrigerator
Freezer high temp - Hotpoint FFA70 Bottom Freezer Refrigerator
  • Hotpoint Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerfreezer high temp - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 12, 2010
Freezer temp cycles above freezing
If you have a frost free refrigerator then temp jumps as you discribe are somewhat normal during a defrost cycle. However it sound like your defrost temp may be getting too high. There is a limit thermostat on the freezer coils that keep the defrost temp from getting too high. The part is called a (defrost termination thermostat) and is a round disk about 1 to 1.5 inch in diameter clipped to the top of the freezer coils with 2 wires coming out of it. When cold, it allows power to the defrost heaters. At around 35/40 degrees it opens and shuts off power to the heater. 35/40 degrees sounds high for a freezer temp but that is behind the wall and only for a short time. Yours may be staying on too long or out of temp calibration needing replaced.
Mar 20, 2015 | Refrigerators
High temp is displayed on my Electrolux side by
is the temp really too high in the ref or freezer ? if so I would check to see if there is frost or ice build up on the backwall of the freezer.. this would indicate a defrost issue... is the freezer fan running?.... if all the temps are fine then I would look at the main board and the sensors............. hope this helped........ ken
Sep 29, 2014 | Refrigerators
I have a hotpoint freezer fza34 The red high temp
it could be that your fridge,freezer setting is not turned up high enough to keep the freezer cold enough.turn it up to setting number 5 at least and if that dont do it u could have a faulty thermostat.have it checked by a engineer.
Oct 30, 2013 | Freezers
The high temp light is on, liquids are now liquid,but the meat is still frozen. I live in west central mich, and the temps have been in the high 80's and low to mid 90's with relitive high humidity, about...
Not normally,Make sure you door is sealing properly also check and make sur ethe evaporator fan is running when the freezer is in a cooling mode.you may need to remove the rear panel of the freezer and check for frost build up.if there is frost build up then defrost the evaporator with a blow dryer.
then check the continuity of the heating element and make sure it is in working order.
Aug 31, 2010 | Frigidaire 14 cu. ft. / 396 liter Upright...
The high temp light is on. What can I do to reset it? Everything seems frozen and fine in the frezzer
HIGH-TEMP ALARM SWITCH (SOME MODELS)
An audible
alarm will sound if the freezer temperature reaches
unsafe levels. The alarm operates on household electricity.If
the power
fails, the alarm will not perform.
An ON/OFF switch
allows the high temperature alarm to be
deactivated if desired. NOTE: You must open the
freezer door to
view the alarm switch. The
freezer is shipped with the switch in
the OFF position.
After the freezer has run longenough to
lower the temperature, you
may set the switch to the ON
position.
To activate the alarm, set the switch
to the ON position.
To deactivate the alarm, set the switch to the OFF position
i got this from the freezer manual from Kenmore hope this was helpful
Mar 28, 2010 | Kenmore Freezer 13.7 cu. ft. Upright...
Red light flashing
red light flashing means temp. is too high (not freezing) just an indicator to let you know that there is a problem
let me know: the freezer temp. (use a temp. reader)
any unusal ice build up on the back freezer panel?
compressor running?
parital frozen foods?
need to know so i can help you
Mar 05, 2010 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
High temp in food compartent freezer is ok
Try cleaning the dust out from under the fridge and the back. This worked for me
Sep 24, 2009 | Kenmore 53642 / 53644 Side by Side...
Freezer not maintaining temp
sounds like the evap thermistor took a ****. in the back of your freezer you have cover that sits over the refrigerator coil. under this coil sits a heater element that is turned on and off to defrost the refrigerator coil based on how long you've had the door open. the evap thermistor reads the temp inside the freezer.. close to the refrigerator coil.. and tells the heater element to turn off after it reaches a set temp where it can be sure that the ice has melted off the refrigeration coil which is about 60 deg. if your thermistor has taken a ****.. your heater element will only shut off based on the "fail safe" time (which is based on how long you've had your fridge door open) leading to a hot freezer.
i suspect your at home more on the weekend.. inside the fridge.. getting cold beers.. and that is why it ends up hotter on the weekend.
Cheers!
Jun 14, 2009 | GE Energy Star PDS22SIS Stainless Steel...
Freezer side not freezing
It appears that the defrost bi metal control is hanging up and during the defrost the temp in the freezer is going too high. It is supposed to terminate the defrost at around 50 degrees. This usually occurs in about 20 minutes, if the defrost heater stays on for too long the freezer temp goes too high. Change the defrost bi metal
Jan 22, 2009 | Kenmore 53642 / 53644 Side by Side...
Water was frozen all inside the freezer and fridge temp was high
Self defrost mechanism may have an issue. If it stays on too long you will have excessive temps build up in refrig as well as freezer. There is also a defrost thermostat that is supposed to turn compressor back on when temps get too high - check that out also.
Apr 14, 2017 | GE Profile PSW26P Stainless Steel Side by...
Hotpoint FFA70 Bottom Freezer Refrigerator Logo
104 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
