Question about Intel Desktop Board D845WN Motherboard
I need help
On the advice of my friend i very carefully removed the processor from my motherboard in order to reset it and stop the horrid bleeping that it was doing. well now i cant get anything to work, when i turn it on the disc drives light up and the fan starts and that is it, It is a x86 Family 6 Model 8 Stepping 10 Genuineintel motherboard and it has 1002MHz, also the operating system is XP Pro sp2. it is my daughters pc and she is heartbroken and i dont feel to good iether, do i need to somehow re install software for the processor or the motherboard? I am at my wits end, I hope you can help
  • 883 Answers
The possible problems are:
1.) static discharge from touching the micro...technicians use special anti-static wrist straps to perform this task.
2.) micro not seated properly into socket...repeat the procedure that you described, but this time, ensure you are statically method is to keep the power cord connected so that earth wire has a path to -earth- and keep one hand touching the bare metal chassis at all times...but the initial discharge (the worst one) can be a tricky really is best to wear a static discharge wrist to provide this path and to limit the initial discharge amperage.
What about the "horrid bleeping"? ....need more detail...
Posted on Nov 18, 2007
When dryer is switched on the red light (start/pause) button keeps bleeping and machine wont work
It seems that the program controller unit is faulty or has hung up . Remove the power and keep aside , check if the controller unit has any power issues.
If the unit does not reset the processor must be checked.check for short on the motor , check if the door switch is working.
Check this link for tips :
Sep 23, 2011 | Zanussi TC7102W Electric Dryer
Hi,my computer has stopped working and just beeps at me. mother boardis a Microstar P4m266-8235. Please Help......Thank You
This problem could be due to carious problems.
1) Your motherboard is faulty.
2) Your Processor is faulty.
3) Your RAM chip/s are faulty.
Firstly, you will need to unplug your computer and open it up. Then you need to locate the RAM which looks like this:
Remove one piece of RAM (assuming you have more than one piece) and try to start the computer again, then if it doesn't work, remove the other chip and reinsert the chip that was first removed and try to power up again.
If it works, then one of the RAM chips were faulty and you will need to replace them.
If the computer still does not work, then either your Motherboard or Processor are faulty.
You should then buy a new motherboard which isn't too expensive (be sure to buy a motherboard that will fit in your computer and will also be able to handle your processor.). Place the motherboard with the RAM in to the computer case after removing the old motherboard. Then carefully remove the processor from the old one and put it in to the new one.
Be sure to re-insert any cables that you have unplugged from the old motherboard in to the new one. Then try and power up once the machine has safely been closed again.
If the computer works, the motherboard was faulty. If it still does not work, then your processor is faulty and you will need to buy a new processor and install it.
Alternatively, you can take the computer to a repairman who will test the various components which will save you the hassle of doing all of that work and it will also save you the cost of having to buy new RAM and a new motherboard if in fact it is actually your processor that is faulty.
Thank you for using FixYa! Have a great day and please remember to rate this solution.
Best regards,
Jan 10, 2011 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
My computer stopped working so I put a new power supply in it. It still won't work. What else would be wrong with it?
Need far more info than that.
I assume you've checked the fuse in the plug?
What are/were the symptoms?
Does anything work or look/sound like its on/working?
If not then it could be a motherboard/processor fault.
Hope this helps, although i'm not sure it will. Try to give us some more information about how it stopped working please, imagine if you went to the doctor and said "my friend stopped working, what was wrong with him?" he wouldn't have a clue ;-)
Good luck and let us know as much info as possible if you need more advice.
Nov 26, 2010 | Computers & Internet
Motherboard has nothing connected to it. i need to know where to connect the cables for the whole computer
connect poer supply to motherboard socket which is near processor beside and see light will bleep on motherboard
Oct 22, 2010 | HP Asus Motherboard P4SD-LA Socket 478...
Computer will not start only BEEPS
hi depending on how many beeps your getting will depend on the problem you have it could be that your ram is not fitted correctly or loose check and refit it could also be that your hard drive lead has come loose check and refit or it could even be that your processor has stopped working or over heated and this will need replacing.
remove your ram and refit
unplug power and connector from your hd and refit only do this if you know what your doing its not difficult but give it a try and it may solve your problem, if not it could be more serious like processor cooked witch would then need replaicing.
let me know how many bleeps your getting and ill tell you what the exact problem is ok get back to me asap
Mar 02, 2010 | Computers & Internet
I have an Intel Celeron D 2.26GHz Socket 478 256 k /FSB 533. Is it possible to replace the Pentium 4 1.6GHz in the Vectra with the Celeron. If so what steps would I take and will I have any XP COA...
You need to check with the motherboard maker. A manual would tell you and you might be able to get the info online if you search for the above model number, find the manufacturer and look up the specs. It needs to have the same socket(form factor) and support the bus speed of the new one.
Replacing a CPU is straightforward but non trivial.
Oct 12, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
you could try removing power lead then remove battery from m/b for 5 mins this will reset bios back to maufacturers settings then replace battery and power then try boot up if no luck then change motherboard
Jul 01, 2009 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
New Mobo & Processor but no Bleeps etc
Could be the power supply is not strong enough to power the system. Replace the power supply with one that is between 350 - 450 watts. This should provide ample power to the system.
Aug 05, 2008 | Computers & Internet
PC powers up but wont boot
I would start with a new power box, then a motherboard. then the hard drive.
Dec 23, 2007 | Computers & Internet
Intel Desktop Board D845WN Motherboard Logo
37 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
