Question about Epson Aculaser C1100 Printer
Epson Aculaser C1100N - Black Toner problem
I've put a black toner (when requested to) in the printer as per manual instructions and I've found that the toner seems to be dumped into the printer and running out within a few sheets use. The cartridge is being installed correctly and this hasn't happened before. The quality of print is very good but the black toner is being used ridiculously fast and during use is being emptied into the inside of the printer which has required meticulous cleaning. This has happened with the last two cartridges. Although there is toner still left in the cartridge it says Replace K Toner on the LCD. What is the problem? Is there anyway of resetting the chips to factory defaults and starting again. One of the toners that was used was an original new toner and the last one was a refilled original cartridge. I'm at my wits end! Help!
  • 1 more comment
  • reddoten Nov 20, 2007
    Great thanks for the quick reply. Can I change to the factory settings whilst the printer is warming up and calibrating? The scenario now is that I switch the printer on and after several minutes of calibrating the message comes up on the LCD Replace K Toner and at this point I cannot access any settings.
  • Anonymous Jan 07, 2008
    reddoten, I got the same problem. Did you resolve yours?
  • doug86 Jul 23, 2008
    I have the same problem. After a (very) long calibration the printer asks to replace k toner. how can I get access to the botom of the printer to see if it has just been dumped?
    also has anyone foud a solution yet?
IF the problem persists with an original cartridge then the factory settings should be restored refer the manual or go through the settings in the control panel . minimise the tone of printing . If toner is getting accumulated in the printer then it might be due to refilled toner not the original cartridge . use the original cartridges
Posted on Nov 20, 2007
Hi. Epson C3000 aculaser. It is ghosting on only on black at a pitch of +/-62mm and also printing horizontal black smudges across both side of the paper at a pitch of +/- 25mm. I have totally cleaned the...
Hi Colin.
I just have had the same problem with my Aculaser C4200.
I may have found a way to solve you problem.
Just print 10 blank (without anything), and after that i took all toner's, the fuser etc. and put it back again. Printed 10 more blank pages, and printed over 200 pages with lot of tekst and colour (think that 50 pages could do it).
After 2 days everything is still ok for me.
Sep 30, 2010 | Epson AcuLaser C3000 Printer
Where abouts is toner k
K toner is refering to black toner. Here is a link to Epson for your Aculaser C1100 Reference Guide. Look under Setup & Maintenence for >Replacing Consumable Products..... click on 'Toner Cartridge' for the proceedure.
Nov 27, 2009 | Epson Aculaser C1100 Printer
What colour is K on low ink
Toner K low refers to the black toner.
May 15, 2009 | Epson Aculaser C1100 Printer
Light print on right side of page
from what you are saying, if color is fine and black is not, its most likely the black drum that is the problem. the toner is part of it. try taking the black toner out and shaking it, and putting it back in, if it still does not help, most likely it is the toner/drum.
thanks adi
May 05, 2009 | Epson AcuLaser CX11N All-In-One Printer
Prints in black are poor quality
fist of all reunisall your printer driver ....
if problem dose not fix .
it means black colour laser section have problem so you can clean lens of laser if posible and replace laser secaner.
Apr 29, 2009 | Epson AcuLaser C4100 Printer
Toner needs black toner how do i replace just the black toner
You shoulh have a button to rotate the carousel, or unplug the power cord and try again.
Mar 03, 2009 | Epson Aculaser C1100 Printer
Black Cartridge just changed, but still says K-toner low
The only way to clear the message is to wait until the the display shows XXXX Toner Out, then change the cartridge and the message will clear itself.
May 18, 2008 | Epson AcuLaser C4000 Printer
Poor Print Quality on Epson Aculaser C1100N
Sounds like the black dev unit is worn out. Easy enough to change yourself if it is out of warranty. If it is in warranty get Epson to do it for you.
Jan 24, 2008 | Epson Aculaser C1100 Printer
Black toner low Epson Aculaser CX11NF
Try powering the unit off and on. The toner indicator does not always reset immediately in my experience
Nov 02, 2007 | Epson ACULASER CX11NF All-In-One Printer
Epson Aculaser C1100 Printer Logo
641 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
