Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
The unit produces steam but does not have the pressure to the cleaning pad. The water pump handle does not retract all the way either. Related?
  • Euro-Pro Master
  • 43,501 Answers
No, probably two different problems...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Sep 24, 2010
Steam come out from handle base
Possibly a split pipe or securing clip has come lose but if it is a cheaper unit it will be the pressure tank seal has gone, I have recently fixed one for a friend.
Mar 30, 2014 | Shark Vac Then Steam Mop MV2010 NEW
My h2o mop won't steam. How do i fix it?
If your H2O mop will not steam:
1. Ensure you have followed the operating instructions.
2. Ensure you have followed the troubleshooting instructions.
If the unit fails to produce steam:
3. Switch off the power at the outlet.
4. Look at the water reservoir. Inside you will see a flexible tube with a cone on the end. Tilt the unit or give it a gentle shake to submerge the cone in water.
5. With the cone submerged, switch on the power supply and follow the normal instructions. The unit should produce steam as normal.
Note: Unless the cone is submerged in water, the unit will not steam.
Apr 21, 2012 | H2o TR220002 Steam Cleaner
My Hometek Steam Penguin wont produce steam
Hi
I opened whole thing and found that no suction to the pump or pressure from the pump. Opened the clear box which contains the pump and the el-motor. Then I opened the white pump and found it was assembled wrong way round. There are two tiny one way silicon "valves" which should produce the flow of the water to the heater. I also wiped off part of the sticky grease away. Now it works. 4 hours work, but it was interesting to learn the function :) .
Anssi
Apr 09, 2012 | Euro-Pro Steam Penguin Hard Surface Steam...
My shark steams at the bottom of the handle but not at the foot of the mop. What is the problem?
sounds like the steam hose between the handle and the floor pad has a blockage in it and / or the pad exit holes are blocked with debris. clean and clear holes and hose and this should restore the unit to working condition.
c...
Jan 03, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Steam Mop - Gray/ Purple Vacuum: I left water in the steam mop and now the steam is...
heatman101
k
May 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My mop would produce steam. It gets hot but when
heatman101
xxxx
Jan 24, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark stopped steaming how to fix this
It may be mineral deposits. Empty reservoir of water, add 1/2 cup of CLR. Let sit 1 hour. Take mop outside with a mop head on but not the cloth padding. Plug it in and start pumping the handle to prime it. I used cardboard to do this on to cushion the mop and soak up moisture. Keep pumping handle until the mineral deposits clear and full steam is coming out. When I was done, I unplugged the mop, dumped out remaining CLR, and rinsed out mop reservoir with water. Please add fresh water, plug in and steam out rest of CLR out of tube leading to mop head. Otherwise your mop will still issue out CLR steam. As always, be careful to unplug and let the unit cool down before adding or removing CLR, water or mop head. Steam can cause serious burns.
Nov 21, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
The lid was stuck for a year and when i finally got it open and tried to use it is has all this white stuff in it and won't produce steam much. how do i clean it out? can i use ctr?
Put a cup of WHITE vinegar in it, shake it u and let it set for 20 minutes. Pour out 1/2 of the vinegar and replace it with water. Plug it in and it SHOULD melt the deposits away. If you still don't get pressure, clean the rim where the seal fits, with scotch brite or a good fine abrasive pad. You can soak the pad with vinegar to help the process.
Jun 15, 2009 | Scunci 52067 Handheld Steam Vacuum
Stopped steaming only releases water into pad
heatman101
ag
Mar 22, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
163 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
