Question about Carrier Heating & Cooling
My AC unit is a carrier LCA061P window unit. It works okay but has recently started to make a loud clatter. I would like to replace whatever parts that are needed but can't seem to find any relevant information. I suspect the problem is a blower fan (rotary) that sits beneath the top channel in the front grill.
    Problem Solver:
  • 10 Answers
Good possibility. WIth the unit powered off and unplugged check the clearance of the wheel and the collection basin underneath, Debris could be the source but I suspect the bearing is failing on the motor
Posted on Oct 21, 2009
Want to know how many btu lca061p
6050BTU
Carrier LCA061P 6050 BTU Thru-Wall/Window Air Conditioner
Jul 11, 2012 | Carrier LCA061P Air Conditioner
I have cleaned the drain holes, filter, coils, etc; however, water is building up in the front of the unit and the fan starts making a loud clattering noise. There is no water built up in the back;...
If your a/c have a housing, set the upper front side 1/2" away from the wall and the lower front side 1 1/2" away from the wall. Some units with plastic base pan should be inclined more defending on the height of the drain line fitted in each model.
Sep 02, 2011 | LG Electronic Window Air Conditioner
I have a carrier visionaire model LCA061P and i am in need of the fan assembly or part # for it it. any help would be appricated
Something fell from the roof and broke the top (outside) of my
visionair a/c unit. Can I replace the part? It's near the circle on
top and finally part broke away and can't be found
Smurfsters@aol.com
Aug 13, 2010 | Carrier LCA061P Air Conditioner
It is very loud inside when turned on. the noise sounds like a loud rumbleling noise.
Is this a window unit, a whole house AC, or a Split package type?
If it is a window unit remove the front cover, reach in and see if the blower fan teeters on the mother shaft. If it does the blower fan center hub has failed and the fan will need replaced. (I have changed 2 blower fans on my Carrier 19,800BTU window units that run 23 hours a day.) They just fail over time. Who knows why.
Kelly
Feb 23, 2010 | Heating & Cooling
I'm looking for a relacement knob for my airconditioner make General Electric window
look in phone book for a company called johnstone most of the time they will sell those kind of parts to general public
Sep 11, 2009 | Carrier LCA061P Air Conditioner
A/C unit clatters very loud
90% of the problem with window shakers is the window that they are installed in is loss in the frame. When the unit is installed in the window you need to make sure that you install vibration eliminaters. This can be as simple as placing the foam strips between the unit and the bottom of the window you raised to install the unit through or as complex as removing the unit from its casing and reinstalling the casing, making sure all parts that touch the raised window as well as the side extensions have a cushion between them. If the clatter persists gently tap on the sash to see if you get any vibration, if so you need to insert slivers of wood between the sash and the moulding. This should solve you problem. The only thing you should hear is the compressor going on and off and the whosh of the fan.
Aug 21, 2009 | GE AGW18DH Electronic Room Air Conditioner
Heating & Cooling Logo
130 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
