Question about Hitachi 53UDX10B 53" Rear Projection Television
50VS69A will not trun on, Lights just flash
My Hitachi has only about 1500 hrs on but will not start anymore. When I switch on. The Blue light, Red temp light and red lamp light flash in that order but tv will not fire up.
Would this be a burned out lamp with such short hrs on the tv?
Fan is nice and clean and sounds like it is working ok. I tried unplugging for a few hrs. I tried holding start button in but it just turns itself off after a few seconds.
TV is less than two years old and has very little use... Hitachi customer support will not tell me a thing... Last Hitachi product I will buy... Advice very much appreciated before it goes to the dump..
  • 691 Answers
Its really hard to tell without being there to see what its actrually doing, Im asumed is out of warranty and few things you can do yourself. go ahead since its projection tv is to open the back up and check the fuses and the lamp, make sure is unplug and use a good lighting so you can truly see clear of the circuits board. some boad will have its own fuses and check them all make sure they are good. pull the lamp out and check it. projector tv are not hard to work on since is big and easy access behind the TV. to test the lamp you can take it to the local tv shop and have it tested for nothing. If all the lamp and fuses check out fine to fix your problems I would not think it will cost more than 150-200 to fix it. hope that help some ..Good luck
Posted on Jul 16, 2009
My hitachi tv will turn off and the red and blue lights flash for about one minute and it will turn back on.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 11, 2016 | Hitachi Televison & Video
My hitachi 50vs69a tv wont turn on and after afew blinking red li
Have you replaced the lamp? Unplug the set remove the lamp and see if it's blown
Sep 20, 2009 | Hitachi 50VS69 50" Projection HDTV
My hitachi 50VS69A tv shows the picture green.
A green image is usually due to a lack of red or especially blue. the problem is becoming all too common with hitachi lcd projection sets. what happens is that one of the lenses in the optical block (or light engine) starts to burn or discolor due to overheating because of a blocked air filter causing poor air (cooling) circulation. Nothing can be done when the damage is too far gone except to replace the light engine-at acost that makes it not worth repair. if the damage is minimal than to reduce further damage the air filter should be replaced. Light engine needsto be removed in order to replace the air filter.
Sep 04, 2009 | Hitachi 50VS69 50" Projection HDTV
Have a 50VS69A the blue light comes on then a second later the two red lights flash in sequence from top to bottom.
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Mar 08, 2009 | Hitachi 50UX58B 50" Rear Projection...
Hitachi 50vs69a Rear projection TV. The t.v was on and suddenly the screen went black and the temprature and lamp red lights are flashing until i turn the t.v off. i tryed turning the t.v on and off but...
Check your door that holds the lamp assembly. It will turn of the power to the bulb if ajar at all, the switch responsible for this function may be fried aswell.
Feb 02, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 53UDX10B 53" Rear Projection Television Logo
249 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
