Question about RCA Scenium D40W20 40" Rear Projection HDTV
GE HDTV Model D40GW10 will not turn on right away
When you hit the power button it takes a minute or two to come on and recently it has gone off while we were watching it. After a few mins it comes back on. What to do?
No sound
Posted on Sep 04, 2011
Ge hdtv mod #d40GW10 will not turn power button flashes 2 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Feb 28, 2016 | Televison & Video
Broken GE HDTV - Need Help To Fix
The deflection board needs replacement. The chirping is indicating the deflection circuit has an issue. You can get a replacement deflection board from www.tvrepairworld.com which includes instructions on how to remove and replace the board.
May 26, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
I have a 52" GE-HDTV/Monitor. After the unit is turned off, it will not come back on-at all now. When I try to turn it on, the green light on the front of the TV comes on briefly, then goes off. I can...
replace CP150 CP114 and CP120 all three capacitors are available at the following link with free instructions they are listed under the RCA parts category which are the same ones for your GE TV.
http://servicemanuals.vstore.ca/
Jan 17, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Blue Horizontal arching lines, Blue hue at power on
if you take the front cover off the tv, you will see 6 little nobe, the top 3 are focus, bottom 3 are brightness, should be RED-BLUE-GREEN in order from left to right, find the one that is blue, turn it down a quarter turn, should fix the problem
Dec 31, 2008 | Sony KP-46WT500 46" Rear Projection...
GE D40GW10 turns off after a minute
Yes and No it depends on what is wrong If your luky it will be 3 capacitors on Deflection board cp150 2200uf 16v and cp114 cp120 220uf 35v capacitors they are green with gold writing on them If cp150 is puffed up on top it is bad. So then replace other 2 caps.
Dec 26, 2008 | RCA Scenium D40W20 40" Rear Projection...
Codes for daewoo tv, ge remote model 24912
Codes for Daewoo are: 0451, or 0092
If this doesn't work with your new remote there is always the way that I have done it in the past and that is to use the find the code function on your new remote. It is a pain but can be done and is quite effective. Each remote is slightly different, but for the most part you would hit the set up botton and hold it in until it starts flashing then hit the T.V. Button and then hit the first code it tells you to hit and then hit the power switch if it doesn't turn off your T.V. then you hit the increment button up, (this is different for each remote so it is important to follow the instruction manual on this part) You bassically keep hitting the incriment button until your code comes up and then it will turn off your t.v.! Then your done. Note: It may take up to 400 pushes of the increment button, but it will work.
Dec 13, 2008 | GE JASRM24912 Remote Control
TV Powers off
sometimes they go into "power saving mode" you should be able to dissable this in the settings
hope this hepls
regards
Nov 17, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
Complicated GE clock radio/CD player
To set the time:
Hit the SET Wake/Time Button closest to the CD player until the clock face appears in the bottom left hand of the display.
Use the TRACK Rev Search Fwd Arrows to adjust the time.
Rev will decrease by minutes and Fwd will increase by minutes.
Hope this helps.
Jan 10, 2008 | Audio Players & Recorders
RCA Scenium D40W20 40" Rear Projection HDTV Logo
82 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
