Trying to fax a document and there's a grinding noise and fax stops
    President:
  • 1,124 Answers
Sounds like the gears that control the rollers are not connecting well and/ or slipping..
Could be a broken guide that holds a gear in place..
If so - not a real easy fix unless your quite technical..
It is older with allot of use ?
Perhaps try unplugging it for several minuets in hopes to clear it..
Also - open the faxing part on top (not sure which printer you are referring to) and clean it out with air pressure - with a air-can.. Air pressure on the rollers & any gears you see..
Hope this helps ;o)
Posted on Jul 16, 2009
Grinding noise in copy mode?
The Grinding Noise has something to do with the scanner not the Printing Part, I think the scanner could have something stuck on the moving tray....!!!!!!
Apr 18, 2013 | Lexmark X8350 Print, Scan, Copy and Fax...
KX-FLB756 Grinding Noise, Unable To Print
if you have driver for this printer pls. install
thanks
alamri
Dec 24, 2011 | Panasonic KX-FLB756 Plain Paper Laser Fax
My HP J6480 ADF is making a grinding noise when I try and fax or copy documents fed thru the ADF. I have tried cleaning the rollers but that hasn't worked. Any other suggestions?
You need to locate, from where sound is coming from.
Then use wd40 or silicone grease oil, and lubricate.
its probably dirt on axis bushings.
Jul 05, 2010 | HP Office Equipment & Supplies
Scanner failure when faxing of coppying
I need help also my black ink stop working also but think it is dry and that is why it won't wor. but still have same fax and copy problem exactly even the grinding noise
Fred
Feb 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Gears grinding with Brother Intellifax 4100
Does it only make the noise when printing. Do you hear the noise when sending out faxes? I have heard grinding noises onlt when using poor quality toner refills, or the fuser gear and or drive gear asm is stripped. First try a known good OEM toner.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Mar 22, 2007 | Brother IntelliFAX 4100 Laser Fax
Fax machine jams or stops loading document for a copy or sending fax
try to open your fax machine ang check paper feed gear maybe 1teeth of gear is broken..or maybe your machine incountered feeding timing error.
Jan 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
k24674
jasbo
jasbo
