Question about Fellowes DM15C Shredder
The automatic-on function will not work - Fellowes DM15C Shredder
  • Jay Blair
    Jay Blair May 11, 2010
    What model is it? Do any lights come on?
  • 328 Answers
What model is it? Do any lights come on? All shredders auto shut off after a while.
Posted on Jul 22, 2009
My whirlpool Fully automatic washing machine is not functioning properly,what can I do to repair it?
Check to see if the machine has touched the on off tap at the back during spinning and cut off water supply.Or check the penny trap at the bottom of machine.if both are okay the it is likely to be down to faulty board or impeller motor which helps the flow of water into machine.
Nov 19, 2014 | Whirlpool Washing Machines
Programming presser foot lift
hello Michelle
regarding presser foot lifter function please follow next points:
1-turn power ON with ( i ) button held pressed for two second.
2- at left hand there\'s screen with two digit ( function No.) and at right hand there\'s screen with four digit ( value of function ).
3- go to function number ( 21 ) it was ( function of neutral presser lifting ) change the value from - or + to ( 1 ).
1: function of presser lifting activated.
0: function of presser lifting not activated
4- change function 21 to 22 or 15 to save your changing.
5- turn power off then turn ON again. presser lifting was working.
if you need more information please just send email to me.
thanks and best regards
Mar 15, 2014 | Juki DDL-8700
Easy in/out function on Mercedes E350 doesn't work
I will try to help. If the function is to move the seat automatically for entering or exiting the vehicle, then this function is often on a Menu list. Sometimes when an oilchange place resets the oil change interval, the wrong button gets pushed and wipes out the settings for something else, like your in and out assist. It may also happen if the Battery was disconnected.
Now if the power to the seat has a broken fuse, you should check your sseat controls to see if they still move. If not a fuse needs to be changed and a repair made. The loss of power to the seat motor is the reason the automatic movement does not work.
If the steering wheel and column is also tied in to easy access, it may be fused separately and still work.
Sep 30, 2012 | 2007 Mercedes-Benz E 350
How to set the time on dmr eh59
Automatic clock setting is done if you initially accept to use the guide plus system (should do). Only if for some reason it does not work, you can set the clock manually following these steps Clock Usually, the unit's setup function automatically adjusts the
clock to correct time. Under some reception conditions, however,
the unit cannot set the clock automatically.
In this case, follow the operation steps below to manually set the clock.
1 Press [3, 4] to select "Off" of "Automatic" and press
[OK].
2 Press [2, 1] to select the item you want to change.
The items change as follows:
Hour,Minute,Second,Day,Month.Year
3 Press [3, 4] to change the setting.
You can also use the numbered buttons for setting.
4 Press [OK] when you have finished the settings.
The clock starts.
If a TV station transmits a time setting signal, and when
"Automatic" in the Clock setting menu is set to "On", the automatic
time correction function checks the time and if necessary it is
adjusted several times every day.
Sep 25, 2012 | Panasonic DMR-EH59 250GB Multi Zone Region...
Not functional automatic transmission
Check your the rear break light and switch function. If both of them working fine, need an overhaul or replacement of your automatic transmision
Nov 17, 2010 | 1997 Mazda Protege
Converting a turntable from automatic to manual
I suppose the only way to do it would be to stop it functioning completely. The only way would be to dissasemble the auto function. What you would need to do is work out which parts are essential for the turntable operation and which only activate the return. So you need to whatch the mechanism working. You will need to remove the base and look at from underneath, just like going underneath a car!
I can't say for certain if you can do it, only you will be able to determine it can be removed without affecting the operation of the entire turntable.
May 21, 2010 | Pioneer PL-990 Turntable
All my automatic functions(lights, A/C, locks
check your fuses,if its done bu a button key maybe the battery has gone inside it? i should think it would be one of the two because the should not all not work at once. hope this helps
Mar 17, 2010 | 2000 Lexus RX 300
I cannot get the functions on the remote to operate.ie pbass dsp/eq etc?
The P.BASS function is only available with 2 channel LPCM sources such as mp3,Divx,cd
and wma. Press P.BASS button and "POWER BASS ON" will be displayed on the screen.
The P.bass does not work with DSP/EQ or DOLBY PRO LOGIC ll modes.
If you press P.BASS in the DSP/EQ mode, the DSP/EQ mode is automatically shut off and the P. BASS function comes on.
The DSP/EQ function is only available in STEREO mode.
Press the PL ii mode button to show STEREO on the display.
This feature works with CDs, MP3-CDs, 2 channel DVD-Audio, DivX and Dolby Digital discs.
When playing a DVD disc encoded with two or more channels, multi-channel mode will be selected automatically and DSP/EQ function does not work.
Nov 04, 2008 | Samsung HT-Z310T Theater System
Auto Function Failed
It could be a communication error between the flash and the camera. Check the shoe foot for any damage or stuck pins. All of them must make proper contact with the hot shoe on the camera to get full auto/TTL, same for the shoe of the camera, bent? dirty contacts?
Dec 31, 2007 | Nikon SB-28DX TTL Flash
Fellowes DM15C Shredder Logo
120 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
