Question about Maytag Neptune FAV6800AW Top Load Washer
The touch pad lights start going on randomly and beeping when trying to start the washer. It is a Maytag Neptune TL model #FAV6800AWW, serial #11697330EN. The machine will finally start but the indicating lights for spin keep changing position and constant beeping.
  • cris7580 Jul 16, 2009
    I would like to eliminate one of the boards by testing. What is the procedure. Should I refer to the testing procedure in the manual in the machine? The warranty on the boards run out in one more month. I already removed the control board and all cable connections. I reinstalled and the machine stopped its random search of modes and beeping for about 5 minutes and then started again. The machine will go through the proper wash cycle but the random lights and beeping persist.
  • cris7580 Jul 17, 2009
    I going to go with the touch pad
  • 15,935 Answers
This is indicative of a faulty control board....
#23 in THIS DIAGRAM
CLICK HERE to see the replacement part.
...or a faulty touch pad.
CLICK HERE
Without testing each independently, you will end up throwing money at it blindly.
Call a service tech for troubleshooting and testing both pieces.
Thanks for using FixYa - please accept this answer to remove it from the work queue.
:D
Posted on Jul 16, 2009
  • blueextc3221
    blueextc3221 Jul 16, 2009
    You can try the diagnostic in the manual - however that will not reveal if it is the touchpad or control board.
    It is my experience on this model that the touch pad is the culprit in most situations of dancing and erratic lights - especially when there are no errors given on the display.
    There is no test for it but to send it in to maytag for them to check.
    Same with the Control board. You will get all the voltages the service manual states - but the controller is Logic based - not mechanical... a computer diagnostic is what is necessary.
    If they are both under warranty - have them both checked!
  • blueextc3221
    especially - if the machine will wash normally without stopping - is the best indicator the touch panel is bad.
Neptune TL Washer FAV6800AWW need owners manual
Google This ""Neptune TL Washer FAV6800AWW""
5th post down is a link for the FAV6800A/FAV9800A SM.
Aug 18, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Fav6800aww machine wont stay balanced move the clothes around it starts back up for about one minute then stops code comes up dc thanks earl
Google this; Neptune TL Washer FAV6800AWW
This is a DIY Appliance repair forum and you can get the Service Manual and repair support at that site..
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800AWW top load machine.
In that Sticky I discuss what is the cause of DC or UC unbalance errors and the fix.
Apr 14, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag Neptune TL ( Model # FAV6800AWW) washing machine does spend but clothes still soak after it done. when you spend it by hand, it only spend in counterclockwise.
Any error codes. What happens if you start a Spin Only Cycle witht the same load? Does the times stay stuck at xx minutes in the LED display and the machine constantely starts and stops?
The more info on your problem the better.
Do you want to DIY the fix? Google this; Neptune TL Washer FAV6800AWW see the 5th post down here for general info and the Service Manual. If you want to try to DIY the repair I will help.
Apr 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl error op
You have lost signaling thru the Left Hand Lid lock or you could have a Lid Magnet out of posistion;
Google Neptune TL Washer FAV6800AWW
6 or so post down and I have service notes to help you troubleshoot.
Mar 13, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My MAytag will not spin the water outta my clothes on spin cycle
If you machine is a FAV6800A or FAV9800A don't worry about the last two letters of the model number.
If you need help post in the Maytag/Magic Chef/Admiral/Jenn-Air forum with your issue and we will try to help.
Feb 28, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl what is code Lr
LR is the error code for Locked Rotor.
This could be an issue with the Motor Controller or Control Board.
I have not seen Drive Motor cause this issue to date.
If you want to investigate further I would suggest getting the FAV6800A/FAV9800A Service Manual.
Google this ""Neptune TL Washer FAV6800AWW""
This is a sticky for the FAV6800A/FAV9800A washer DIY support. Go to the 5th post down in the Sticky and you will find a link for the Service Manual.
If you want to go further in troubleshooting and possibly a DIY fix just open a new thread in that DIY forum with Model number and Serial number. That info is found tag behind the console right back side as you face the machine console.
Feb 24, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My washer starts and after about 5 minutes gives out... i get an nf code... anyone dealt with this
That's a No Fill error code. Is there any water flowing into your machine?
May be a block in the in the Water Inlet Valve. If it was false I feel you would have to break out the mop for flood/over fill condition. Did you try to fill with a mix like Warm/Warm selction?
If you want to troubleshoot further go to a real DIY forum.
Google this Neptune TL Washer FAV6800AWW
Feb 16, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag TL fav6800aww won't start wash cycle.Pause light flashes ,won't go into diagnosis mode.No codes shown
I'm sure you power cycled the machine if not give it a try.
This could be a Control Board issue or a Console issue. I would replace the Control Board 1st.
I have working Control Board's and Console's. With an issue like this it's difficult to troubleshoot if you can't get into Service Mode to at least look for a starting point.
Do the key pad keys beep if you press them?
You could try to do some basic Ohm meter checks This post discused. My 1st choice with that issue was a Control board swap and it turned out to be a Console issue.
Jan 28, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune key pad ocassional working
The machine control pad, with the LED lights, is going out. Replace this control pad and all lights should be working normally again.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 10, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
52 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
