Question about HP Officejet Pro L7650 Printer
When faxing a document the paper feeds half way and then there's a noise and the fax gets stuck
  • HP Master
  • 19,396 Answers
Check for fragments of papers or foreign objects inside the printer.
Ensure that the printer phone cable is connected, and that there is signal , otherwise it may be hanging on just because no signal is detected.
If this happens only when faxing, and does not happen when scanning and printing paper then the problem is software related.
Test to see if you get the problem doing a regular copy (Scan and Print).
If you do not get the problem, then try uninstalling the printer software and installing it again.
Regards.
Posted on Jul 16, 2009
Whats the scan platform
Scan platform in english is Were you shove the stuff to send ;) ie dirty feed roller, paper detect switch stuck or fragments of paper in original feeding paper path area or feeding stuff too thick or stiff, or if multi document issue it is the pad or roller that sits under the main feed roller...al this is nothiong to do with paper tray full of blanks it is the original feeler area on top..
Same error should occur doing local copy, check feed section/roller
Cheers hope that helps
Nov 19, 2009 | Canon FAX-L1000 Plain Paper Laser
Can't fax or copy on brother mfc3240c machine
Sounds like you may have a small obstruction in the scanner feed. This would inhibit making copies and sending faxes. Lift this section up slightly to inspect for small pieces of paper or dust. Blowing it out with compressed air would also be a good idea.
Aug 20, 2009 | Office Equipment & Supplies
Paper jam in Panasonic KX-
Your document feed is separate from your received and report prints so that's why your reports are printing ok and the document feeder jams. When you open up the doc feeder and look inside the machine you will see a roller and above it on the cover that opens you will see a rubber pad. Clean both the roller and pad (in fact anything in there that is rubber) with a rubber cleaner, alcohol, or even soap and water on a cloth without it been dripping wet. You will probablt find that they are very dirty. The roller feeds the document in so that needs to be clean and the pad helps to keep all the other docs from feeding in at the same time and that should be very clean so it produces good friction.
Jul 07, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
When I send a fax from my Brother Intellifax 2800, the person receiving the fax gets the fax but there is an inch and half black bar along the right side of the document. If I make a copy, the same...
Either, you have a dirty contact sensor glass (and I hope that is the case) or your contact sensor has a faulty section. The contact sensor is basically the method which your machine uses to scan documents. Even machines with a lamp and mirrors have a slip glass that can get dirty as well as mirrors. Lift up the doc feeder to reveal the glass strip that the document feeds across, you may notice it light up when you lift the cover up or touch the document sensor arm. Hopefully, there is dirt (usually tippex or white out) stuck on the glass in that particular area. Use a alcohol cleaner to remove those stubborn types of dirt and in future let the tippex or white out dry before scanning. It may even be the gum from a post it pad which is harder to see as you look into the feeder but just clean that glass well and hope that you don't need a new contact sensor. Maybe there's paper stuck there.
Jul 06, 2009 | Brother IntelliFAX 2800 Laser Fax
We have a Brother FAX-1840c. It will jam feeding paper into the scanner. I maintenance mode it returns an A1 error code. Feed rollers look serviceable and the pressure pad is clean. Stops half way thru...
Hi
There must be some torn paper or something stuck in the Paper feed. You will need to ope the upper face portion by pulling it, and then look for papers/ dirt / pins there, you can either clean it by blowing air or use a blower, or if you can see the particle. Try feeding the paper, it should be ok.
Jan 27, 2009 | Brother IntelliFAX 1840C Plain Paper...
Paper feed not feeding properly
There is a gray rubber pad on the upper half of the feeder.
Take the white piece off and turn the pad 180 degrees.
Aug 28, 2008 | Samsung SF-560 Plain Paper Laser Fax
Paper won't feed from drawer - stuck on "manual feed"
The readout on my intellifax 2820 says, Document Jam, clear the scanner jam, then press the stop key. I can't get it to clear. What should I do?
May 03, 2008 | Brother IntelliFax-2820 Laser Fax
NOISE OR PAPER GETTING STUCK IN FAX MACHINE WHILE SENDING FAX
look in or around scanner area to see if there is any foriegn material trapped in paper handling area.
This is area where the original document feeds through
Jan 22, 2008 | Brother IntelliFAX 2800 Laser Fax
Outgoing fax makes loud clicking noise
2 different problems here. 1st is with document feed and 2 is with paper feed.
1st prob seems to be with the paper feed roller not meshing at the gear. Probably a broken piece on the lower document tray assembly. No real fix for this unless you can strip it out and haywire it.
2nd prob is probably a poorly meshing drum unit. Examine the gear teeth on both the drum and the machine. As you have replaced the drum already (presumably with a brand new one) You might possibly find a missing or badly worn tooth on the messhing gear in the machine.
Oct 02, 2007 | Brother IntelliFAX 2800 Laser Fax
The document feeder keeps trying to feed
You have a bad Document transfer sensor. Sensor is located under the doc. transfer roller.
Nov 15, 2006 | Sharp FO 6600 Plain Paper Laser Fax
HP Officejet Pro L7650 Printer Logo
Seeker5211
Seeker5211
