Question about E-Machines eMachines Desktop PC
REBOOT AND SELECT PROPER BOOT DEVICE OR INSERT BOOT MEDIA IN SELE
CON'T-------SELECTED BOOT DRIVE
INITIALLY I COULD NOT OPEN MY DISC DRIVE (CD) I OPENED THE SIDE PANEL OF THE COMPUTER LOOKING TO SEE IF THERE WAS A CONNECTION TO OPEN THE STUCK DRIVE. I SAW A BELT AND DISCONNETED IT AND REALIZED BY THE MESSAGE ON THE COMPUTER THAT IT WAS THE HARD DRIVE I DISCONNECTED. I RE PLUGED IT IMMEDIATELY AND THAT IS WHEN I RECEIVED THE MESSAGE IN THE DOS SCREEN THAT I NEED TO REBOOT
Reboot & proper boot device how to slove the proble
Posted on Mar 05, 2010
  • 81 Answers
1, to open your cd drive manually, get a tooth pick, look closely onto your cd drive i mean where the cd comes out from when ejected, you will see a very tiny hole put the tooth pick inside the hole push it in a bit hard then bring out if it does not try a tinier object it will come out.
2, if the system was on when u disconnected the belt it might have burnt the hdd or has caused error on the hdd, off the computer and reboot if no solution, reformatt the system if it does not work, get a new hdd. thanks
Posted on Jul 16, 2009
My pc wont boot. All i get is " reboot and select proper boot device or insert boot media in selected boot device and press a key"
This can happen if you have non-bootable media in the default boot device (i.e., you have a CD in the CD/DVD drive and that drive is listed as the default boot device in your system's BIOS). More often (on newer systems), a failed hard drive will also produce this message.
If you have bootable media (the Windows install CD is one example), you should try to boot to it and see if you can read your hard drive.
Jan 20, 2014 | Computers & Internet
Hello, My laptop shows the following message when I turn it on- Realtek PCIe FE Family controller Series v1.19(08/10/09) PXE-EGI-Media test failure,check cable PXE-MOF-Exiting PXE ROM Reboot an
It can't locate a working boot disc. Most likely lost communications with hard drive. Look in BIOS again to see it recognizes the drive. If not try re-seating / reconnecting drive.
Feb 16, 2013 | Dell Inspiron N5010 Black
What if disk drive does not open during system says reboot and selesct proper booot device
Sounds like you may have a CD/DVD in the drive that is stuck and/or not inserted properly. There should be a small, pin-size opening on the front plate of the CD drive. Find a large paper clip, bend out one end of it then insert into the pin-hole. Push it until the drive pops open.
Aug 10, 2012 | Toshiba Satellite P755-s5320
Reboot and select proper boot device
You cannot start a virtual machine in Microsoft Virtual PC 2004 Service Pack 1 (SP1) or in Microsoft Virtual Server 2005 from a third-party startup CD or from an ISO file that contains a third-party startup CD image.
When you start a virtual machine that does not have a guest operating system, you receive the following warning message:
Reboot and Select proper Boot device or Insert Boot Media in selected Boot device.
If you insert a startup CD for the operating system into the physical CD drive, or drag an ISO file that contains a startup CD image to the CD icon in the status bar of the virtual machine
window, and then press ENTER, Virtual PC 2004 and Virtual Server 2005 will ignore the operating system that is on the CD or on the CD image.
hope this helps
Jul 14, 2012 | Dell Computers & Internet
Help with reboot message for Asus G1 notebook.
Sounds like its trying to boot from the Optical drive (cd/dvd drive) thats empty or has no disc in it. You will need to get into the BIOS and change the boot sequence. Select HDDR 1st to boot from your C: drive where your OS is.
Dec 15, 2011 | ASUS G1 Notebook
WHEN I TURN MY NETBOOK ON IT SAYS " REBOOT AND
If you have a CD or DVD in the internal drive, remove it and reboot. If the system does not have a drive then you may be experiencing HD Failure and the system will not identify its main hard drive to boot from.
Feb 28, 2011 | Computers & Internet
Hp compact mini n110 when you switch on says reboot and select proper boot device or insert boot media in selected boot device and press any key can anybody says whats gone wrong?
Dear User,
Please ensure that the first device under Bios is Hard drive and there shoud be any external device like pen/flash drive is connected and or disc in optical drive. If everything is proper then it seems to be issue with you hard drive.
Regards,
Tech_Comp
Feb 24, 2011 | Computers & Internet
Hp pavilion a530n will not boot for cd it says not hard drive found reboot and select proper boot device or insert boot media in selected boot device
Need to set it to boot onthe CD drive.To boot on CD drive;
1-at start up press F2
2-At BIOS select BOOT option and move the CD drive to the fist option using the keyboard arrows.F10 to save and exit.
Oct 26, 2010 | HP Pavilion A530n (DW234A#ABA) PC Desktop
Reboot and select proper boot device or insert boot media
its basically telling you that your master hard drive with O/S installation cannot be found in the booting system...Check if your master HD is not corrupted and see if your O/S still exist or maybe wiped out..
Mar 31, 2010 | Computers & Internet
System error
Sounds like your hard drive maybe had it. Try to do a repair with your windows disc.
Mar 17, 2009 | HP Compaq Presario SR2011WM PC Desktop
E-Machines eMachines Desktop PC Logo
746 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
