SOURCE: Side mirror is loose
Housing or just the mirror? Most mirrors are glued to their holders these days.
SOURCE: 99 Astro lift door latch left side inoperative
I slammed the door shut one time and the door wood not open at all. I had to take the inside door handle off and found that the cables simply came off of their post (inside the door) on the outside part of the door handle. More than likely only one cable has come off its post on your van. I hope this helps!
SOURCE: seat back mechanism broken
my 99 explorer was on a recall for the same thing and they fixed it for free like 8 months ago
SOURCE: Lift gate won't unlatch on left side
Van has dutch doors in rear; the lift gate electronic mechanism seems fine as it unlatches on the right side, but will not unlatch on left side
SOURCE: 4 Door. Drivers side rear window has dropped down
window regulator has failed. Look for an after market one the GM replacement is junk. Usually it is a clip that holds the cable to run window up and down. probably a safety clip used if someone gets cought in the window, GM will charge you over $400 for the fix. not hard I have it down to about 30 min. and around $100 for the regulator.
