Purchased Rowe laser star juke box. Loaded juke box with original cds and burned cds. Worked fine the first night we used it. Next day, issues were it would play one song off of a cd, then the second song it would cut off short, then the next song selection would not play at all. Let it set for about 15 minutes and then it would start the same process all over again. Could something getting hot be causing this? Please I need help!
SOURCE: Song Programming
With regards to your problem with the Rowe Ami 100 cd jukebox.
Do you have a manual, if not I suggest you buy a printer manual or one on CD and refer to the Programming and Installation section.
In order for the jukebox to know about the cd's that are installed in the jukebox it has to initialize all or the changed cd's that have been replaced within the jukebox.
Put the jukebox into the Service Mode (the service mode should appear on the display)
Type 3 to select the Initialize sub menu
Type 0 and full initialize will appear on the display
Press Popular to start the initialization
Place the jukebox service switch into the normal mode
Initiazation will take around 30 minutes to complete.
Regards
Alan Hood
ami-man
SOURCE: I have rowe ami jukebox Eagle Laser Star and its
No don't do that. Take it to someone who services amps. They're all pretty much the same. Usually a couple of final-stage transistors are **** or the power supply is troubled. Good luck though!
SOURCE: Rowe Jukebox CD-100E. When I turn it on the
AT THIS TIME YOU ARE NOT SURE IF THE PROBLEM IS IN THE LASER ASSEMBLY, OR THE AMPLIFIER?
BORROW OR RENT, AN AMPLIFIER HOOK IT UP TO THE OUT PUT ON THE LASER OUT PUT ON THE LASER CD OUT PUT. LOOK AT LASER UNIT IT HAS A MARKING ON IT THAT SAYS AUDIO OUT PUT. PUT CABLE TO A SECOND AMPLIFIER.
THAT WAY IF IT STILL FADES. THEN THE CD LASER IS THE PROBLEM . IF THE SOUND IS GOOD THEN THE AMPLIFIER IS AT FAULT
DOCTOR FIX IT
SOURCE: Rowe Jukebox Model R-93
I suggest that you get a manual from www.victoryglass.com if you do not already have on, all the instructions for setting up the CCC will be in the manual.
Regards
Alan Hood
ami-man
