Question about Dell Inspiron 6400 Notebook
Dell Inspiron 6400 - Screen visibility problems
Hi, I have started having problems with my Dell Inspiron 6400 when I power it on. The laptop boots up but I cannot see anything on the scree. Tried adjusting the angle of the screen and can dimly see the desktop when the laptop is fully open. Eventually after powering on and off many times the desktop appears and the will laptop will then successfully power on repeatedly. I am completely baffled...has anyone got any ideas??
  • Dell Master
  • 32,281 Answers
This could be a faulty video cable or connector or CCFL lamp or inverter.
Try reseating the video cable/connector that connects to the motherboard first.
If this doesn't work then to determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jul 17, 2009
Hi I have Inspiron 6400 laptop and the problem, it...
Here are some tips
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
If the system is posting but will not boot to Windows, then try re-seating the drive, resetting BIOS defaults and running diags on the HDD (Fn+Power Button to start diags)
May 21, 2010 | Dell Inspiron 6400 Notebook
Static noise and black screen
hi..
Based on what you are stating, could be power supply problem. Try replacing power supply adapter that Dell supplies. Go on Dell support page using your computer number and you can see if there are any manufacturers recall on the computer or the power supply...
Aug 18, 2009 | Dell Inspiron 6400 Notebook
My Dell Inspiron 6400 laptop battery isn't charging, I think :(
Debby
Try booting without the battery installed. You probably will have no change but this eliminates the battery as a source of the problem. If it doesn't boot and you are sure that the external power supply is ok, you probably have a bad motherboard. At that point, the unit needs to be checked out by a pro or a really competent amateur.
Aug 01, 2009 | Dell Inspiron 6400 Notebook
Cannot get by dell screen to come back on once it hibernates
sounds like a power scheme setting is shutting off your monitor after a time-out period. sometimes monitor will not return without re-boot. change your power options settings in control panel.
May 16, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron password fault
Hi my inspiron 6400 cannot boot up after trying several time .I press switch on, then after 3 second it goes off again.Battery fully charge.
1)battery new
2)rep used mother board
3)rep touch pad
4)rep keyboard
I hope anyone that know this fault .Kindly help me with the issue.
Mar 08, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 screen problem
I had the same problem. You need a new graphics card.
Jan 08, 2009 | Dell Inspiron 6000 Notebook
Dell inspiron 6400 system responding very slow on ac adaptor
FIRST REPLACE YOUR BATTERY, THEN ALSO CHECK VIRUS WITH AN UPDATED VIRUS CLEANER.
Nov 20, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
468 people viewed this question
Alun Cox
