I can not get my tv to turn on by hand or remote. I have checked both the tv and the electric conections
  • 1,606 Answers
Unfortunately this sounds like part of the power section inside has failed on you. If you are still seeing a power light but it won't turn on this is typical. Basically it won't come out of standby if it shows some life. Normally the part that will fail and cause this is worth somewhere between 25 cents and at most $4 or so. The labor to replace that can run many times that amount.
If there is a local repair shop they should be able to fix it fairly inexpensively. Get an estimate before letting them fix it just to be sure you don't end up with a surprise and make sure it is or isn't under warranty.
Posted on Jul 16, 2009
I need tv codes for a sharp tv for the universal conect it Rm400 Remote
0038,0019,0058,0022,0019,0000 are the codes to check. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 08, 2013 | Conect It RM400 Multi-Brand Universal...
Codes for a conect rm500 remote
I have a RCA MODEL TV 27V514T and a conect-it RM500 UNIVERSAL REMOTE CONTROL I just need the code to program my TV. Please help me.
Feb 26, 2013 | Conect It RM500 Multi-Brand Universal...
Trying to program LG remote to Samsung Blu-Ray
i wanted to program lg plasma smart tv remote with samsung blu ray,was so easy! with tv on conect blu ray hdmi to tv and press simplelink button on remote, and automaticly turns blu ray on.... thats all !!!! u can use only remote when watching movies...
Jun 16, 2012 | LG Mkj40653801 Remote Control
Cant find out how to hook up the wires for my pioneer deh-p4200ub to my 94 pontiac firebird its maken me very mad
the best way to conect ur stereo shud have electric tester always find the positive and the negetive in the car wires its mostly black -,red + once those conected to the stereo last but not least the blue remote wire for memorie thoes 3 conected set shud turn on and if it dnt u may have burnd out ur fuse check ur car fuse stereo fuse!
Aug 24, 2010 | Pioneer DEH-P4000UB CD Player
The 'hand' on screen
Make sure that the Sensor Bar is setup correctly:
Check the cord on the Sensor Bar for any frayed wires or kinks, and verify that the Sensor Bar is free of obstructions.
Verify that the Wii Remote is being used between 3 and 8 feet directly in front of the TV, and that the Sensor Bar is placed properly (see Sensor Bar setup).
Verify that there are no bright light sources, including sunlight, behind or near the TV, shining towards the Wii Remote or reflecting off the TV screen. Also verify there are no heat sources (such as electric, propane or kerosene heaters, flames from fireplaces or candles, stoves, etc.). If there are bright lights shinning directly behind the TV or on the screen, turn the lights off.
If problem persist your Wii Remote need service.
Oct 21, 2009 | Nintendo Wii Console
The remote continues displaying a low battery signal. i have tried to sit the control on the cradle but it doesn't seem to sit well, therefore it can't receive a charge. do i need to buy a new battery or...
your remote charges in a base, is the tv very old or new, if its under warranty check where you bought it, if its not, see if you can replace the batteries in the remote, they will get old and malfunction, they are probably small batteries like go in a heraring aid or computer, if there are several, one can go bad causing the others to go bad, clean the terminals on the pad and remote, use a pencil eraser, to clean them, sometimes they spill coke or just your hand can contaminate the conections.Matt
Oct 29, 2017 | Logitech Harmony 880 LCD Remote Control
No sound
If your TV is a Samzung, and has the Anynet+ function, you need to set the TV up with the Theater system. If there is an Anynet button on your TV remote, push that, and then select the function that sets up the sound system to the TV. If you don't see that button on your TV remote, then look for the option in the TV menu section. Once set up, you can use the menu under that Anynet button to turn off the sound system and return to normal TV audio... and while using the sound system audio, you can control the sound system volume, or mute it, with the TV remote.
Dec 22, 2008 | Samsung HT-Z310T Theater System
Unable to control channels or volume
Is the remote a universal? Make sure you select TV as the the device you are trying to control. You can also fix a wonky remote by popping out the batteries and mashing down all the buttons. This rids the remote of any built up electricity that could be hampering functionality. Also, the remote sensor on the TV is controlled internally of course so a power drain of the TV wouldn't hurt:
1. Unplug the product's power cable so that the device is not grounded to the house. Do not simply turn off the power-bar if one is in use.
2. Press and hold in the products power button for 1 minute to release the retained electricity from the capacitors and circuit board. 3. Plug the product back into the wall outlet rather than a power-bar to rule it out of contributing to the problem and turn the device back on.
What do the buttons on the TV itself do? Do they work properly? If not, the problem is going hand-in-hand with the remote and again, the problem is internal and service or a firmware update, if available, may resolve this.
Sep 20, 2008 | LG 42LG50 42 in. LCD HDTV
T.v turns on and off
MAY BE A LOOSE CONECTION TAP THE TV WITH HAND ON SIDE TO MAKE THE CONECTION MOVE BAD SOLDER JOINT WHEN IT GETS HOT IT WILL EXSPAND
Sep 18, 2008 | Mitsubishi WD-62528 62 in. LCD Television
Blows fuses repeatedly on IWT3206 model
when electrical storm was going on the t.v. was on ? if it is was then return electrical / heavy lightning it may burn the parts.shorting through your mains and anteena conections, please clarify
Jun 24, 2008 | Televison & Video
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
