What is the remote code for a Proscan 32LB30QD HDTV with DVD player built in to work with Comcast?
  • bkuyp Jul 17, 2009
    Using the standard process provided by Comcast did not work.
    I need the exact code for the Proscan TV I have which is model # 32LB30QD
    Scholar:
  • 119 Answers
Greetings,
You have the comcast remote... and the proscan remote. Depending on how you want to control things you could program both/either sets of remotes.
The comcast codes are here:
http://www.comcast.com/corporate/customers/customer_support/remotes.html
The proscan codes are below. You would try these codes on your comcast remote to operate your TV
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0807524.pdf
Also, keep in mind the proscan used to be RCA so the RCA codes MIGHT still work.. you can try Thompson as well... new proscan is made in Korea/China and is not owned by RCA or Thompson.
I hope this helps! I often struggle when trying to program remotes too :S
Please let me know if you need further clarification.
Posted on Jul 17, 2009
  • 3,037 Answers
The manual for the Comcast remote can be found at the following website link
http://www.comcast.com/MediaLibrary/1/2/CM/VanityURL/documents/comcast_on_demand_remote_manual.pdf
Basically the codes that should work are 0047, 0060, 0760, 1060
The directions for entering the codes can be found on the manual, if none of them work which does happen, then try searching for the code. The directions for searching are also on the manual that I posted a link for above. Let me know how this turns out
Benjamin
Posted on Jul 16, 2009
Need code for ProScan universal remote
Proscan HDTV Codes = 1000
Proscan TV Codes = 1000, 1008, 1068, 1094, 1108
Proscan DVD Codes = 2118, 2144, 2205, 2319
Proscan VCR Codes = 3000
ON MOST REMOTES:
1. Turn on the TV.
2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light.
3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
4. Verify by pressing the VOLUME + button. This should turn the TV VOLUME up.
5. Press the TV button to store the 3, 4, or 5 digit code. The button will blink twice to confirm the code is stored.
Your ProscanTV can be controlled with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc...
Nov 22, 2016 | Proscan Televison & Video
I have the Proscan TV/DVD combo. The cable remote works for the TV, but NOT for the DVD player. And ever since I got cable, the Proscan remote no longer works (for tv or dvd.) Long story short, I have...
Did ever worked properly?Is it wright one for unit that you have,you can check that in your owner manual,if not I will go back to dealer and ask for replacment.
Aug 23, 2011 | Proscan 32LB30QD 32 in. LCD TV
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
I need the remote control code for Proscan tv with dvd player
Don't know if the 26" is the same as the 32, but 10019 works for the 32".
Sep 09, 2009 | Proscan 32LB30QD 32 in. LCD TV
My remote stopped working and there isn't any sort of # on the remote to know whqat to order to replace it. I have the proscan 32" 720p model with built in DVD player.
its may be the bulb a the front part,, while presing up and down channel move bulb with finger if change channel its a lose solder joint on bulb,, if not bulb maybe bad
Aug 12, 2009 | Proscan 32LB30QD 32 in. LCD TV
Remote code for comcast dvr/proscan tv
I was having the same problem with my 40" Proscan Tv. I had to go to Comcast and get the remote with the gray OK button instead of the red. I could program my DVD player with a 4 digit code so this remote worked when I put in the 4 digit code Proscan sent with the TV (0178). This was the only solution I could find . They do have the remotes with the gray button but you might have to be very persistant to get one with the codes for the rest of your electronics.
May 23, 2009 | Samsung DVD-HD845 DVD Player
DVD input channel reads "no signal" when I try to play a DVD
First I would run a dvd cleaner in unit! Second you could take tv apart and look to see if signal cable is loose. the power wire seem fine as it powers up, and accepts an eject dvd.
Feb 28, 2009 | Proscan 32LB30QD 32 in. LCD TV
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
Electro Med Services...
