Question about Sony Cyber-Shot DSC-W5 Digital Camera
Sony digital camera lens is not coming out fully to take photographs
My Sony digital Camera Lens was not coming out and going in properly, but once it is outside I was able to take photographs.
After that I gave to one servicing centre for lens alignment and after that now I am not able to take photographs. Problem is that the lens is not coming out fully.After few seconds it is giving message to shutdown and start again. Same problem is coming in the next time as well.
Can the lens be out side permantly for ever and will I be able to take photographs?
Thanks & Regards,
  • Sony Master
  • 4,738 Answers
Re: Sony digital camera lens is not coming out fully to...
The following blog outlines some repair options for a lens error:
Posted on Dec 23, 2007
0 characters
3 Points
How do I fix lens error problem on the described camera?
lens error occur normally when it fell or the lens shaken, if so open the camera, take the lens unit out, disassemble the lens unit, then fix it again properly. example below:
(this is not the told model)
Dec 10, 2015 | Nikon Coolpix S3000 Digital Camera
My camera comes on and then the lens retract and go back into the camera. The camera never fully comes on. The batteries are fully charged and there is plenty of memory. Please help.
Could be one of the ribbon cables is loose. If you can open the camera and reseat all the ribbon cables. If the lens makes an ugly grinding noise the gears to the lens are chewed up. You can go to for a flat rate repair quote. Hope this helps.
May 27, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
Sony A200 lens problem
Do you have the lens aperture ring set to "A"?
May 10, 2010 | Sony Alpha DSLR-A200K Digital Camera
Turn on camera and the lens only comes out slightly
Hi there some how your camera lens is pressed heard from outside. Thats why the lens guide pin is damaged or dislocked & thats why its not came out fully. Even if you follow then you will get a bad noise from inside in the camera. So i suggest you repair the guide pin or replaced it. Thanks. Example of guide pin below:
Mar 23, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Sony DSC W30 digital camera, lens unit problem
If you're sure you didn't damage the lens flat cable which connect to the motherboard, the focus of the lens unit you bought on ebay doesn't work. You can simply replace the back part (with focus) of the new lens unit with your old one. It requires soldering.
Mar 06, 2010 | Sony Cyber-shot DSC-W30 Digital Camera
The shutters on my Fujifilm E900 wont open or close properly.
Do you mean the lens cover on the end of the lens Is not opening properly, or the shutter inside the lens?
Aug 24, 2009 | Fuji FinePix E900 Zoom Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera turn off
u c turned off the cemera immediatly & start it again after 20-30 min. it works poroperly again
Jul 01, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Telephoto lens
Hi, the adoptor tube are not compatible to the camera try to consult nearest lense seller they can recommend the exact adoptor lenses to your camera.
Sep 28, 2007 | Canon PowerShot Pro1 Digital Camera
My lens is stuck out and it won't go back in!!!
Lens motor is shot. If an older camera- buy a new one a repair will cost nearly as much. If young-[less than a year] send it back
Aug 11, 2007 | Sony Cyber-Shot DSC-P100 Digital Camera
Camera lens comes out and goes back in when I turn it on.
Sounds like the lens can't get into the proper position. Any possibility of damage to the lens?
Aug 10, 2006 | Olympus FE-110 Digital Camera
Sony Cyber-Shot DSC-W5 Digital Camera Logo
76 people viewed this question
Top Sony Digital Cameras Experts
Larry Spears
Larry Spears
Vish Iyer
Vish Iyer
Rick Johnson
Rick Johnson
Are you a Sony Digital Camera Expert? Answer questions, earn points and help others
