No volume Re Samsung 1080i rear projection tv.   There is no volume on all but 1 tv channel but the sound also works perfectly on the dvd. Was changing channels with the tv remote accidentally (only had the tv 2 weeks) and then realised and changed to STB remote with the result no sound on other channels
  • Anonymous Mar 17, 2014
    when volume button is pressed it appears on screen as if working but sound doesn't change.
  • 192 Answers
Normally when you have only one channel with audio the cause is usually SAP is turned on, either on the television or the cable or Sat elite box.
If you were pushing buttons on the remote, I would suggest that the SAP button is on the remote.
On a Samsung remote, the MTS button identifies this function. It may be labeled stereo.
Make sure the remote is in the TV mode to change or check on the TV.
It may also be a button on the remote for the Cable or Sat elite box. If not then you may have to search in the menu's of the Television or the boxes.
If the set is only two weeks old (the actual set, not how long you have owned it) then it probably has an ATSC turner labeled Air that will receive local HD by using rabbit ears. If the set is over 3 years old, it will not have this feature.
It's difficult to give a full de script explanation of a solution without knowing the model or configuration of the input signal.
If this does not help, respond to this post and I will reply.
Posted on Nov 18, 2007
sounds like a scaler problem.
hd bypasses the scaler, any non hd will be bad, try other stuff like dvd and video games. if its consistent, you need a new digital main pcb
if not, let me know i can help
Jun 05, 2010 | Samsung HL-P4667W 46" Rear Projection HDTV
How do I scan the channels on a Panasonic 1080i HDTV? This is for the conveter box hooked up to the DVD/VCR to the Panasonic 1080i HDTV'
The cable to the antenna and another cable from the TV needed to be hooked up and THEN follow the directions that came along with the converter box.
Channel 3/4 and scan., be sure the antenna is strong enough.
There was no need to touch the DVD/VCR box.
Jun 12, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Samsung 46 '' HDTV 1080P --------no sound
what is the complete model number of your tv?
does the volume control display pop up with a headphone or speaker sound on tv mode?
Mar 20, 2009 | Samsung 46 in. Flat-Panel LCD HDTV
Mitsubishi WS-55809 Upconvert Stopped working
your problem is the 2hdw board is located in the signal board.
Feb 02, 2009 | Mitsubishi WS-55809 55" Rear Projection...
All of a sudden sound
The Time Warner support walked me through getting my SAP turned off on the CABLE BOX.
Nov 06, 2008 | Hitachi 53SBX01B 53" Rear Projection...
Satellite input
Most tv setups require that you change the input source to gain the ability to watch the proper peripheral e.g. if satellite is connected on video one and the dvd is connected to the tv on another input such as video 2.
If the satellite runs into the dvd unit and from there the dvd is connected to tv you may have to power off or on the dvd player to resolve conflict.
Another problem may be the resolution setting if your tv is Hi Def. Set the tv and receiver to the resolution e.g. 1080i.
You can also changed the way the satellite is connected to the tv possibly if you have other inputs.
Check the channel also, if the unit is connected with coax it would more than likely need to be on ch 3 or 4 if you are at the satellite receiver box location. If you are at a stand alone tv off of a dual tuner you may need to search the channels for the right source both air(analog) and cable(digital).
Hope this helps you out. If I can be of more assistance let me know.
Sep 07, 2008 | Proscan PS60690 60" Rear Projection...
HD Issue
are you using scientific atlanta cable box by any chance?
Nov 27, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Using the component 2 outlets
please read your owners manual for the samsung ptv to determine the best input to use and possible proper settings to adjust in your menu's.
Nov 15, 2007 | Samsung HCL4715W 47" Rear Projection...
Hdtv-dlp has no sound or picture
This sounds like an o-so familar problem. It sounds like the Switching IC or the MICOM has failed
Nov 10, 2006 | Samsung HLN467W 46" Rear Projection HDTV
Televison & Video Logo
137 people viewed this question
Top Televison & Video Experts
