Make konica copier model 1212 problem j12, abnormalities since this model has no second cassette the problem can be rese by the 2&5 mode, just forgotten the location !
Power off then depress 2 and 5 and power on
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: pls. my Konica 1212
power supply went bad!
try this Reseat CN15 on CB than check the oporation of L1 L2
47 mode 00
hope that help
SOURCE: konica 1212 - no image on the copy, but copier run properly
this is might be simple solution check how you place you original to Document feeder it should be face up not face down. The transfer/separation corona is not install properly, drum carriage is not install and the locking screw is not screwed in. the last thing my question is did you completely run out of toner? If you did you have run 75 copies before the toner mix in to the developer. there is a shorter way to add toner to the developer but I can not tell you how not unless you are a copier tech.and you should have a extra developer with you in case the developer is over tone. HH
SOURCE: I need to know what code P.27 is for my Konica
the machine needs maintenance by a tech... its due... or you have problems with your toner sensor... and need a tech...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
SOURCE: how do i clean konica 3035 copier roller - where is it located
just with a dry piece of cloth.
or copy 40 white sheets(blanch) at least.
